308 gt4 tubi install
Discussion in '308/328' started by PeteyDaddy, Jun 18, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. PeteyDaddy
    PeteyDaddy Rookie
    May 25, 2017
    28
    Anyone have issues with the drivers side connection matching up? It's like the header is pushed forward about an inch and I can't get the flange to marry up...i dont want to pull the header out as im worried ill damage something..driving me nuts![​IMG]
    Sent from my SM-G955U using Tapatalk
  2. GordonC
    GordonC F1 Rookie
    Rossa Subscribed Owner
    Aug 28, 2005
    3,291
    Calgary, AB, Canada
    Gordon
    If this is a no-cats system, you have the headers on the engine, a connector pipe between each header and the exhaust, and then the Tubi exhaust. Often to get everything to line up properly, you need to loosen both ends of the connector pipes (the header ends and the exhaust ends), then you can make slight, small adjustments to angle and position on the connector pipes which result in larger shifts at the exhaust tips!
  3. Dom
    Dom F1 Veteran
    Nov 5, 2002
    6,948
    Southern California
    Dom V.
    I had an issue a few years ago. Would not fit. I posted a thread about it, if you search you can find it. Tubi was not helpful at all. Returned the tubi, and wound up getting a Nouvolari exhaust. Glen at Nouvolari was super helpful, and the exhaust sounds great. I would recommend them, as they have the correct setup for the GT4.
    Edit: Here are the threads:
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/370296-no-tubi-me.html
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/379424-my-new-nouvalari-exhaust.html
  4. Nino1964
    Nino1964 Karting
    Aug 14, 2015
    78
    Has anyone consider cutting the lower panelbelow the aft bumper on USA model GT4's to rid the muffler panel cover? And get the euro look with exposed muffler look.
  5. PeteyDaddy
    PeteyDaddy Rookie
    May 25, 2017
    28
    Thanks for the help guys. Appreciate it.
