308 carb idle question, w/ A/C on-off...? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by greg328, Apr 29, 2007.
  1. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Guys the idle solenoid was a produst used on a lot of american cars prior to the electronics era and FI. It is a solenoid (plunger) that is mounted to a bracket and presses on the throttle lever. The way it worked is when you turned on the AC the compressor clutch engaged and at the same time the idle solenoid was engaged. This would push out the plunger maybe an 1/8 or 1/4" against the carb. throttle. Thus the idle would increase to compensate from the drag of the AC compressor. I think it would be easy to do this on our carb cars all you need to do is fab a bracket and go to any parts store to get a solenoid. Simple. Enjoy the ride
  2. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Steve--good info..
    Greg
    PS--Pippo, I'll PM you ASAP..
  3. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    No hurry, Greg....its Friday!! Hope Steve's tip helps.
    (Thanks, Steve!)
  4. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Theory:
    I've measured the RPM drag my Sanden compressor creates, and it seems to be ~500RPM.
    Seems excessive..
    Could this be due to an overly tight belt? Or is that not an issue because the belt is always spinning?
    Could the compressor clutch kicking in cause that much drag if the belt is too tight?
    What is the proper A/C belt tension?
    Greg
  5. Steve King
    Feb 15, 2001
    4,367
    NY
    500 rpm seems to much. Something else is wrong. I still have the York piston type compressor and it only takes about 100rpm drag. The rotary Sanden compressor should be less then the york. So I would think that it would only take 50-60 rpm drag. As I mentioned before I set my idle at 1100 rpm and when the AC is turned on it drops to 1000rpm.
  6. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Steve,
    What do you think I should look at? The Sanden is new.
    Could belt tension be a factor?
    Greg
