308 Battery Replacement | FerrariChat
Discussion in '308/328' started by chfengr1, Aug 17, 2004.
  1. chfengr1
    chfengr1 Rookie
    Aug 17, 2004
    9
    Connecticut
    Ray
    Help! Can anyone suggest possible non-oem battery options for my '84 308 GTS i QV? When I bought 7 yrs ago, had an Interstate that fit perfectly. Unfortunately, when that died a year later, I didn't record the model no. (shame on me!); went to Sears, got the closest DieHard "replacement" for the Interstate (they could not recommend a DieHard model, as Ferrari 308 was not in their database). When I got the new battery home, found I had to surgically alter its base flanges to fit the car's mounting bracket scheme. Now I need a new battery and would like one that fits perfectly without cutting it up.
    Thanks!
    Ray
  2. BigTex
    79,211
    Houston, Texas
    Bubba
    Bosch is what's in mine, IIRC
    Don't have it handy though.......
    Anyone use this one??
  3. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Funny that your Die Hard was too big, I'd be curious what model that was.
    The brackets on my 78 are just a hair too large to effectively clamp the standard sizes of batteries. I just put in a Die Hard I think I got a group 78? It fits, but isn't retained all the way by the clamp. Batteries theoretically should all be the same size, but I'm sure there are variances. There are quite a few threads wherein people discuss what variety of Optima battery they put in their cars. Do a search on that.
  4. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I use Optima batteries in all my cars. Optima makes a reverse pole battery if you car requires same. I used an "orange top" Optima which has reversed poles in my ex-348 Spider which required that.
  5. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    Interstate in my '85 308...I had similar problem with Interstate, though. Died after only a couple weeks. Each time, I went to the Interstate distributor and got another one. Each one died soon after...then I went to a local garage and bought an Interstate...been in the car for 3 years. I called Interstate and was reimbursed for the purchase. They told me they had a faulty lot of batteries go out. You should have returned the battery...Interstate would have stood behind the product.
    Interstate is the only company I know of that makes a battery with the poles reversed, as required in the 308.
  6. Eric308gtsiqv
    Eric308gtsiqv Formula 3
    Nov 26, 2001
    1,955
    Orange Park, Florida
    Eric Eiland
    Just dropped a new Optima Red Top battery in my 308 about a month ago...I purchased the model that has both the top and side post terminals...purchased from local AutoZone for roughly $130 or so. Fit perfectly...even better than the larger size battery that was already in the car.
    I now have Optima Red-Tops in both the TR and 308....with no problems to date whatsoever.
    FWIW, I hooked up the battery tender overnight to the Optima after installation in the car just to ensure it was fully topped off before driving. If I don't get a chance to drive either of the cars within a couple weeks or so, then I top them off with the battery tender unit.
  7. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    Good point...I forgot to mention it....After all my battery problems, Algar Ferrari of Philadelphia suggested that I put a battery tender on...they installed it for me for less than $75.00...they said they put battery tenders on all new cars too...well worth the money.
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Optima red-top in my 1984 308GTSi/QV USA model. It's great.
  9. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Optima here too.
  10. f355spider
    f355spider F1 World Champ
    17,934
    I believe the correct size for the 308/328 should be the size 34R. That is a size 34 battery, but with the terminals in the reverse position. If you take a standard 34, and flip it around, the cables may not reach.
    You should also be able to fit one of the new "universal" size batteries like the 78/34. This has the side terminals (for the 78 size) and has the top terminals closer to the mid line, so if you flip it around, the cables should still reach.
    Both sizes are available in "standard" type batteries available from Interstate, Sears or Costco (btw, Costco's "Kirkland Signature" batteries are made by Exide, the same oem as the Sears "diehard"). Optima also makes batteries in the same three sizes.
    You can get a Costco 78/34 with 900 CCA for $59. Quite a bargain.
    The only Optima Costco carries is the smaller 75/35 with 720 CCA, which should still be fine. I think the factory spec is for a 550 to 600 CCA battery.
    Dave
