308 Distributor problem
Discussion in '308/328' started by Paul308GTSi, May 31, 2011.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Paul308GTSi
    Paul308GTSi Formula Junior
    Oct 26, 2008
    979
    Queensland Australia
    Paul D
    #1 Paul308GTSi, May 31, 2011
    I was just in the process of removing the distributors so that I could reseal the cam covers when I discovered a mess inside the front distributor. Obviously there should not be a pile of brass shavings inside the cover.
    It appears the rotor has been rubbing on the contacts for ages .......... should this be happening ??
    I'm used to electronic ignitions and am a little lost with this old technology ......Help !
  2. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    83,600
    Mount Isa, Australia
    Pap
    Is there any lateral movement there Paul when you move the shaft up and down?
    Looks like the shaft bush is worn out, causing the rotor button to "wobble" and wear out 1 of those 4 posts inside the dizzy cap. Although it looks like they have all copped a hammering over time it seems.
    If there is movement there, remove the dizzy's and overhaul them. Or have a pro do them both and have them bench tested while he is at it. :):)
    The rotor button does not (should not) touch the posts. As it comes past the post, the spark jumps from rotor button to post to send spark to the lead/spark plug and into the cylinder.
    Have the dizzy's overhauled and replace both dizzy caps and rotor buttons while you are it. :):)
  3. mwr4440
    mwr4440 Three Time F1 World Champ
    32,869
    Bavaria, The 'Other' Germany
    Mark W.R.
    To the best of my limited but growing knowledge in this area, PAP is "All over it."
    GREEN rotor buttons?????? Hmmmmmmmmmmm ....
    Never seen those before. Got ANY markings on them?
  4. Sledge4.2
    Sledge4.2 F1 Rookie
    4,605
    Marin
    Geno
    #4 Sledge4.2, May 31, 2011
    My old dizzy caps looked much worse. I had my distributors rebuilt (new bearings) when I did the pertronix setup. a few months later, I noticed the caps had huge grooves in the terminals (worse than yours), so I bought new ones. Prior to rebuilding the distributors they were spinning out of round causing the grooves in the caps. When I later replaced the caps there was no change in the way the car ran. While those grooves arent good, in my case they didnt seem to affect the spark that I could tell.
    agree with earlier response you should rebuild the distributors including new bearings.
  5. miketuason
    miketuason F1 World Champ
    Rossa Subscribed Owner
    Feb 24, 2006
    11,762
    Cerritos, CA.
    Looks like you need to replace the oil seal too.
  6. Jonny Law
    Jonny Law F1 Rookie
    2,789
    La La Land
    IT Guy
    More then likely the brass shavings are a result of the rotor head being too far away from one of the posts. When I opened mine the hammer head of the rotor was laying on the bottom of the cap, and the inside of the cap looked like it had been painted in gold metal flake. Since the normal fraction of an inch clearance was now 1/4 inch, every rotation arched off a little brass.
    superformance.co.uk has replacement rotors and caps for £99.00 ($150ish) each.
  7. Tired of seeing this ad? Upgrade now
  8. mikael82
    mikael82 Formula Junior
    783
    Finland
    I just opened my i-model distributor to change ignition wires and was little surprising to find that it got QV rotors in.
  9. Paul308GTSi
    Oct 26, 2008
    979
    Paul D
    #8 Paul308GTSi, Jun 1, 2011
    Oh Yeah ! :)
    I didn't mention the other end of the camshaft where the seals are so bad it looks like a memorial to the Exxon Valdez !
  10. Paul308GTSi
    Oct 26, 2008
    979
    Paul D
    I hadn't noticed any problem with spark either , she'd rev out easily with no stuttering or problems.
    I'm certain in time it would have had problems for sure.
  11. mwr4440
    32,869
    Mark W.R.
    Oh yeah? How did it run with those in?
  12. mikael82
    783
    Finland
    #11 mikael82, Jun 1, 2011
    Well, I had no idea that it got QV rotors until, few week ago as I was browsing Superformance homepage and almost write there that they got it wrong with rotors.
    Otherwise 308 GTBi (I like when people make clear note for what model they have not just "308") has both original distributor caps (9/80) and until last week, original ignition wires.
    I have no idea when rotors had been instaled, they look very old.
    So I would say; It runs excatly how it should and not burnig distributor caps or connectors.
    (btw, car is originally sold in Germany)
  13. Yoric
    Yoric Formula Junior
    268
    Yoric
    My rear cam cover is leaking noticeably and, though I've already bought the correct (green) gasket from Ricambi, I'm now a bit hesitant to remove the cover, scrape off the old gasket and replace it (with Hylomar or Hondabond in the right places). I'd do it in a heartbeat if I didn't have to remove the rear distributor--or do I? It took me many tries to get the timing and distributor setup just right, and the thought of going through it all again is giving me pause. By the way, my car is a '77 GTB.
  14. Tired of seeing this ad? Upgrade now
  15. Paul308GTSi
    Oct 26, 2008
    979
    Paul D
    Well it looks like I have to replace a couple of distributor caps , fair enough.
    I might as well replace the ignition wires also , , at this point I would prefer to change the huge long straight plug leads for the angled ones like QV's have ...... not because they are QV parts but because the angled end means they do not stick up in the way when I am fixing something else.
    Will QV plug leads also 7mm like a 2 valve GTSi distributor cap ? I'm trying to find black leads and caps also ........ so what fits , , I recall somewhere on here someone modified Honda / Accel plug caps.
  16. Jonny Law
    Jonny Law F1 Rookie
    2,789
    La La Land
    IT Guy
    Here is a link to Birdman's solution.
    http://www.birdmanferrari.com/service/spark_plug_article/spark_plug_wire.htm
    308 GT4/GTB/GTS Spark Plug wire replacement
    The only problem I ran in to was the back of the motor, #1 wire came up a little short. Also you will not be able to get the rubber boots back on, but I have not had mine on in over a year, and have had no issues.
  17. Paul308GTSi
    Oct 26, 2008
    979
    Paul D
    They are marked " Magnetti Marelli " " Made in Italy " there is also a B with a circle around it. No other marking visible anywhere.
  18. Paul308GTSi
    Oct 26, 2008
    979
    Paul D
    #16 Paul308GTSi, Aug 20, 2011
    Can anyone tell me what the gap between the rotor and the brass contact in the distributor cap should be please. I'm chasing a dimension for the distance between the red lines drawn onto the photo.
    I have found a considerable difference between an original cap and a replacement !
    I will measure both soon
    ............ I would just like to know what the gap SHOULD be
  19. Fairview
    Fairview Formula 3
    1,025
    Waynesboro, Virginia
    Jeff Ward
    Hi Paul,
    I measured for you. Using a used Marelli distributor cap, and a Marelli rotor, both removed from my running 78 GTS, I measured all way across from one terminal face to the other- 59.2mm. This means half the distance (from terminal face to middle of center coil terminal) is 29.6 mm.
    I then measured the rotor from the tip to the center of the wear pattern for the carbon coil contact- 29 mm.
    So, the gap between the rotor and the terminals on my 308 is .6 mm (or about .024 inches). Yours looks wider than that, doesn't it?
    Hope this helps. Jeff
  20. Tifosi100
    Tifosi100 Karting
    Sep 26, 2006
    50
    Montana
    I went through 2 set of rotors and caps at quite an expense... Had the same issues as you, even broke one rotor under full throttle, lost one bank... Was a little scary at the time! Found out after market parts are not the best quality. I bit the bullet and put on an elecronic ignition system and all ignition problems solved, car runs much better too. Wasn't cheap and wasn't the simplest task either (but not too bad really), but in my opinion is the single best upgrade for the old 308's you can do to improve driveability and reliability. My 2 cents. I've got a bunch of picture of the install somewhere if you're interested I can post them later... Good luck!!
