News
308 gas fills slow
Discussion in 'Technical Q&A' started by luckydynes, Sep 28, 2005.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Hey all,
    This has been annoying me for years . . . my 308 takes gas real slow during fill ups . . . is it:
    1. The unleaded "flap"
    2. A blockage in the venting
    If no one else has problems with the stock "flap", I'm guessing it's somthing to do with the venting/check valves/charcoal canister. I've got the psgr gas tank out right now so it's a good time for me to look at it.
    Thanks,
    Sean
  3. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    you must have a problem with the venting. My 308 fills up just fine. Check the hose between the 2 tanks, if that is pinched it would cause the tank to fill slower.
  4. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Thanks for the reply . . . can't wait to be able to fill the car without holding the nozzle on "slow" the whole time!!!!
    Sean
  5. Chiaroman
    Chiaroman Formula 3
    1,596
    New Jersey
    Always was a little slow to fill and if I insert the nozzle and click the fill device to full speed it will "click" and shut off.
    Must stand there and slowly fill.
    Any other spot to check besides the hose between the tanks?
    Tom
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,000
    Groton, MA
    Verell Boaen
    My Euro 308 doesn't have the unleaded flap/nozzle fitting plate.
    It fills fast for most of a fill up. However, at stations with newer pumps, the saddle tank being directly fills seems to get ahead of gas flowing over to the other tank. If I stop & wait half a minuite for things to equalize, I can usually complete the fill-up at full feed.
    With older pumps, I can fill up at max. flow.
  8. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,249
    Colorado
    Dave
    The pre-unleaded carb cars fill quick, but after that, they are all slow as are 328's.
    Dave
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,000
    Groton, MA
    Verell Boaen
    Umm, my car's a '82 Euro GTS QV...
  10. spike308
    spike308 F1 Rookie
    4,008
    Austin TX!
    Mike Z
    Mine is slow too.... but if a pinch was the case, wouldnt you not be able to fill the tank completely?
  11. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,134
    Austin, TX USA
    Greg
    I think he's talking about the vent hose between the tanks....
    Greg
  13. hardtop
    Jan 31, 2002
    11,249
    Colorado
    Dave
    The Euros have wide mouths because they don't have cats and do not require unleaded.
    Dave
  14. PT 328
    PT 328 F1 Rookie
    3,438
    My 328 fills slowly at all gas staions except chevron. At chevron it fills as quickly as it seems to go when i step on the gas pedal.
  15. Dr Tommy Cosgrove
    Rossa Subscribed Owner
    May 4, 2001
    31,369
    Birmingham, AL
    Tommy
    Mine does this too. Always has.
  16. pete04222
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    I don't mean pinched shut, I mean pinched smaller. A little kink perhaps? All the gas goes into the left tank, then flows through a hose to the right tank. If the hose is restricted, you have to wait for the tanks to equalize before you put more gas in.
    Like I said, my car fills up just fine.
  17. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Okay, so it sounds like some with the flap do not have this problem . . .
    The gas pumps in CA might be more sensitive with the "fume catching" device that's on the end of the pump . . . maybe that's the reason you guys with the flap that aren't having problems don't have the "sophisticated" emissions lowering fuel pumps where you're at?
    At some stations I have to turn the handle upside down to get it to take fuel even slowly, but one or two stations it has taken fuel normally (that's in the last 10 years). I guess if I can't find anything wrong with the venting/charcoal canister, I might consider modifying the "flap".
    Sean
  18. bill308
    bill308 Formula 3
    1,082
    Windsor, CT
    Bill Sebestyen
    I have this same problem with my 78 GTS. I replaced all the hoses 2 years ago, there are no kinks, anywhere. The problem occurs even with low tanks. I don't have a solution but wish I did. There is a restrictor plate in the filler neck. I wonder if the filler hole was opened up if this would cure the problem?
    Bill
  19. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    81 gtsi; never had a problem with filling tank - jon s.
  20. ria
    ria Formula Junior
    Nov 2, 2003
    725
    ohio
    phill
    80 308gtsi slow fill on my car.
  21. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    '81 GTSi, all new hoses, slow fill.
  22. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    interesting situation. not seen it on mine, have to keep tabs...
  23. Steve Magnusson
    Steve Magnusson F1 World Champ
    19,940
    Texas
    Like Sean, I found on my ex-308 was that if I rotated the filling nozzle assembly upside-down from the "conventional" position it would accept a faster flow rate without shutting off prematurely (although I still wouldn't go full blast, and you should NEVER leave the filling nozzle unattended IMO).
  24. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    my 80 gtsi ( no flap) is the same, slow fill, always clicking off, but by pulling out the nozzlel out a few inches from a fully inserted position lets it fill up at a normal rate.
