308 Engine Rebuild & CIS to TWM Throttle Bodies Conversion Thread! | Page 5 | FerrariChat
Discussion in '308/328' started by Pizzaman Chris, Sep 13, 2007.
  1. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    WHOA............
    How cool is THAT gonna sound !!!
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #102 Pizzaman Chris, Nov 4, 2007
  3. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Yes, He did it because he is pure of heart, (and probably has a pernicious lust for THE SOUND and instant throttle response).
    Or maybe someone just swapped the carb set up for a pizza or 2.
    Are those manifolds stock or ported?? They look mighty smooth down in there?
    Did you get the velocity stacks too?
    Will the smog gear be taken off, so it can be carefully restored and put into a box under the bench?
    No doubt, Enzo is smiling down on this one :)
    Are you going to stay with the digiplex ignition or go to something better???
    impared minds want to know,
    chris
  4. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Chris my "Big Wheels Brother"
    Deep deep down, the kid in me, always love carbs.:) My last sports car a 72 Corvette 383 with Double pumper. OH SO SWEET!
    The carb setup cost more than a few pizzas, subs and fries.:p
    I would like to get velocity stacks.
    On ignition i would like to get the Electromotive setup. Will have to touch base with our local Carb Guru aka BIRDMAN!
    Now back to our regular scheduled program....in progress..........
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #105 Pizzaman Chris, Nov 11, 2007
  6. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #106 Pizzaman Chris, Nov 11, 2007
    Hi gang,
    Well, i got the Plenum off with no problem, and i didn't drop any washers either.:)
    But now the fun part. How do i remove the runners? I might have a few studs seized so i have been soaking them with PB Blaster.
    What should i use? Rubber hammer and a piece of wood?
  7. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    Chris, you need to get a a high work bench, or else you will have a sore back my friend.
  8. VR4
    VR4 Karting
    Apr 22, 2004
    58
    vancouver, wa
    steve
    lightly tapping them with a hammer/wood or mallet should break the bond with the head and allow you to pull them off.
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    He's got a hydraulic height control on that workbench, it can lift from about 9" high to about 4' or more high. Guess he just likes to bend over.
    Chris,
    Don't get the Electromotive XDI setup, it's intended for a track/race application & it only has a single 'map' that only has 4 points defined by the 4 switches. IMHO, it's actually a step backwards from your current Digiplex system, other than the direct fire coil packs. Again, there are individual cylinder coil-packs that make for a very clean installation.
    There are much better systems out there for less or equivalent money.
  10. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    http://www.ferrarichat.com/forum/showthread.php?t=174084
    I explained a solution to use a Haltech ECU for controlling your dizzy's . . . and later it will control your EFI should you go that route :) See my dyno numbers? 210hp/180 ft-lb at rear wheels with stock cams and high compression :) We don't need no stinkin' carb's ;)
    Sean
  11. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Hey Chris,
    I remember when you didn't tinker too much with the motor...and now look at you.
    You my friend are an inspiration and are going to have a wonderful drving machine when you are done. I guess we'll have to plan that national 308 Gathering when you are done.
    Keep up the great work.
    Henry
  12. jagjet
    jagjet Rookie
    Oct 24, 2007
    31
    Florida
    W.Robert Phelps, III
    Lads
    I found some new stuff at PRI last year call "Evopo Rust" ! Evo friendly, user friendly and works like chicken bones in Clorine tank. Enough said!
    Also they make an aluminum cleaner that turns that dull corroded bit into show, same handle only it works best at 160 f.
    PPI is annual trade show for racing industry that likes to work smarter than harder. Performance Racing Industry show Orlando, fl.
    www.Evapo-Rust.com 1-888-329-9877
    Cheers Robert
    PS can you not take the whole engine /xbox out as a unit from below? like Mondial ??
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    No. It comes out the top on a 308....barely.
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Sawzall.....
    :D
  15. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    gee'ss pizzaman....... no flys on you mate!!! ur fairly getting stuck into that rebuild..... keep them pics comin cheers
  16. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    Hit them with a pizza peel!!
  17. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Soak them in Tomato sauce or Olive oil and then tap with a rubber hammer.
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Chris,
    How about starting a engine rebuild thread rathar than having everything in a bunch of different threads...
  19. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    you guys crack me up !!!!!!!!!!!!!!!!!
  20. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    That's to expensive!!
  21. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    50/50 balsamic vinegar & garlic infused extra virgin olive oil...WAY better than PB Blaster !!! ;-)
    Its gonna take something harder than a rubber mallet to "shock" that gasket bond apart. Maybe plastic face mallet or a dead blow and a block of hardwood. Dont' go to the "maybe if I just drive a putty knife between......" place !! Might want to pull the injector nozzles out before you bust the intakes loose, they are about 3" long and extend into the intake ports.
  22. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Toss in a few strands of angel hair pasta and when you are done you get yourself dinner. Would you like some cracked pepper with that?
  23. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    I am going to pull my plenum to repaint. Are there gaskets between the plenum and runners I need to order before re-install?
    Spang
  24. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    Anywhere metal is adhered to other metal there should be some type of gasket...
  25. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Yup, Thought you'd already pulled the injectors, yank them before you go beating on it. A couple of gentle taps with that 2 lb sledge we used to separate the tranny from the block on a piece of 2x4 should break those stuck gaskets loose. If not, then more olive oil & balsamic...
    BTW, had to pull the motor mount studs to get that stuck spacer off of the tranny. Glad you'd been soaking them w/PB blaster (Or did you use oil & balsamic there too? ;)
    The tranny is mounted on the stand's mounting plate, all ready for a couple of strong backs to pick it up & slide it into the stand.
