Need help getting ready to replace my fuel pump hose on my fuel injected 1982 308. Does the hose need to be for fuel injected high pleasure or can i use a stranded fuel hose? What are you guys using Thanks Image Unavailable, Please Login
That's the low pressure hose to the pump inlet, but the trick is either cutting it to the perfect length so it doesn't "kink" where you have the arrow head placed (yours is presently good in this regard), or there is a special metal wire brace that holds the hose in an arc to prevent kinking.
Image Unavailable, Please Login Scuderia Rampante (Dave Helms) in Colorado sells a complete tank crossover, filler neck and fuel pump hose kit, although a bit expensive, They’re good for life? Lots of us here have purchased these kits. IIRC around $300
Thanks for the suggestions ont the hoses guys. I got it fixed and now car is running now i need to fine tune the car
