Buy
308 GTSi wine
Discussion in 'Technical Q&A' started by Cooly0, Mar 12, 2004.
  1. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    I recently just joined the club and changed my oil at my home. Two nights later I am driving up here in wisconsin and it's in about 20's - 30's and at around 3-4.5 RPMs I here a odd wine. It increases as I accelerate. It is not around if I stay at a steady speed. It does not wine when I rev the engine and does not start until at least in 2/3 rd gear. My obvious guess is that it is the transmission. It is a '80. Could any body inform me as to what and why the sound is being created. Thanks for the info
  3. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,375
    Sounds like a belt or bearing. You might be able to narrow it down with a mechanics stethescope...
    Btw, it is "whine", not "wine". Wine we drink, Whine is what I do... :)
  4. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    oops, :) It wasnt the same sound. I was first thinking belt too but is wasnt really that close to what I heard when my Alternator belt went; and hten comes the question of the why only in 2nd and above, and cant remember if it's in 6th or not. It would make a sound in first as well, and that's when it would be the worst because it would be slipping the most to the higher acceleration.
  5. PeterS
    PeterS Four Time F1 World Champ
    41,191
    95370
    PeterS
    Are you SURE you emptied engine oil and not the gearbox? Don't laugh, it's been done! The sound my be from a dry gearbox.
  6. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    Yea, I'm sure, I am about to check the transmission lube and end up having to jack the thing up again and change that too.
  8. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    I wasn't aware that a 308 GTSi had a six speed box. My 82 is only five.
  9. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    I meant by 2nd and higher gears. :)
  10. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    New Update: Also When I am driving and I am slowing down in 2nd, it works it's way out and Jumps OUT of Gear! The noise is most prevalent in 4th
  11. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    hmm..... Im starting to get a bad feeling I was a moron and did drain the trans fluid, I was thinking when I thought I changed my oil and thought that It was taking a little less than I thought.
  13. wax
    wax Four Time F1 World Champ
    Advising Moderator
    Jul 20, 2003
    46,478
    SFPD
    Dirty Harry
    If so, you certainly won't do that again. As peters said - it wouldn't be the first time someone's done this. Good luck.
  14. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    Now the question is, How do I get the Transmission oil in there, I remember it being very hard, and in the work shop manual it does not say how
  15. PeterS
    41,191
    95370
    PeterS
    Cool..I think you F#@ked up bad. Popping out of gear is not good. I will send you a side email.
  16. f355spider
    May 29, 2001
    17,375
  17. Tennlee
    Tennlee Formula Junior
    Feb 10, 2002
    645
    Great Smoky Mountains
    Here's from the Ferrari shop manual. It says that if there is whining while accelerating, to top off oil. It says nothing about a remedy if no oil. I think I'd have a pro look at it. It could be an expensive mistake. :(
  18. PeterS
    41,191
    95370
    PeterS
    If it is doing what you said, it's probably too late to add fluid. I sent you an IM with my Ph #. You should call me.
  19. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    I was Lucky.
  20. PeterS
    41,191
    95370
    PeterS
    CoolyO..It was nice to talk to you last evening. From your post, it sounds that you have have caught things in time. Keep a close ear out for grinding sounds in the near furtue. You may not want to take any long trips for 200-400 miles.
  21. Ricambi America
    Sponsor Owner
    Can somebody provide an update on this situation? I've been wondering about this poor gentleman's problem for the last 24 hours. Was it indeed the gearbox that drained?
    -Daniel
  22. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    Yes, gear box had been drained, but caught things just in time
  23. f355spider
    May 29, 2001
    17,375
    Did you overfill the engine then?
  24. GearHead
    GearHead Karting
    Jan 3, 2004
    76
    And people wonder why cars with service records from reputable shops command such a premium!
    If your car was whining and popping out of gear . . . well, let's just say I don't want to be the next buyer . . .
  25. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    Thanks for the helpful comment
  26. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,221
    TN
    That pisses me off. I do all of mine own work on all of my 308s and my 348. What the hell. I do very good work. I have helped many others with their cars even on this site and you are going to tell me my car is worth less because I do my own work and some guy just because he works for a dealership and services the car makes it worth more? That is stupid. One of my cars was completely dealer serviced and I saw some cut corners but I will say it was worse with another car that was an indep. service shop.
    Come on. This shop was auth. service but wasn't a dealership and put in just the top of the thermostat on a 308 thinking that coolant flow would still go through the rad. This was what many consider a reputable shop. Not meaning to start an arguement but I work on my own cars very hard and that kind of attitude just pisses me off. My favorite is that your in the Tech. Section. Why even bother coming in this section if you only prefer over priced dealer service. Go get screwed and have substandard work performed. Needed to vent.
