Buy
308 engine installation
Discussion in 'Technical Q&A' started by Gianluca, Mar 17, 2004.
  1. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    Hi,
    I am finally ready to reinstall my engine in a '81 308 GTSi and have a few questions for those who have done it before.
    1) I removed the AC compressor when I took the engine out. I believe that I can reinstall the engine with the compressor already mounted. Is this correct?
    2) I have not yet received my headers from being ceramic coated but would like to drop the engine in this Saturday. Is it possible to install the engine and then add the front headers? (maybe by lifting the engine a bit)?
    3) I have profusely oiled all the parts that were removed during reassembly. Anything special about the restart?
    4) Finally, any special suggestions and/or caveats about this job?
    Thanks,
    Gianluca
  3. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
  4. BigTex
    Rossa Subscribed Owner
    Dec 6, 2002
    76,166
    Houston, Texas
    Bubba
    Life will be easier to install front header first. I can be installed thru the right wheel well, if you remove fuel tank and tilt engine up from mounts.
    A/C may complicate drop in as well. Why not mount once engine is in???
  5. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,221
    TN
    A/C really needs to be out. I know it isn't what you want to hear but it will make it easier. You can do it with it the compressor in there but it would be too troublesome. Do you have freon in the system or is it still open?
  6. Gianluca
    May 6, 2003
    349
    Gianluca Chegai
    Thanks for all the advice.
    Right side tank is out already. Was waiting to install engine before I put it back.
    The AC compressor has been removed so is empty.
    I will install the compressor afterward.
    Since the gas tank is out of the way, could I put the headers after the engine?
  8. BigTex
    Dec 6, 2002
    76,166
    Houston, Texas
    Bubba
    Yes, I've replaced a shattered one that way.
  9. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    1) Yes.
    2) If the right tank is out, yes. The alternator might need to be out, too.
    3) Disable the fuel pump and crank the car with the spark plugs out until oil pressure shows on the gauge.
    4) Don't tighten the motor mount bolts until they're all in place. If you're cam belts covers are off when you set the motor it, don't break the lips of the cam pulleys.
  10. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    17,261
    The Cold North
    Tom
    I just dropped the motor in my car this evening. The best way to handel the front header is to put it in the engine bay first..lean it upagainst the fire wall and then lower the engine in. This way you don't have to fight with anything. Then once she all in and sitting reach up and put your gaskets on the studs, then simply push on the manifold.
    The engine can easily be installed with the alternator in place. A bit of a trick to do with the A/C on but I have done it. You need a load leveler and 3 people mind you.
