308 Compression test? | FerrariChat
Discussion in '308/328' started by SlickMurphy, Feb 18, 2005.
  1. SlickMurphy
    SlickMurphy Formula Junior
    Aug 18, 2004
    275
    Essex
    David
    I am having a PPI done on a 308 next week and I have a few questions. I am getting conflicting reports from many Fcar mechanics as to whether or not a compression test and leak down is really neccessary. They claim that they can gauge compression by exhaust smoke, oil in exhaust, engine sound, engine smoothness and general driving characteristics. Most mechanics want between 2-4 hours JUST for the compression test. And if the compression is good, is a leakdown still needed?
    Anyway, I am having a compression test done regardless of what I am told!
    thanks,
    David
  2. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    A compression test should tell you if there is a problem, a leak down would pinpoint what the problem would be. I havent met the mechanic yet that could tell me that one of the cylinders is 20% down using a calibrated seat of the pants.I also pull each plug wire one at a time,as the engine is running and listen for a stumble, all should sound the same. This also detects ignition and fuel supply problems at each cylinder.
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    If a mechanic tells you he can tell engine condition by looking at/driving the car, go elsewhere. Spend the money on a leakdown. It should run $200 - 300 and will tell you a lot about the condition of the engine.
    Remember, a rebuild or a rebuilt engine is going to cost $10 - 15K. A couple of PPIs is cheap insurance.
    Philip
  4. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
    Check before getting it done whether it will be done cold or hot (esp the leak-down testing). I've seen much discussion on this, & I think the majority seem to think that it should be done close to operating temp. As the idea is to compare the numbers to some "standard" or reference, it's important to compare the same variety of fruit, so to speak.
    Seek more advice is my advice!
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    From memory, 185 degrees water temp is the reference point. Warm, not hot.
    P
  6. Dr Tommy Cosgrove
    36,716
    Birmingham, AL
    Tommy
    Ask them if they can tell you how fast a car is going just by listening to how loud the engine is too
  7. Chiaroman
    Chiaroman Formula 3
    1,690
    New Jersey
    Have every possible test done NOW!
    You will only pay MORE later!!!!
    I know it is easy to fall in love with the car as is and you want to BELIEVE in the car and make it into something it isn't.
    Take a few steps back and listen to me and all the others here.
    Please...I speak from experience and I want you to learn from my mistakes.
    (It's cheaper that way!!!)
