308 gt4 European Bumper | Page 3 | FerrariChat
Discussion in '308/328' started by The Kook Abides, May 8, 2011.
  1. Nino1964
    Nino1964 Formula Junior
    289
    North Georgia
    I used Fiat Spider bumper struts from old parts that I had from my Fiat spider ( I saved original struts so that I could reinstall if needed). Fiat bumper struts should be easily found at a reasonable price.All Fiat spider bumper struts are the same from 1975 to 1985. Fiat produced over 200k of these cars. I first drilled and drained all the hyd fluid from the stunts and then used an angle grinder to cut off the last 1 where I had measured where I wanted the bumper to sit. Then I drilled holes to match where bolts would secure in brackets. I also had to enlarge the mounting brackets of the struts to accommodate bumper studs. I then mounted the struts and and then the bumpers.
    modificator likes this.
  2. absostone
    absostone F1 Veteran
    9,281
  3. Erol
    Erol Karting
    Sep 1, 2020
    136
    New York, USA
    Erol
    Hi Al
    Any chance you still have parts available for the front bumper? I did the back already but the front seems tricky because of the turn signals. Housing is too deep and seems it would prevent me from pushing the bumper in as far as in your pictures.
    Here’s my back bumper. Feel like that’s as far as it will go...
    thanks!
