308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 7 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. SpeedTek
    SpeedTek Rookie
    Aug 1, 2007
    41
    Hawaii
    Dexter
    We took apart the CIS FI an here are the BOSCH part numbers we got:
    0 438 140 132 Warm Up Regulator
    0 438 100 139 Fuel Distributor
    0 450 905 231 Fuel Filter (We subbed it with part #0 450 905 087)
    hope it helps!
  2. lekkerbek
    lekkerbek Rookie
    Mar 21, 2008
    3
    I am looking for a pair of engine lid struts for my 1979 Ferrari 308 GFS.
    Would the above listed struts fit my car ?
  3. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    I'm currently rebuilding my 328 window mechanisms.
    Here's the Bosch part numbers for the motors:
    Left: 0 130 821 069
    Right: 0 130 821 070
    These are the same ones as the FIAT 131 Mirafiori
  4. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    I believe that they would fit. But check the length and end fittings before you buy them. Pep Boy might take them back if they are wrong and/or you do not mount them.
  5. Sailawaysg
    Sailawaysg Rookie
    Apr 11, 2008
    47
    I used 1.25" napa fuel hose for the crossover.
    SG
  6. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Rear Brake pads - Wagner Thermo Quiet PD31 or PD736/WD31 less than $30 at local parts store.
  7. DGS
    DGS Seven Time F1 World Champ
    74,354
    MidTN
    DGS
    You can look up parts by year, make, model, and engine at
    http://www.boschautoparts.com/Resources/VehiclePartFinder/
    (You can ignore the VIN drop-down)
    After "Locate Vehicle" you get a "Select Part" drop-down of parts types.
    Each selection gives cross references such as:
    (e.g. for "Fuel Injection" under '88 328GTS V8 3.2 GAS)
    Part Number Description
    0 438 120 164 Air Flow Sensor
    0 332 204 001 Combi-Relay
    0 280 170 401 Cold Start Valve
    0 438 170 004 Fuel Accumulator
    0 280 150 300 Frequency Valve
    0 280 800 068 ECU - New
    0 332 015 006 Main Relay
    0 332 019 151 Main Relay
    0 280 120 310 Throttle Switch
    0 438 140 132 Warm-Up Regulator - New
    The listings aren't entirely complete nor consistently incomplete.
    For example, here's the "Fuel Injection" list for an '88 Mondial (same engine):
    0 438 120 164 Air Flow Sensor 1/88 to 12/88;
    0 280 170 401 Cold Start Valve 1/88 to 12/88;
    0 438 170 004 Fuel Accumulator 1/88 to 12/88;
    0 280 800 068 ECU - New 1/88 to 12/88;
    0 332 204 001 Main Relay 1/88 to 12/88;
    0 280 120 310 Throttle Switch 1/88 to 12/88;
    0 280 130 217 Thermo-Time Switch 1/88 to 12/88;
    0 438 140 132 Warm-Up Regulator - New 1/88 to 12/88;
    I'd guess that's probably the same thermo-time switch used in the 328, but it's only listed under the Mondial.
    FWIW.
  8. thecarreaper
    thecarreaper F1 World Champ
    18,167
    Savannah
    this is great WOW !
  9. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    I have made it my hobby to collect information on parts crosrefrence, Mainly on Ferrari 3x8, Mondial (and Lamborghini Countach) Here are some:
    Mondial Cabrio:
    Hood mechanism - Alfa Romeo Spider (diffrent length)
    Door handle - Alfa romeo Spider
    Front seat mechanism - Lancia Gamma
    Rear electric window mechanism - Lancia Prismassa, Thema, Y10, Fiat Croma, 100S Regata, mirafiori...
    Steering column switches and collumn - Lancia Delta (HF?)
  10. ClydeM
    ClydeM F1 World Champ
    12,326
    Wayne, NJ
    Clyde E. McMurdy
    #160 ClydeM, Jun 13, 2008
    I went to my local Napa to find the rear caliper rebuild kit using 1970-1976 Porsche 914/6 (GT Car parts accidentally sent me only the handbrake piece instead of both kits). The store says Napa no longer carries the kit nor are any available in their network.
    A local Foreign automotive place had a kit from VERA (31-07003)
    which had the ATI sticker 13.0441-4209.2
    I'll let you know if it works.
    An old ATI box I had is labeled 13.0441-3811.2
    Ati web site (English)
  11. AlfaGreg
    AlfaGreg Karting
    Dec 28, 2003
    83
    Saint John, NB Can
    Greg Gormley
    #161 AlfaGreg, Jun 16, 2008
    Does anyone have a cross reference for the fuel pump check valve, '77 carb 308 GTB. Mine is weeping around the pressed flange.
    Ferrari PN# 111790 - Valvola unidirezionale. Item #59.
  12. jabramson
    jabramson Formula Junior
    Jun 3, 2006
    502
    San Diego, CA
    Jeff
    #162 jabramson, Jun 26, 2008
    Looking to find a 1987 Concave 8 x 16 right rear wheel. Anyone have a lead on a used one in good condition? Part number 125925.
    Jeff
  13. moysiuan
    moysiuan F1 Rookie
    4,340
    Canada
    This part crossed to a Bord Warner item, which was available at a local (Toronto) Parts Source. Saved me lots of time and money.
    F-Chat - I have silver subscribed for the savings in time and money this simple parts cross provided!
  14. thecarreaper
    18,167
    Savannah
    i am glad this thread grew the way it did` !
  15. thecarreaper
    18,167
    Savannah
    #165 thecarreaper, Aug 22, 2008
    added this great post by Brian Harper.
    holy smokes. 32,000 views on this thread! wow!
  16. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    Instead of the $23 for the 42mm bearing in the water pump I took my used to a bearing store 8/27/08 here's the prices
    SKF 6302 28S1/C3 $11.86 6302 is the size, 28S1 means it has 2 neoprene seals
    C3 is the inner tolerance This is original equiptment
    or
    NSK 6302 VVC3 VV means 2 neoprene seals made in US $12.13
    So get 2 water pump bearings for the f suppliers price of $24 each.
    Have to get the multi piece seal from a f parts supplier
    Don't pay appx $140 for rebuild kit from T Rutlands. Just purchase the other items you need
  17. thecarreaper
    18,167
    Savannah
    quoted post added
  18. thecarreaper
    18,167
    Savannah
    #168 thecarreaper, Sep 10, 2008
  19. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    Hi, someone has a replacement suplier for those clutch bearings ? Prices are from www.eurospares.co.uk
    - trust bearing nr 100849 (£ 40.66) find this on there website Ferrari Mondial QV 3.0 (84), mecanical, page 19 clutch controls nr 023;
    - busch bearing nr 116326 (£ 118.50) page 19 clutch controls nr 033 ;
    - beating nr 103042 (£ 203.20) page 19 clutch controls nr 020 ;
    - off retainer nr 110314 (no price) page 19 clutch controls nr 021 ;
    - roller bearing nr 105142 (£ 43.30) page 21 gearbox transmission nr 10 ;
    - axial roller bearing nr 105143 (£ 12.70) page 21 gearbox transmission nr 11 ;
    - bearing for mainschaft nr 108655 (£ 180.80) page 21 gearbox transmission nr 12 ;
    Guido
  20. thecarreaper
    18,167
    Savannah
    http://www.reidsupply.com/pdfviewer.aspx?catid=BPT&refid=BPT
    these guys are a great source for any and all bearings ever made.
  21. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I purchased a used Delorean seat belt receiver for my 1980 308GTBi for $32. It is about 4cm shorter but otherwise identical. There are several sources of new and used parts for Delorean cars. Delorean Motor Co, Texas, has complete new belt for $138. Ferrari used sources of hit/miss and quoted me $100 for the same part.
    Ferrari used two belt types (mondial et al)...squarish tang with square hole and Press button on wide flat of rectangular receiver. Mine has 'mushroom' shaped tang and Press button on edge of trapezoidal receiver.
    http://www.deloreanone.com/cgi-bin/cat00.pl?page=876
  22. pshoejberg
    pshoejberg Formula 3
    1,884
    Denmark
    Peter H
    Any one now the size and/or SKF puchase number for the 308 spigot bearing?
  23. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    #173 theunissenguido, Oct 12, 2008
    10- Ferrari 328 /Mondial QV 3.2 and others (1987-1988) - BEARING extern driving gear
    Part No. 112981
    ▼ Zylinderrollenlager, bordloser Innenring, 2 Borde Außenring NU10
    NU1007ECP SKF 33.99 EUR
    Website :http://www.ekugellager.de/advanced_search_result.php?keywords=SKF&Wälzlager-Suche=search&sort=1a&page=68
    2 -Ferrari 328 / mondial QV/ 3.2 and others (1982-1988) - ROLLER BEARING
    Part No. 105142 INTERMEDIATE GEAR
    INA RNA 49/32 XXL Life INA 32.95 EUR
    "Search-suche" on this website "INA"
    Guido
  24. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    #174 theunissenguido, Oct 16, 2008
  25. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Actual part number for the 308/328 engine lid gas struts: SACHS # SG237001
