News
For Sale 308 F106 A E * 00767 Engine
Discussion in 'Ferrari Parts & Collectibles' started by guygowrie, Jul 14, 2019.
  1. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    308 F106 A E * 00767 Engine - $8500 with local pickup Tenafly NJ.
    this engine left the factory in a 1978 308 GTS - carbed 2v engine.
    Used for a few years in my 308 GT4 and removed to install the original Gt4 engine. My Gt4 is now sold and I'm now selling this engine.The engine was running great when pulled and only pulled to reinstall the original motor in my Gt4.
    I did the belts two winters ago. It has Hill engineering tensioners. It has a Forza waterpump that I installed (almost $800) that is much sturdier and seems even after a decade they don't fail or need rebuilding.
    I've set it up with Electromotive electronic ignition. ie crank fired. The complete system can be included for an extra $500 (cost over $2k as I recall). Great system.
    Otherwise, totally reversible to dizzies.
    Included in $8500:
    complete engine and carbs as pictured with Starter and alternator.
    front and rear headers in VGC (one has the insulation still intact)
    a/c pump and mounts.
    3 heatshields
    1 distributor, 3 distributor caps, small boxs of extra
    The car is located at Auto Elite in NJ which would be a good place to transplant the engine if you need. Great engine to revive a 2v 308 without going the full blown rebuild.
    This is some history on where this engine came from:
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/323318-my-first-ferrari.html
    Casey, the guy I bought it from confirmed. See further photos below showing he had the heads off (good news in itself)
    Exhaust valves 5-8
    Valve stem seals
    Clear coolant passages of crud
    Head and cam cover gaskets
    Cam seals
    Hill tensioner bearings
    No bottom end
    Expect to require some fasteners or fittings although I will go through with Vinny to make sure most are there.
    At $8500 this is asking less than the sum of its parts and was a very reliablle and well running engine while in my Gt4.
    pm me or email me at guygowrie@hotmail.com
    Thanks!
  2. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
  3. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
  4. DonB
    DonB Formula Junior
    326
    Florida
    Don Bartz
  5. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    Hi Don
    Ofcourse it could although I dont have any experience doing so. Looks like there are some pallet/box combinations that can be purchased for a few hundred.
    And I have no idea of what it would cost to ship it say to Florida (again, no personal experience in shipping items of this size. there are some online websites that promise quotes but I think are just generating leads.
    Guy
  6. 19633500GT
    19633500GT F1 Veteran
    Silver Subscribed Rossa Subscribed
    Nov 9, 2010
    6,995
    Unapologetically
    American
    Don, I just used YRC Freight for a heavy item, and they were excellent. It was 400lbs+ and cost about $500 to ship from CT to Illinois.
    If Guy has the dimensions, weight (general) and specifics (ie. full engine), then use this info and they should be able to generate a quote, pick up time and etc.
    I bet the shop in NJ could at least get it palletized and shrink wrapped for prep to be picked up.
    This is a LOT of engine for cheap. Wish I had the coin myself
    guygowrie likes this.
  7. Vonbarron
    Vonbarron Formula Junior
    Rossa Subscribed Owner
    Aug 26, 2014
    818
    Sammamish Washington
    S Barron
    How long after payment could I leave engine in NJ?
  8. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    Without asking him I think if I get it packed and palleted Vinny would be flexible - few weeks no problem, a month or two possibly also ok.
  9. Vonbarron
    Aug 26, 2014
    818
    S Barron
    Sent you an email
  10. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    replied thanks!
    I dug up some info I sent to a buyer a when I was looking to sell the car with this engine in it:
    "I had a ppi done at Vantage Motorsport 15th May which gave the following compression test figures. Oil and filter also changed then. Belts done last winter.
    Compression test figures:
    Front bank facing passengers l to r: 210 - 200 - 200 - 185
    Rear bank facing rear trunk l to r: 180 - 175 - 180 - 180"
  11. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    sale pending!
  12. BigTex
    Dec 6, 2002
    72,965
    Houston, Texas
    Bubba
    That's one steal of a deal......GLWS!
  13. guygowrie
    guygowrie Formula 3
    1,388
    ct
    guy s
    It needs to move on and power another Ferrari!!
    BigTex and 19633500GT like this.
