308 GT4 Dino front lower wishbone removal | FerrariChat
Discussion in '308/328' started by miahshodan, Jun 9, 2025.
  1. miahshodan
    miahshodan Karting
    Feb 25, 2016
    94
    West Jordan, UT
    I have my Dino up on the lift today and I know I need to replace all of the bushings, but as I look at the front lower wishbone, I can't figure out how you would get it off. The nut is on the inside and the bolt is on the outside and it doesn't seem like there is enough room to pull the bolt out. Do you have to cut it off?
  2. Dockboy
    Dockboy Formula Junior
    589
    Maryland
    You will need to unbolt the fork.
  3. GT4andMore
    GT4andMore Karting
    Oct 23, 2020
    66
    Graham
    All the lower wishbones are on forks which are shimmed to enable the suspension geometry to be adjusted. These are relatively easy to remove as they have a very large and accessible nut on the inside of the chassis. The challenge starts with the upper wishbones. Good luck - keep us posted.
  4. miahshodan
    miahshodan Karting
    Feb 25, 2016
    94
    West Jordan, UT
    thanks, to get to that nut do you have to remove the under-tray and go from below, or are you going in from on top of the wishbone?
  5. GT4andMore
    GT4andMore Karting
    Oct 23, 2020
    66
    Graham
    You need to remove the undertray and then it will all very straightforward.
    miahshodan likes this.
