308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 8 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. dave80gtsi
    dave80gtsi Formula 3
    1,964
    Ohio
    Dave Meredith
    #176 dave80gtsi, Dec 30, 2008
    Addendum / Update: I recently ordered a pair of replacement rear engine pneumatic gas struts for my 308 thru a well-known Ferrari parts house.
    I ordered Ferrari number no. 60592800
    What I received was a pair of generic Stabilus struts (in Stabilus boxes w/o any Ferrari markings).
    The Stabilus model number is 1831-BR.
    Perfect fit, work great.
    Cheers - DM
  2. Thomas Quintin
    Thomas Quintin Formula 3
    Mar 2, 2005
    2,066
    Paris France
    Thomas QUINTIN
    Does someone know from which Fiat, Alfa or Lancia, the power window switch of 308 GT4 comes?
    Best regards
    Thomas
  3. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,270
    Indiana/North Carolina
    JIM
  4. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    For the Early 308 cars that use the Sipea 6010: use a Tridon EL13. I replaced the unit on a '79 GTB.
    The units mentioned earlier do not have the same connector layout. Best to just bring the one from your car to the auto parts store and look at all of them until you find the same pin layout (P,L,+).
  5. marco246
    marco246 Formula Junior
    Mar 25, 2004
    288
    Hawaii
    Mark
    I just replaced my 328's OEM water pump with one from Nick's Forza Ferrari and found that the OEM belt does not fit. It is 20 mm too short. Gates makes both the OEM-sized belt (Gates 7M630) and a larger one (Gates 7M650) which will fit the NFF water pump.
  6. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    308 window switches are also the same as Range Rover Classic ('82-'89) - these are $2/each used on ebay.
  7. fdekeu
    fdekeu Formula Junior
    637
    Belzium
    Frank
    Anybody has cross references for the 328 rear wheel bearings
    They are not the same as the ones of the 308/QV/8
    Ferrari numbers: 144807 + 145805 (about 50£/each at Eurospares)
    Also of the front wheel: 112799
    This one is more expensive: over 200£
  8. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    I've done the search feature on all I can imagine for this topic. Friend of mine is in dire need of the top latches on his GTS. Factory prices downright scary. Anyone know of a better solution? Does an X1/9 use these? Alfa Spider? Just poking around tryng to help. Thanks in advance. Even if no matches, this thread is a major help.
  9. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    Here's what I have:
    Front Bearings- Ferrari p/n 112799 -> SKF 441696M
    This bearing is difficult to find. A local supplier was happy to sell me the 2 last ones in stock for many years :)
    You have to shop around.
    Rear Bearings - Ferrari p/n 145 805 -> SKF 62207 2RS1
    Ferrari p/n 144 807 -> SKF 62208 2RS1 or 62209 2RS1 ? Not sure which ... if someone knows for sure please post !
  10. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #185 spiderseeker, Mar 17, 2009
    * If he just needs the latches rebuilt, I think "Verell" does that at reasonable cost, if he needs the entire latch, he needs to check a Ferrari salvage place. (do a serch for them- gtcarparts I think is one)
  11. Jdubbya
    Jdubbya The $10 Trillion Man
    44,175
    Hell's waiting room
    After exhaustive searching I didn't find anywhere that a cross ref # was posted for ignition condensers for the carb 308's. I'm sure it's here on Fchat already but I didn't find it. I was finally able to cross the number online somewhere to a Fiat part # 9942107. Napa didn't have any and said they couldn't even order one. Schucks though was able to pull through and they are now on the car and seem to work just fine. They are slightly smaller than the Marelli ones that came off the car but the car runs great with them on. Oh, and they were $3.99 each!
  12. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    #187 theunissenguido, May 7, 2009
    Starter Fiat nr F 416 27 84
    Solenoid Magneti Marelli nr 636 00 403 superceeded part nr 855 40 281
    Aplication for Fiat Uno 45-55-60-70
    Price about 40 euro.
    Ordering by your starterrepair-shop
    www.menbers.it part nr; 03720500
  13. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    I have found a perfect match for the Exhaust Donut gasket on the QV engines at NAPA Auto Parts.
    It is a FELPRO PN# 8194. Originally GM V8 1935-1987 Exhaust Pipe Flange/Ring
    $1.99 each
    Also, the exhaust flange bolts are 2 3/4 inch long 8mm standard threat (since they tend to break when they are old)
    $0.70 each
  14. thecarreaper
    thecarreaper F1 World Champ
    18,167
    Savannah
    this info was posted by BIRDMAN, AFTER MUCH HARD WORK.
    thermostat for 308's, made by Hella , Germany.
    quote
    1.173.80.300 : Thermostat In den Merkliste legen
    Beschreibung
    Thermostat, Kühlmittel
    Kategorie:
    Thermal Management > EC Equipment for Passenger Cars > Thermostats
    Kenndaten
    Artikelnummer 1.173.80.300
    EAN 4250192924301
    Alte Teilenummer H78010041
    Öffnungstemperatur [°C] 80
    quote
  15. thecarreaper
    18,167
    Savannah
    quote .
  16. Roberto Japanini
    Aug 13, 2007
    26
    Kakogawa City, Japan
    Robert Dunn
  17. thecarreaper
    18,167
    Savannah
    #192 thecarreaper, Jul 5, 2009
  18. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Since the brake booster check valve p/n 128435 and earlier version 101538 are truly no longer available, you can use the similar valve p/n 193186 from a late model 360 and 430 is a direct replacement... it's just plastic instead of metal and VERY inexpensive:
    http://www.ricambiamerica.com/product_info.php?products_id=210005
  19. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I've received no response from these guys regarding this switch. Anyone got a source please?
  20. ace_pilot
    ace_pilot Formula Junior
    Sep 6, 2007
    921
    Long Island, NY
    George
    Struts works perfectly on my 328. Thanks for the info!
    Ace
  21. Ricambi America
    Sponsor Owner
    I have 2x.
  22. Aircon
    100,524
    Peter
    #197 Aircon, Jul 18, 2009
    really? the correct ones with the arrow only as an outline and 4 terminals, not 5?
    (i sent a pm...no response yet)
    it's says no stock on your website.
  23. thecarreaper
    18,167
    Savannah
    your welcome, always nice to hear a thanks now and then ! :) :) :)
  24. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,881
    The twilight zone
    I needed an alternator for a 1980 2Vi and found an Iskra 1-1347-01BO-2 for $120 brand new is basically a drop in replacement for the bosch unit. It came with a longer bolt and spacer to get the tension bracket attached right then I had to swap on the original pulley, leave the rear heat shield off (I could have used it with spacers and longer screws I think but this is a US car with insulated headers so I figured it will be just fine) , and the new alt has an extra terminal labeled “W” that is not used for a 308 (it’s alternator rpm and is used to turn off an ignition light on some vehicles). There is no core exchange so you can keep the original incase you want to have it repaired.
