308 Engine Rebuild & CIS to TWM Throttle Bodies Conversion Thread! | Page 4 | FerrariChat
Discussion in '308/328' started by Pizzaman Chris, Sep 13, 2007.
  1. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    What's the clipboard for???
    Is that's the doctors notes on the patients condition?
    You gotta be stoked to see that thing outta the car like that. Now all those things you wanted to clean and polish but just couldn't reach are all available to ya.
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    LOL!
    No man, that's no clipboard. It's the oil cooler in a box for protection.
    Oh you no it.;)
    The only problem is, I just don't know where to start. :eek:
  3. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks Andy.
    Good friends is right.:)
    I can't Thank them enough.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    That's the way I do it as well, front up coming out and going in.
  5. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Newman, mk e,
    My understanding from reading previous engine removal posts & procedures over the years is that the front header must be removed before you can rotate the engine as you describe. To pull the front header, you have to pull one of the gas tanks.
    To rotate the engine the way we did you just have to remove the bell housing/transfer case, rear motor mounts, spacers & studs. Once they're removed, it'll come out without touching. It's a lot easier to pull the bell housing, motor mounts, etc. than it is to pull the front header with the engine in place.
    When JWise & I pulled his QV engine, we did pull the rear mounts, spacers, & studs before starting lifting, & the engine came out pretty easily.
    Problem we got into this time is I forgot that the rear motor mounts, spacers & studs had to come off. Thus we started the pull with the mounts, spacers & studs in place & got to the point where we couldn't go either up or down. Of course having one of the strap hooks up against the intake plenum was another DUH-OH that occurred at that same awkware point. I don't believe anyone there would make either of those mistakes again.
    However, if you can pull the engine by rotating towards the rear w/o pulling the front header, then those previous posts were wrong & the whole equation changes.
  6. Yamaric
    Yamaric Karting
    Apr 7, 2007
    199
    West Palm Beach, FL
    Richard Dalgleish
    cough, cough......#5, #6
    lol
  7. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Richard,
    Yes, I caught that. :)
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    When I removed the engine from my first car (77 308 GTB), I was not able to rotate it far enough either way to make any real difference. In the end I was able to slip it out in an almost level position by carefully working it around things while lifting slowly. As such, I am of the opinion that the engine should be able to removed or installed with the header, alternator and starter installed, but next time the clutch housing will be removed. My rear motor mounts did catch on things a bit, so I would probably remove them, but I dont think the studs would be an issue.
    I am contemplating pulling the motor from this second car so I can clean and detail the engine compartment, possibly swap heads, etc., I just need motivation.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Very impressive!!
    Chris -- you have email with pics
  10. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,523
    Canada
    Newman
    You can simply leave the header sitting flat on the frame rail and lift the engine out. You dont have to remove the tank to leave the header sitting there. Its easy to access too. Starter stays in, bellhousing and mounts stay on, etc....ferrari somehow puts these engines in with the a/c compressor on, which seems impossible with a regular cherry picker.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I do it the same way.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    (imported quote from SC thread)
    OK Chris, lets have it!
    I think you've been talking about a supercharge for as long as you've been on f-chat. Are you coming back to the light and staying natural aspiration or going to the extra dark side and turboing it.....or no, I can't even think iy...are you (God forbid) looking at another model ferrari?
  13. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Now now Mark, i can't let the cat out of the bag yet.;)
    Besides, i got to fix my gear box first.
    Yeah, i know. But after i pulled the motor out i started having crazy ideas. Not MarkE kind of crazy ideas.:D
    The 308 is staying.:) Just going to wake her up a bit.:D
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Don't be like that....that poor cat will suffocate if you don't let it out!
    Don't be like that either, I haven't even mentioned the supercharged v12.....I did not just say that :)
  15. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Do I hear twin turbos? Two itsy bitsy hair driers tucked down out of sight.....
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Too common for Mark....
    FOUR itsy-bitsy blowers - one for each of 3 cylinders to match the pulsing.
    The POWER of FOUR:
    Four Cams
    Four Valves
    Four Turbochargers
    Four Miles per Gallon
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    LOL.
    I was just kidding
    seriously, I was kidding
    ….........fine, don’t believe me then :)
    Now the way cool camshaft idea that just popped into my head on the other hand.......can't let the cat out of the bag just yet, but it's way, way cool :)
  18. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Nows the time for variable cam timing, might as well if you have to come up with a cam drive system anyway. Why not variable lenght runners too :)
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I hadn't thought about this...let's discuss on the v12 thread so it doesn't distract from Chris telling us about his plans here :)
  20. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    ok....
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Ok, we waited since yesterday, now can you tell us?
  22. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    OK....Chris...
    I've been lurking here and the suspense is killing me.
    Tell us your plan, man..!!!
  23. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Well, if you really want to know, this is my plans:
    Now that i have the motor out i decided to rebuilt it with 10:1 comp. pistons and do a nice valve job and switch to.................
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Welcome to the way of truth, light and goodness.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Cool!
    Don't forget early carb cams, they will make a big difference.
