308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 21 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,856
    Cerritos, CA.
  2. Jack-the-lad
    Jack-the-lad Eight Time F1 World Champ
    Wheel bolts for 1975 GT4? A thread search did not give any results.
    Thanks.
  3. Steve Magnusson
    27,022
    Jack-the-lad likes this.
  4. Jack-the-lad
  5. Ricambi America
    Sponsor Owner
    RodC328gts and Jack-the-lad like this.
  6. Jack-the-lad
  7. Cameron Henlin
    Cameron Henlin Karting
    161
    Roseburg OR
    Cameron Henlin
    My driver seat adjuster was damaged and I read elsewhere that 308 seat rails and sliders are from a Fiat 124 Spider. I purchased one from Midwest Bayless pn 4221988-OE and can confirm that they are identical to those on the 308, BUT the sliders on the 308 have an additional tab welded on making them somewhat Ferrari-specific.
    You could easily add the piece of metal but it will be some fabrication effort. I was instead able to use the Fiat rail as a reference and repaired and reinstalled my Ferrari rail. I am going to save the Fiat rail on my shelf and will weld tabs on to it and use it if I have any more trouble with the Ferrari rail in the future.
    miketuason likes this.
  8. ragtop1
    ragtop1 F1 Veteran
    5,278
    Ontario
    Larry Warren
    What's the tab for? Is it necessary?
  9. Cameron Henlin
    161
    Roseburg OR
    Cameron Henlin
    Yes, it is threaded, and it lines up with another tab on the bottom of the seat. The rails are mounted to the seats on the front of the seats by these tabs. On the rear part of the seats the standard Fiat mounting hole is used
    ragtop1 likes this.
  10. Cameron Henlin
    161
    Roseburg OR
    Cameron Henlin
    Following up a bit more, it turns out I actually took a picture of how it is mounted to the seat as well. Here you can see the tab on the rail aligned to the tab on the seat with the mounting bolt loosened. You can also see how bent out of alignment my seat rail was, that bar should be well below the bolt. Someone must have really been pissed at that seat!
  11. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    In case anyone is looking for a generic seal/weatherstrip for the rear cargo area on the 308/328, I can confirm this one is a match and fits well:
    Vertical Bulb Rubber Seal | Bulb Diameter: 0.51 inch (13mm), Grip Range: 0.039 to 0.12 inch (1-3mm)
    Amazon also sells it:
    https://www.amazon.com/dp/B0191KFEIW
    It's about $1.50/foot depending on the length roll purchased.
    Looks like the same seal shape/profile is also used around the front spare tire well, however the original front seal on my 328 has some glued/fused joints in the lower corners, so a generic replacement from a bulk roll would need some glue tweaks to be a perfect match (probably not super important).
  12. Jack-the-lad
  13. Mohan Balasingam
    Jan 5, 2020
    8
    Singapore & Malaysia
    Mohan Balasingam
    Thanks for this. Really appreciate this. Can i safely assume that this is for a 308GT4?
    Cheers,
    Mohan
  14. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,163
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Thermocouples for the "Slow Down" light system are available from Blaze Technical Services as Part Number 071223KU-154. These have a 154 inch lead which is the same length as the factory thermocouples.
    This configuration is not listed on their website so you have to phone or email them to order them.
    miketuason and derekw like this.
  15. Rags1873
    Rags1873 Rookie
    Jul 8, 2024
    13
    New Brunswick Canada
    Mark Perego
    Those references are great work. Appreciate that thanks. I have a parts catalog US version 1978 GTS GTB if anyone needs a photo of a part. I'm sure others my have this ferrari dealers shop manual. I attach a photo of cover and a page. New trying to load a photo lol.
  16. eurocarguy101
    eurocarguy101 Karting
    121
    Jacksonville, Florida
    Jefferson Wheeler
    Does anyone have a cross-reference to the toggle switches for the fan, rear defrost, hazard, and wipe speed for an 84 QV?
  17. ragtop1
    ragtop1 F1 Veteran
    5,278
    Ontario
    Larry Warren
    I purchased the fan toggle switch from this site. It is a perfect match. I carefully cut off the plastic tab, and the proper mouse ear tab slid right on. I don't know if the other two-way and three-way switches shown will work for our cars. They are all very inexpensive. The fan switch was about $12, part # SPB200. They are excellent quality and stamped Lucas; however, it's below the exposed switch.
    https://www.autoelectricsupplies.co.uk/c/lucas-toggle-switches
    I have bought the ones from Superformance in the past. They are junk and fall apart.
    eurocarguy101 likes this.
  18. aartbik
    aartbik Rookie
    Aug 19, 2024
    29
    Saratoga
    Aart Bik
    absostone likes this.
  19. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,565
    Atlanta, GA
    Steve D.
    bought the 7261, and it's the correct 1/4" top measurement, but nowhere near long enough for the crank/waterpump/alternator routing on my GT4. Dino parts sells a 975mm, which is Gates 7384. I'll update when I get it.
  20. absostone
    absostone F1 World Champ
    10,321
    #521 absostone, Aug 29, 2025
    steved033 and ChevyDave like this.
  21. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    538
    Pacific Northwest, USA
    Dave W
    LE06 likes this.
  22. LE06
    LE06 Formula Junior
    301
    Lee
  23. ChevyDave
    Dec 21, 2019
    538
    Dave W
    Awwwww.....dude.....well, what's funny/not funny about this is that my little project started out six months ago as a "simple" investigation of a throttle pedal with way too much stiction on return.
    Rebuilding carbs was the furthest thing from my mind.
    But once I started poking around (this is a new-to-me car), I found a litany of "while you're in there's" of which, rebuilding the carbs was just one.
    Ironically, the car drove fine when I first got it so I agonized over going all-in, knowing I probably should, but that I would also lose most of the driving season by doing so.
    Anyway, as the time I had available for the throttle pedal problem evaporated, it gave me the opportunity to ponder my predicament and finally commit to rebuilding the carbs and resolving all of the other issues.
    So I guess I'm apologizing for taking so long to come to that decision; I will endeavor to be better in the future....:p
    - Dave
    LE06 likes this.
  24. LE06
    LE06 Formula Junior
    301
    Lee
    Well it was a little rude of you to take so long costing me a few bucks but apology accepted. :p:D
    I know how you feel. My wife keeps saying “it was running fine why did you take it apart?”
    Yes but it was not perfect is my answer.
    ChevyDave likes this.
