308 F.I. plastic lines to injectors - Weak design? | Page 5 | FerrariChat
Discussion in 'Technical Q&A' started by dave80gtsi, Mar 31, 2004.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,491
    Dumpster Fire #31
    SMG
    the lengths vary depending on where the the hard line was placed in the bay. the 328 is one of the shortest runs I've seen and the Mondials the longest, by at least twice the length (supply return lines). the frequency valve also uses the 8mm.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    The kit has 2 meters of 8mm line. That s/b enough to cover all applications, but I don't have a Mondial to measure. If it needs more than 2m, I'll bring out a Mondial specific kit.
  4. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
  5. DMaury
    DMaury Formula 3
    Mar 27, 2007
    1,993
    Ponchatoula, LA
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    While searching for something else, I came across this interesting article abstract by a Volvo engineer & research scientist:
    While they were using a high %Ethanol for the research, I suspect it doesn't bode well for long-term use with lower percentages.
  7. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,471
    Hello, any idea where I can order the Cohline 5mm and 6mm ID 2mm polyamide fuel hoses?
    Sent from my MAR-LX1M using Tapatalk
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    2,400
    Lyon (FR)
    R. Emin
    Unobtainium supply OR Cohpro UK
