308 Center Console Sag thread??? | FerrariChat
Discussion in '308/328' started by gil308, Aug 16, 2015.
  1. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    Forgive me in advance...I've tried searching here, and even Google searches...I cannot locate the thread that provided a detailed description of how to repair the center console sag on the 308's (below the gauge cluster). It had pictures and everything!!! Which I need as I'm very simple...I remember searching "308 center console sag" in the past and it came right up. I even bookmarked it...but my bookmarks are gone!!! Any help is greatly appreciated.
  2. ClydeM
    ClydeM F1 World Champ
    10,578
    Wayne, NJ
    Clyde E. McMurdy
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    I've out a wooden block under there to support it.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I have a hypothesis that overtightening the screws in the ash tray causes the sag under the gauge cluster. But once the damage is done (over much time) I'm not sure that straightening the bracket under the ash tray alone will resolve the sag.
  5. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Injected cars are leather... They shrink especially in hot sunny areas and warp the panel. I've notice he early carb cars aren't as bad perhaps they were wrapped in vinyl ?
  6. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Same here, more than a decade ago.
  7. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I cut a length of smal square tubing to bridge from one side of the inside console to the other, braced it in place with wood clamps so that it raised the sag back to straight and then glued the two ends of the tubing to the fiberglass console with large blobs of epoxy glue.
    I think it is more from differences (construction inaccuracy) in the height of the top of gearshifter box and the underside of the console. The screws need to be done up tight or else the shifter gate is loose.
  8. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,542
    Munich, Germany
    Michael
    #8 ME308, Aug 17, 2015
    yub ... between gate and ashtray
  9. 2281GT
    2281GT Formula 3
    Oct 9, 2006
    1,132
    Germany
    Markus
    @ ME308
    PM
  10. chris_columbia
    chris_columbia Formula Junior
    818
    Columbia MD
    Chris
    I used the wood block too. I cut it at a slight angle to make a wedge so I could adjust the height at installation. I was going to glue it in place, but it was so tight I just left it unglued. That was 8 years ago. It still hasn't moved.
  11. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
  12. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
  13. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,542
    Munich, Germany
    Michael
    #13 ME308, Sep 26, 2015
