308 coolant change | Page 2 | FerrariChat
308 coolant change
Discussion in 'Technical Q&A' started by sp308qv, Aug 11, 2005.
  1. f360racer
    f360racer Karting
    Sep 14, 2004
    193
    Renton, WA
    PJ Z
    I was wrong about them bleeding the system. After it overheated yesterday in Bellevue I called the mechanic and he said, "Actually I didn't bleed it!" So I'll do it myself. Hope that really fixes the problem. I'm tired of leaking all my new coolant out on every outing. One thing I see is the thread on the header tank is stripped on one side so it doesn't lock at the tightest point. I have to back it off a bit to find a tight spot. Is there any way to fix this without a new tank. Its just the lip of the thread is stripped. Maybe this is why it overheats if it can't pressurize sometimes.
  2. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    164
    Austin
    Great help on the procedure. A few pictures to add to this thread to help the future internet.
    picture of the screwdriver method for draining from the access panel
    Picture of the funnel for the engine stopcock
    and then a plug for two things that help immeasurably once installed
    EZ-bleed screw for the water pump - http://www.unobtainiumsupply.com/
    and Clark & Clark’s front and rear stopcocks that support running tubing straight to the gallon jug
    https://clarkandclarkinc.com/catalog/ferrari
