News
308 Dead Battery Engine Start
Discussion in 'Technical Q&A' started by RAC911, Jul 19, 2020.
  1. RAC911
    RAC911 Karting
    111
    Arizona
    Ralph Cacace
    The 308 battery is located in the front under the spare wheel. If you encounter a dead battery, how can you easily jump start the car without removal of the spare tire and battery cover? On the 355 there are connections in the engine area.
  2. 308 milano
    308 milano F1 Rookie
    4,234
    Montana
    Kim
    Unless someone has added some alternate jump posts I think the only alternative is to push start it? Not sure that’s even possible with the 308. I am one of the guys that just leaves his spare tire and battery cover in the garage.
  3. miketuason
    miketuason F1 World Champ
    Silver Subscribed Owner
    Feb 24, 2006
    13,892
    Cerritos, CA.
    Kim is right, either push start it or jump start it straight from the battery.
  4. wmuno
    wmuno Karting
    Dec 24, 2007
    57
    Wilmette, Illinois
    Bill Muno
    Any metal part of the engine would be a good ground (the negative connection). For the positive connection, the battery side of the starter solenoid would work; this terminal should have a heavy wire directly from the battery. I don't know how good the access to the solenoid would be in the engine compartment.
