308 Alternator Question (1980 GTBi) | FerrariChat
Discussion in '308/328' started by kgantzer, Oct 2, 2007.
  1. kgantzer
    kgantzer Rookie
    Apr 9, 2004
    31
    Ohio
    Kurt Gantzer
    I have searched the forum, and found various references, but no clear answer to the question below.
    I need to repair/replace my alternator. It is an original Bosch unit.
    Can anyone recommend a reputable source (and fair priced) to either rebuild my unit or to get a replacement unit?
    Thanks,
    Kurt
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    You might be better off posting this in the North Central section.
  3. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
  4. ATSAaron
    ATSAaron Formula 3
    1,120
    Shady Shores, TX
    Aaron Bunch
    I don't know if a 78 GTS and a 80 GTBi use the same alternator, but I just installed a rebuild Fiat Spider unit from O'rielly Auto Parts and it was identical to my old alternator. I think it is still a 55 amp unit though. I am very tempted to try and install a GM 100 amp one wire alternator on my 78.
    Aaron
  5. ATSAaron
    ATSAaron Formula 3
    1,120
    Shady Shores, TX
    Aaron Bunch
    Oh yeah, the core charge was cheap, like $15, so I just paid it and kept my original one.
    Aaron
  6. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    Hi, in the sticky thread about part sources, I found this. I just bought one but it has not arrived yet. It should be here tomorrow or the day after. I can post my impressions if you like.
    Gianluca
    Rebuilt Alternators: from a popular Ferrari parts website,...
    308 & Mondial, 1974-82 models, 65 Amp: #FR110073R $389.95*exchange
    Give me a freakin break !
    try this.. but you will have to swap the pulley.
    Worldwide Alternator Part Number: 13152 Our Price:$36.99 Lifetime Warranty
    its the same from a (80 Fiat spider)
    http://www.partsamerica.com/ProductD...ype=11&ptset=A
  7. kgantzer
    kgantzer Rookie
    Apr 9, 2004
    31
    Ohio
    Kurt Gantzer
    Thanks - keep me posted, please.
  8. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    I couldnt get the link to work (maybe something wrong with FChat again with links?)
    However, is there a fiat equivalent replacement for the 83-85 QVs? Anyone?
    I'll check the sticky too......
    James in Denver
  9. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    +100 I'd prefer to get a 'new' Bosch replacement for the 83-85 QV cars, with a slightly higher Amp rating....can anyone recall the 'stock' Bosch part number?
  10. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
  11. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
  12. mike308gts
    mike308gts Karting
    Aug 28, 2006
    97
    Washington NJ
    Michael
    I used the 13152 Worldwide alternator on my 79 308 and it works fine.
  13. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    I understand - however, because of the EFI system that carb cars don't have, our Amp requirements hover in the 83-85 range. Its a known fact that QV/3.2 litre cars have larger, higher-output alternators than the carb cars do - but I don't know what mine is compatible with, replacement-wise.
  14. Gianluca
    May 6, 2003
    349
    Gianluca Chegai
    I received the 13152 alternator. It is identical to the original. The pulley has to be changed and it took 30 seconds. There are no markings on it. The voltage regulator is there.
    For the $ 36 plus 8 for the core it is worth a try.
    Gianluca
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Can anyone confirm this will fit the early 308? For $42 and I can keep my old alternator this is well worth it.
  16. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I used that 13152 alternator in my '75 GT4 and it was _exactly_ the same as what I pulled out. But you can't use that alternator on an FI car because the FI needs more power, right? Well, I agree that it should especially since CIS K-Jet uses heaters to run everything, but my GT4 has been "upgraded" to CIS FI and the alternator keeps up just fine, even at night. If I had a GTXi I probably would go for the bigger alternator, but I might try the 13152 because for $45, it could be worth a shot, especially if your night driving with highbeams, low revs and slow speeds with the AC on full while running the defroster stays to a minimum.
    And I, too, thought about a GM 100 watt alternator, but since I have no stereo and the car has so little electrical stuff I didn't think it would be worth it. I did this on my Scirocco, though, and it was better and cheaper than the stock unit, but I also had an amp that would dim the headlights when the volume was up!
  17. Phil Agnes
    Phil Agnes Rookie
    Jan 1, 2020
    2
    Philip Agnes
    Just had my 1982 308 GTSI alternator rebuilt locally $139. Discount Auto Parts the same price. Bosch part # 0 120 489 156 65 amp
    miketuason likes this.
  18. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    I have used Kaestner Auto Electric in WI. Alternator was stepped up to 110A. Cost with shipping was $319. I'm very happy with the work that they have done and great people to deal with.
