308 GT4 Bottom end, might as well project | Page 3 | FerrariChat
Discussion in '308/328' started by sinbad, Nov 1, 2011.
  1. sinbad
    sinbad Rookie
    Nov 1, 2009
    44
    Venice Beach
    Thank You! I kept all the parts in the separate plastic container for each side. But even if you mix things up the bolts and nuts can only go in their respective places. Plus I took bunch of pictures just to make sure I put everything in the right place. Definitely keeping everything marked and separated is a must.
    I actually finished everything. It took me 7 weeks. Five weeks of 5 hours a day, and the last two weeks, which I took off work, was 10 hours a day. So total around 300 hours. Finished on December 15th, alinement shop on the 16th, took it on a nice cruse around Palas Verdes on the 17th, and on the 19th started the interior, which I will be posting as well. Now I am posting the project part by part from the beginning to the end. This way you get to see the work all the way trough.
  2. sinbad
    sinbad Rookie
    Nov 1, 2009
    44
    Venice Beach
    Thank You my friend! It's great to be part of this family.
  3. sinbad
    sinbad Rookie
    Nov 1, 2009
    44
    Venice Beach
    Chris, that is a great tip. I tightened the arms at the same angle as if the car was on the ground to make sure that the bushings are not twisted. At first when I tightened them I noticed the arms became stiff and had minimal movement in both directions. So I retightened them at an angle that they would be as if the car is on the ground. Thanks again!
  4. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    http://www.ferrarichat.com/forum/showpost.php?p=141075349&postcount=43
    When you clean parts on a wire wheel (or any rotary-type machine) does the metal need to be treated?
    Or are they non-ferrous?
    I think the rule is: if a magnet sticks to it, then it needs some kind of protective coating.
    I would like to clean parts as they come off in hopes that, eventually, I may have more clean parts then dirty/aged parts.
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Chances are you brushed through the protective coating with a wire wheel if the part is steel. So yes, you should have it treated. Paint or POR15 work but not as nice as having them re-zinc coated.
