308 Engine Rebuild & CIS to TWM Throttle Bodies Conversion Thread! | Page 77 | FerrariChat
Discussion in '308/328' started by Pizzaman Chris, Sep 13, 2007.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks gents. :)
    I'm very pleased with the way she's running.
    Here's one more going up hill.
    [ame=http://www.youtube.com/watch?v=VoOXTawzkNw]Pizzamans 308 - YouTube[/ame]
  2. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Small update.
    I did a little wiring last night.
    I ended up cutting a lot of wires to shorten the big mess of wires. Off course it was late so I didn't get a chance to see if she will start or run right. Fingers crossed.
    Now I got to think about how I'm going to mount the Tec3. One idea is to make a "L" bracket. Mounted to the trunk and the other part against the lip where the rubber gasket sits. 3rd picture.
    Not to many options. Anyone have any different ideas?
  3. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,232
    Atlanta
    Tom Spiro
    can you mount it under the carpet as the digiplex were mounted?
  4. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    The TEC unit needs to breath. Mount it where it will get the most air. Also, have you thought about running a wire back to the passenger compartment for your laptop?
  5. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Just put a couple of 1/4 20 bolts through the fender...
    It'll work! :D
    (BTW, nice wire reduction)
  6. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    It's still a little crowded in that spot. I got most of the wires tied in that spot.
    I also have that tac box in that spot.
    Paul, I was thinking of that. Not sure where to drill a hole.
  7. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    There's always a comedian.
    Thanks Rob. I can always count on you. :)
  8. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Little update.
    Here's my bracket for the Tec unit. I had my buddy do a couple mods to complete it.
    I sprayed it black to match the carpet. Theres no need for more bling.
    My initial plan was to screw it where the tail light assembly is and the other end against the wall of the trunk.
    But then I figured if it goes in tight, it ain't going anywhere. That's why I slotted ends.
    Behold, the mighty bracket......:)
  9. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Chris, i had to mount a computer cooling fan on mine and route fresh air to the coolong fan. my tec unit would over heat back there and shutdown...fyi.
    i cut a hole in the fender well (fiberglass), and routed fresh air in thru there.
  10. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Looks great Chris. For that extra area next to the Tec unit, you could place a tray to hold fuses/bulbs/relays and it won't move around during driving.
    I like the fan idea for the Tec unit (if it doesn't have a fan in it); IDK about cutting a hole in the wheel well, though (small hole with a screen very near the fan might be ok).
  11. George Vosburgh
    George Vosburgh F1 Rookie
    We are mounting the unit behind the passenger seat because of the heat problem plus dynamat on the fire wall. I hope it works.
  12. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I mounted my TEC3 behind the passenger seat 10 years ago, as per Electromotive's recommendation - no issues.
  13. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks for all the ideas guys.
    A little PC fan is on my research list.
    George, Paul what happens when the Tec overheats? Does the car just die or its doesn't run right?
  14. George Vosburgh
    I think it shuts down but I have no personal experience with it. I had one on my XKE but again it was in a cool place.
  15. Aussie
    Aussie Rookie
    Aug 18, 2009
    24
    Well, I just read 96 pages in 2 days. What an experience. Props to a pizza guy for delving into such a project on such a car. Love it.
    I noticed earlier in the thread that you replaced the velocity stacks for just a low plate. I know with carbs, that the stack legnth makes a big difference in performance. Is this still applicable to a Fuel Injected setup? Have you lost any power or torque by not using them?
  16. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks for the kind words.
    Yes, on the Fuel injected system it doesn't apply tall stacks or low plates like on a carb setup. I would love to drive around with the tall stacks and no air cleaner but ill stay conservative and keep the air cleaner on.
  17. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #1917 Pizzaman Chris, May 13, 2013
    Well boys, today was the first official day.
    After wrestling with the rear bonnet for a hour I finally got to go for a real drive. Sorry no video. I wanted to be focus on the drive.
    After a warm up i drove about 2 miles to the gas station. I noticed there was alot of pressure when i opened the gas cap.
    After a nice warm up i drove to the local gas station and got 10 gallons of the premium stuff. Then drove around for about 30 minutes. She was driving rough in first gear. And a lot of back firing when I would let off on the gas.
    So after a short drive, I went home, cut the grass, took a nap and then went for a longer drive on the highway. Couldn't really open her up, there was to much traffic. Did about 20 miles. The back firing was still there.
    The tweaking continuous......
  18. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    When did you get the backfiring - during acceleration, cruising, and/ or letting off the throttle?
  19. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    It was during acceleration in first and letting off on the gas on any gear.
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Congrats!!!
    Perhaps need to richen up your off throttle map.
  21. F1Austin
    F1Austin Karting
    Apr 29, 2012
    103
    Near Austin, Texas
    Pat Welch
    Im so Glad I have a euro w/the fiberglass bumpers.My mechanic is installing new Koni w/Carrera 375/300 springs on 47407,,had a spongey leaker on the front and a locked up on the rear.Great thread
  22. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thank you sir. :)
  23. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #1923 Pizzaman Chris, May 14, 2013
  24. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    What issue?
    Are those 550 wheels, did you have to relocate the rear shocks like Mark did?
  25. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #1925 Pizzaman Chris, May 14, 2013
    The Stebro exhaust would not line up. The small rear bend that goes to the rear header has to much bend.
