308 GTSi Suspension Rebuild
Discussion in 'Technical Q&A' started by seschroeder, Jan 1, 2004.
  1. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Well, I've started my winter suspension "rebuild" project. New Koni shocks, ES bushings snd a complete cleaning/repainting of the parts. I'm still undecided about the ball joints as the current ones seem tight yet I hate to go this far without doing the job correctly. I'm also considering "upgrading" the road springs to slightly stiffer/lower ones. Does anyone have a good source for these? I would also like to replace the current roll bar link bushings with something firmer. The car isn't raced, only street driven. Suggestions?
    As always. thanks i
  3. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Hey Steve, I'm doing the same this winter.
    As far as stiffer/lower springs for the stock Konis,
    the choices are rather limited.
    Off the top of my head, I think I remember that superformance in the UK has some.
    The spring selection gets better if you go to an aftermarket shock to replace the stock Koni with as I did.
  4. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,482
    Somewhere in NC
    Greg
    I'm doing mine this Feb/March. With all of the bushings, tie rods, ball joints, new shocks, etc...the tab should be ~ $1800.00. I was going to have Nicks and Superformance price the parts list.
    Where have you purchased your parts from?
  5. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    I purchased the Konis from the Tire Rack, bushings from Nick, and the rest from Ferrari UK. I suspect your $1,800.00 estimate is going to be very close.
  6. Bob308GTS
    Bob308GTS Formula 3
    Sep 26, 2001
    1,147
    Aurora,IL
    Bob Campen
    I'm doing the same on my 79 308, total in parts right at $2200, most parts from Ferrari UK, shocks from tirerack some rear outer bushing parts from McCann and ES bushings for all the inners and swaybars
  8. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Seems to be "Suspension" season for us 308'ers.
  9. Bob Downing
    Bob Downing Karting
    Nov 7, 2003
    62
    BobD
    Hypercoil will sell you springs. http://www.hypercoils.com They supply CART and IRL cars also. Call them. I recall they can sell normal springs, lowering springs, race springs. etc. And I believe they are fairly reasonable @ 180$ per spring.
  10. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi
    I did the suspension etc. on my 308GT4 last winter. Photos at http://dino308gt4.com. I also had the calipers rebuilt, all parts replated to correct colours, new brake hoses, new rear hub bearings, replaced cv joint boots and grease (VERY messy job but worth it to know there are o problems in that area).
    Superformance shock bushings are a bit different from the originals. They seem to work fine however.
  11. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    I just finished the rear hubs, front and rear a-arm bushings and am now rebuilding the 4 brake calipers. I have 1 rear caliper to go then I'm finished with all 4 corners. I haven't decided what I'm going to do with the shocks. Koni's or change to adjustable aluminum?
    I now have a digital camera (finally) and as soon as I learn how to post photos I will post some of what I've done already. (Any help here?)
    As far as ordering parts, I went to Superformance, Rutlands and my local Ferrari dealer. So far my vote is for Rutlands. Superformance is good but with the shipping and duty costs I could have and would have gladly bought the stuff from someone closer and still might have been less then Superformance.
    Have'n fun!
  13. Jet Lag
    Jet Lag Karting
    Dec 6, 2003
    173
    Seattle
    Robert Bangs
    #10 Jet Lag, Jan 3, 2004
    I am also going to rebuild my suspension this winter. I did a repair last year (see picture) This year I want to do it right, and your posts sure help… thanks to all! ..
    Gerritv: great series of pictures!
  14. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    17,842
    The Cold North
    Tom
    hey Jet...Thats a recall problem. Take your car to the dealer!!
  15. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    Please give more info on this recall, years/models ?
    thanks tbakowsky
  16. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Steve
    I re-did shocks, bushings etc last winter and have played around quite a bit with settings at the track. I put on an adjustable ARB (rear) last year and have a 22mm front being built. Each of these was $225 - 250 including end links (source: Saner Performance Fabrication).
    I have also just bought a set of springs from Phil Warburton (at QV London). He makes a 20% stiffer, slightly shorter spring for 160 pounds sterling (about $280) for a set of 4. They are in shipment so will advise any issues when I put them on.
    HTH
    Philip
  17. Verell
    Verell F1 Veteran
    May 5, 2001
    7,013
    Groton, MA
    Verell Boaen
    A member asked me the following questions. Guess he's feeling a bit shy. However, since the answers are relevant to this thread, I'm responding here.
    Anyone have the rear suspension Baum tool they'd loan/rent to a fellow member? If so, send me eMAIL & I'll fwd it to the asker.
    Haven't gotten into them, but I'm, reasonably sure they're re-packable.
    I use Valvoline's DuraBlend synthetic moly fortified grease for both wheel bearings & the half-shaft CV bearings. The critical element is the moly which Ferrari WSMs specify.
    Almost any modern moly based synthetic grease rated for CV joint applications should be fine. Modern synthetic greases have 25 years of FWD CV joint reliability driven technology advances over the fairly crude dino greases of the early '70s that were available when the 308 was designed. Moly was just coming into general use back then. Another good one is the Mobil 1 synthetic grease.
    The hallf-shafts are completely separated from the wheel bearings as you'll see when you pull things apart. BTW, the half-shafts have funny washer like balancing weights that span across pairs of the bolts. Be sure to note/mark where each comes off.
    Be very careful handling the half-shafts. The bearings are relatively fragile & can be damaged by letting the weight of the shaft plus 1 end drop suddenly, thus taking the supporting bearing to it's travel limits. The WSM warns against this.
  18. seschroeder
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Well, so far so good. The front suspension came apart nicely without any problems or surprises. I'm take the parts to be cleaned and power-coated. Haven't had much luck finding a "rebuild" kit, that actually has ALL the pieces, for the front calipers. This weekend the front wheel wells will be cleaned and paint. The whole thing should go back together nicely. I've decided to stick with shock springs and roll-bars as the vehicle is never raced or auto-crossed.
    Thanks to all for the advice and help to date.
    Steve Schroeder
