308 Exhaust Leak - is this common? | FerrariChat
Discussion in 'Technical Q&A' started by GearHead, Jan 4, 2004.
  1. GearHead
    GearHead Karting
    Jan 3, 2004
    76
    A 308 that I looked at (less than 20K miles on it) seemed to have an exhaust leak on the rearward cylinder bank. Like a cracked manifold or something - the sound was coming from around that area.
    Common problem? Expensive problem?
  2. Peter
    Peter F1 Veteran
    6,431
    B.C., Canada
    Cracked manifolds happen occasionally. Poorly made to begin with.
    Expensive?
    • Yes, to replace with new. Less-so if used.
    • Not really if repaired by a welding or even a better-equiped muffler shop (headers are stainless).
    I can't remember, but I think either Tubi or Stebro (or maybe both) make stainless aftermarket replacements.
  3. Peter
    Peter F1 Veteran
    6,431
    B.C., Canada
    ...Or it could be just a bad doughnut gasket at the header/muffler flange...
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    One of my primary pipes on the rear head had a cracked weld when I bought the car. A mig welder fixed that 2 years and 15K ago, still no leaks.
  5. BigTex
    79,218
    Houston, Texas
    Bubba
    BOTH my headers failed due to distributer advance problems. Blew into lots o' pieces!
    Replacement cost was all over the map. $200 - $750.
    I've seen an add recently for custom replacements from a vendor in the UK, looks like nice work.
  6. Wayne 962
    Wayne 962 Formula Junior
    502
    What do you guys think, would an exhaust leak cause extreme backfiring when:
    - Coasting down from speed with your foot off of the throttle, and the transmission/clutch engaged
    - Backfiring (every time) when you turn off the car
    - Flub-flub-flub noises coming from the exhaust (burning exhaust gases)
    I definitely have an exhaust leak, but I'm not sure if fixing it will completely eliminate the problem?
    -Wayne
  7. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,517
    NJ
    Peter
    I had noisy exhaust with some muffled backfiring on decceleration and the problem turned out to be 2 bad hoses in the exhaust. I don't know the name of the hose (it was fixed by a shop), but I think they are used to recirculate exhaust gasses. It was an amazing difference in quieting the car. This was for a 3.2, I'm not positive that the 308 has the same setup.
  8. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    What are some of the signs of an exhaust leak or cracked manifold on a 308?
  9. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,060
    Kansas
    Sean F
    Are the air pumps hooked up on that car? If not, the leak could be blowbye at the air injectors in the exhaust. If not properly plugged, they will blow bye and cause a chirping noise.
  10. yank05
    yank05 Formula Junior
    Nov 8, 2003
    272
    New England
    Anthony
    Hi,
    I had the same symptom on my 308 . The analyzer tubes in the front manifold were rusted and leaking - made the familiar exhaust leak "ticking" noise. You can plug the holes with the proper brass plugs - not sure of the size (Ferrari UK has them I believe).
    Thanks,
    Anthony
  11. FerrariFrank1
    FerrariFrank1 F1 Rookie
    Aug 15, 2003
    3,887
    Chicago-Phoenix-L.A.
    Frank
    My '81 308,makes a kind of "Whistling" noise when I accelerate. Reminisce of an old VW Beetle. Is that the "Blow By" problem ? The car only has 18K miles.
  12. philvecc
    philvecc Formula Junior
    Nov 3, 2003
    751
    Longmeadow, MA
    Philip Vecchiarelli
    Had the same problem with my '85 308. It split right at the header flange/pipe weld on the right end. Twice, as a matter of fact. The first time we welded it back in place, but it was evident that it was under stress since it split again. So we milled the flange face flat, and took a piece of stainless tube about 1/2" wide same diameter os the pipe, split it, wrapped it around the junction leaving the gap underneath open, then welded it up and haven't had a problem in two years.
    I was quoted $1,800 for a new one.
    Good luck!
  13. pnorman
    pnorman Rookie
    Dec 30, 2003
    47
    The whistling is from the exhaust tips having lost their fiberglass packing not an exhaust leak...Patrick
  14. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    I believe I have the same problem on the rear bank also, I can smell strong exhaust fumes when I lift up the engine hood with the engine running. I am wondering how you can tell if this is leaking with the heat shrouding material all around the header? Even to repair the manifold, it looks to me like the heat shielding material needs to be removed first.
  15. flashman
    flashman Formula Junior
    483
    Star Valley, Arizona
    William Rappaport
    Patrick,
    Is there a way to fix this problem without completly replacing the exhaust tips? I also am having the same problem as red 81 308 on my 81 308 GTSi. Is this a problem common to our model?
    Thank's
    WilliamR
  16. Wayne 962
    502
    My floorjack is at the shop right now - when I bring it home, I will take some photos. Seems like these exhaust leaks appear to be a common problem on these cars, yet there didn't seem to be much in the archives about them.
    -Wayne
  17. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    You might want to check the emmissions hoses. There are " check valves " on cars with air pumps. I had a bad check valve and replaced and leak was resolved.
  18. FerrariFrank1
    Aug 15, 2003
    3,887
    Frank
    Thanks Much! I appreciate that! Guess I may be installing a Tubi sooner than when my 30K is due.:) Thanks again!
  19. Wayne 962
    502
    Where are these located, and how do you check them.
    (I'm up to my elbows in four cars that are having problems right now - Pathfinder (smog), 2 BMWs (smog) and the Ferrari.)...
    -Wayne
  20. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,153
    Kingsport, TN
    Lawrence A. Coppari
    My 328 developed an exhaust leak at a check valve that lets in outside air to heat the cats faster. There is one for each bank on a 328. When they corrode out, it sounds like an exhaust leak. But I don't know if a 308 has them. They are GM parts.
  21. Steve Magnusson
    25,138
    Wayne -- With regard to: "Where are these located, and how do you check them.", your F OM should have a decent illustration showing their location(s).
    With regard to checking their function, the first thing to do is make sure they haven't just generally disintegrated ;), but, if you remove the flexible air supply line from them, no exhaust should come out backward with the engine running.
  22. Wayne 962
    502
    When I get done working on my truck, I will jack up the 308 and take a long, hard look at what's in there (I'll take pics too). It sounds like there may be numerous places for an exhaust leak to occur...
    -Wayne
  23. Glassman
    Glassman F1 World Champ
    As posted above, chech the air pump maifold rail first. The one on my car at the back of the engine had a hole in it. The front for some reason is perfect. These are very tin tubing and with the air pump disconnected the corrosive gasses come thru it and eat it all to hell.
  24. flashman
    483
    William Rappaport
    I just went through my exhaust system and found out what was making the noise. I have a small (1/2") crack in the rear exhaust collector. Can this be patched or does it have to come off the car to be welded?
  25. SR Ferrari
    SR Ferrari Rookie
    Dec 1, 2003
    48
    Gear head 90% of exhaust leaks are at the CO correction tubes where They go into the manifold they just rot off take a close look if you can to see the condition of the front tubes if the fronts look bad then restasure the rear ones are the same/
    look for missing manifold nuts also.
    Perry Solamens 85 308QV has be the best car at Montery for the last couple of years I simply had the oportunity to have the manifolds out of the car and we removed the tubes and closed the ports with a clean healiarc welds as per Perrys request.
    This may not be the answer for you but if this is the case the manifolds need to be out of the car either way.
    Kind Regards
    Wayne Hynes.
