308 Engine Rebuild & CIS to TWM Throttle Bodies Conversion Thread! | Page 78 | FerrariChat
Discussion in '308/328' started by Pizzaman Chris, Sep 13, 2007.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Yep 550 wheels, no relocating of the rear shocks. I'm not that daring as Mark. :)
  2. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Chris, hook up your laptop and do some data capturing - might as well take advantage of the tools you already have. Start with monitoring the A/F, RPMS, Ignition, and the EGO, if activated. That should give you a good starting point.
  3. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    So they fit just fine, anything else needed?
  4. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    Ugh...!
  5. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    No Todd not that easy. :)
    To make them fit, the rear wheels where narrowed 1" and I have QA-1 shocks too. The fronts have spacers also.
  6. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Tell me about. I was told it was a plug n play system.
  7. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    That's why I'm talking to Wade about using an ECU with "traction control." LOL
  8. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks Paul. Will do.
  9. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    LOL
    Others have said it seemed the factory mounted the exhaust hangers where ever they were needed to line up the exhaust.
    Wade told me he only likes to take one 308 apart at a time because of the differences in spacers, shims, etc.
  10. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    See, he's got patience. Ha!
  11. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    New air/fuel gauge install.
    Don't mind the numbers I was just checking to see if it works.
    I need to get the 308 running good soon cause I'm going to a BQ next month. We don't need people pointing and talking about her back firing when we pull in. :)
  12. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Show us installed pics! And the install process!
    Isn't a deadline a great motivator?
  13. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Yes it is.
    But if I tackle this install, knowing me, I won't make the deadline. :eek:
  14. George Vosburgh
    George Vosburgh F1 Rookie
    Love those wheels Chris!
  15. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
  16. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #1941 cavallo_nero, Jul 1, 2013
    nice grab on the wideband O2 sensor and gauge. i live by mine!! and my trusty pyrometer.
    one of these days i will turn on the feedback circuit with the O2 sensor, and let the ECU figure it out..
  17. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,323
    Ventura, California
    Robert Garven
    Chris its taken you so long to get your car finished mine is in pieces again!
  18. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    John, that's a nice spot for it. I was wondering if it will fit where the clock is.
    I'm going to have to wait on that though. No more taking her apart.
    I just want to drive her for the summer. :)
  19. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    You guys know I did all this work.
    Engine out. Rebuild motor. Rebuild tranny. Took the wiring out in the rear that handled the engine management. Modified a lot out items. Soldered wires and ends. Made my own spark plugs wires. Attached crank sensor, cam sensor, map sensors. Wired throttle bodies. Had custom made parts made. Etc, etc.
    So last night I had one last detail of the puzzle to connect. The rear antenna. I was getting tired of looking at that hole.
    So I plugged it in, adjusted the antenna to be straight. Sorry, i don't like the angle look.
    Got in the car, turned the key and..............
  20. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,787
    Shreveport, LA
    AND WHAT???
  21. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I can only imagine ... I've had a piece of duct tape on the inside of that hole since I repainted my car ... remove the antennae and give that a try ... my cars been rock solid except for head gaskets :) ...
    but seriousrly ... hope u can find whatever is grinding ur gears ... simple as dead battery maybe? ... cheers
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    ......and no one has heard from Chris since he roared off into the sunset radio blaring, exhausts rumbling .
  23. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,787
    Shreveport, LA
    The battery was dead.. the "straight" antenna let all the smoke out of the wiring.. the key broke off.. you woke up and it was only a dream and Bobby is still alive???
  24. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    ....**off making popcorn**....
    And what????
  25. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Sorry guys, I got busy at work last night and forgot to reply.:eek:
    So, like I was saying, I turn the key and.....
    [ame=http://www.youtube.com/watch?v=euoyp6m1vds]Ferrari 308 - YouTube[/ame]
