308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 6 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. dave80gtsi
    dave80gtsi Formula 3
    1,964
    Ohio
    Dave Meredith
    This looks like one of those one-size-fits-all replacement deals.
    B.T.D.T. My experience is poor with these - the female part at the console is too long in the replacements, and the overall belt length is also too long to work.
    This ad says the webbing length is 131" - Off the top of my head, we all need something more like 110" or so.
    So, carefully measure the belts before you order a kit like this, and should you indeed ever find an exact match, post here!
    Cheers - DM
  2. Gerry328
    Gerry328 F1 Rookie
    2,673
    Home
    Gerry
    I am going to replace my compressor and cannot find the part number 278108. A few suppliers crossed that number to York 58066. Does anyone know if this is a new number for the correct compressor?
  3. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Dave Meredith contributed this in another thread, not sure if it's here yet:
    RADIATOR THERMOSTATIC SWITCH
    NAPA FS-193 Switch: On: 82 degrees C / Off: 68 degrees C
    This switch originally fitted to early 1980 Peugeot. Less than $25.00 USD. Perfect fit, completely interchangeable in every aspect.
  4. thecarreaper
    thecarreaper F1 World Champ
    18,167
    Savannah
    pm member JFRAZAR as he and his mechanic at his car dealership have a new rotary compressor upgrade thats less load on the engine and electrical system.
    his Mechanic "RED" as we call him, can redo the entire freaking system and you can have a carb 308 with reliable, ice cold a/c for a reasonable price.
    there are 2 carb 308s here with the new system and they work great. one of the 308's belongs to Joe, the other is my old red GTB 20433 that belongs to a multi exotic owner and friend of our named Brian.
  5. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    #130 Mike C, Jun 23, 2007
    Can't find the screws you need in black anodize, and don't want to pay $2 each nor wait for them from a Ferrari parts supplier? Been tempted to spray paint them?
    Here's a quickie make-your-own solution I use. You can probably find most of the common screws you need at the local hardware store like Lowes, Ace or Home Depot. Get them in standard zinc, and then just soak them for one or two minutes in "Instant Gun Blue" solution, which you can get at most gun shops or sporting goods stores. What it does is turn them "instant black", fast and cheap!
  6. Ultimate Pedals
    Ultimate Pedals Karting
    Nov 1, 2003
    101
    Palm Beach, Fl
    Rob Baylor
    BMW Part Number 61311363459.
    Bavarian Auto list price $39.95.
    Rob
  7. Ultimate Pedals
    Nov 1, 2003
    101
    Palm Beach, Fl
    Rob Baylor
    It appears (at least from the outside) that the Lamborghini Diablo uses the same latch.
    No sure about the inner bits (latch release cable attachment point, door lock lever etc....).
    Rob
  8. Ultimate Pedals
    Nov 1, 2003
    101
    Palm Beach, Fl
    Rob Baylor
    Same as the Porsche 930(same vintage).
    I don't remember if its the same as the coupe or the targa.
    See automotion.com part #902849 or #902858.
    Rob
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Here is a Napa part number for the copper crush washer on the oil and transaxle drain bolts:
    704-1356
    They call it a copper gasket. It's 22mm ID, 27mm OD and 1mm thick.
    $.64 each. Buy them 10 at a time and never run out.
    Birdman
    3px19 likes this.
  10. thecarreaper
    18,167
    Savannah
  11. thecarreaper
    18,167
    Savannah
  12. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #137 Brian Harper, Jul 6, 2007
    I just replaced a cam seal on my GT4. I took the old seal to the local bearing shops and got a replacement, SKF 19600 or Chicago Rawhide CR19600. I would have purchased more but they only had one in stock and I was ready to drive again. Applied Industrial Technologies sells the seal for $5.04 but the deal is over at Motion Industries for only $4.50.
    http://www.applied.com/apps/commerce/catalog/catalog.do?e=10&s=1436217&r=0&type=a
    Hey! Their website says $4.50 also. I was charged $5.04 plus tax. Picture doesn't look right, but the part is. Installation was easy, didn't even need to remove the cam cover, just belt cover and belt. Of course my AC compressor is already on the garage floor, so that makes it easier!
  13. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Didnt find this posted before, I looked, but sorry if its a repost:
    Oil Filter for 328s (308s?) instead of UFI:
    Thread as reference:
    http://www.ferrarichat.com/forum/showthread.php?t=158932
  14. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    I tried EP34 in my 1981 308 GTSi and it did NOT work.
    I tried EP36 in my 308 GTSi and it WORKED!
    There are posts in this thread that EP34 works in a GT4 and EP36 works in a 328.
    From my results I would conclude that EP36 works in 308 GT?i's thruogh 328's.
    Hope this helps.
    stephen
    PS got mine at Advance for $11.98.
  15. ATSAaron
    ATSAaron Formula 3
    1,136
    Shady Shores, TX
    Aaron Bunch
    Any cross over for a starter drive? Mine is not engaging 100% of the time anymore.
    Aaron
  16. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    #141 teveo, Sep 25, 2007
    i just got my adobe CS3 upgrade and had to check out the new acrobat sw.. :) compiles this thread, here is a summary of the interchange parts list.. print it and keep it on the desk, in the garage etc..
  17. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,856
    Cerritos, CA.
    Wow thanks, this are valuable information.
  18. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,270
    Indiana/North Carolina
    JIM
    This is EXCELLENT! Thank you for doing this. :)
    Printed and in my workshop manual!!!
    JIM
  19. bigdreamer
    bigdreamer Karting
    Jan 24, 2005
    203
    Wash. DC area
    Wayne
    RADIATOR COOLING FAN SWITCH 2 POLE
    VW PN# 82395948182 180F
    VW PN# 82395948172 160F
    $6 @busdepot.com
  20. ClydeM
    ClydeM F1 World Champ
    12,326
    Wayne, NJ
    Clyde E. McMurdy
    I just used a R-02 Metric O-ring for the radiator bleed screw available at Pep Boys in the o-ring kits.
    I/D=4.4mm, section=2mm.
    Fits well, no leaks
  21. ClydeM
    12,326
    Wayne, NJ
    Clyde E. McMurdy
    for an '83 308: All from Napa
    To confirm, GE158 has been superceded by GE168 - for side marker lamps. ($1ea)
    Brakelamps: #1034 ($1.70ea)
    Halogen Headlights LMP H6024 ($11ea)
    But the Crush washer listed as 704-1356 is the 18mm copper washer ($.69ea). Mine needs 22mm.
  22. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,068
    Kansas
    Sean F
    Didn't see this on the list
    For the carb throttle shaft bearings, sealed replacements SKF 607-2RSH/LHT23 (qty=8)
    Also, www.autohausaz.com sells the correct 7mm fuel hose that fits better than the 5/16th hose. They sell 7mm ID braided and 7.5mm ID non-braides FI rated line. They also have Gemi clamps.
    Look under 1972 Mercedes/280SEL. THe price is about 1/3rd what you'll pay local.
  23. ClydeM
    12,326
    Wayne, NJ
    Clyde E. McMurdy
    The body shop lost the screw for my hood release latch. Found a replacement (same screw as engine release latch):
    5mm x 20mm Machine Screw Flat - Phillips steel/Zinc Plated : $0.79 Home Depot. A little dip in Gun Bluing...presto! Perfect black match to original
    Also, time to replace the hodge-podge of screws holding the black fiberglass Air ducts/master cyinder/A/C cover down...
    (7) 10x1/2 Pan Phillips Zinc. A quick dip in the Gun Bluing fluid....Presto!
    BTW: A plastic "Motts" apple sauce cup makes a great dipping tub
  24. branko
    branko F1 Rookie
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    308 CV joints are the same as 91'-95', 164 Alfa Romeo inner CV joints.
  25. SpeedTek
    SpeedTek Rookie
    Aug 1, 2007
    41
    Hawaii
    Dexter
    The Fuel Filter posted is the wrong one. Is there any other part numbers? This is the one in the engine compartment. Is the Purolator one listed a pre-filter?
    1985 308 GTSi QV USA Model
    Hopefully someone has an answer, Thanks!
