308 fuel tank | FerrariChat
308 fuel tank
Discussion in 'Technical Q&A' started by ria, Nov 29, 2003.
  1. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    can anybody tell me what is the best way to drain out the fuel tanks i need to get the old fuel out any INFO on this. thanks.
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    line from the fuel pump?
  3. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,794
    LA
    Frank
    I believe there is a drain plug in the pipe that connects the 2 tanks
  4. Steve Magnusson
    24,941
    Guys -- Combine those two recommendations with "run most of it thru the engine if possible" (although if by "old" you mean "stale/bad" then you wouldn't do that). You don't want to try draining any more than the absolute minimum out of the crossover pipe plug (it's too messy/fast), so take the bulk out the smaller line going from the LH tank outlet to the fuel filter (then open the drain plug -- and clean up the mess;)).
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    If the 'reserve' indicator light isn't lit, then start by siphoning it out of the filler neck into a container. I used a cheap siphon with a hand squeeze system to get it started. Paid $5 or so at an auto parts store.
    Once you've siphoned it down as far as you can, then resort to the other suggestions.
    When I changed my fuel accumulator, I drove it down until the reserve light was flickering. Siphoned it down until the light was on quite steady, then pulled the plug from the crossover pipe.
    Good thing I was using a large oil drain funnel into a 5-gal can. It came out in a seriouus flooding gush!!! Filled the 5-gal container to within 1/4" of the top!
    I was expecting it to dump much faster than draining oil, but was still surprised at how fast it came out.
  6. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i think i will do the siphon first and then pulle the plug it makes sence to me. i want to thank all of you for the info.
  7. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I disconnected the output line from the fuel pump. Ran the pump into a couple of 5 gallon gas cans. 20 mins. Drain last bit from cross over pipe as others have suggested - its messy (takes a new crush washer). Also, suggest you look at the quality of the hoses while you are at it -- I replaced all of mine.
    HTH
