308 GTSi | FerrariChat
308 GTSi
Discussion in 'Technical Q&A' started by Cooly0, Mar 8, 2004.
  1. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    I am just curious Where abouts do I adjust the advance on my 308 GTSi.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,899
    The twilight zone
    The Butcher
    You don't.
    The ignition is solid state. Each distributor has it's own drive box the reads a crank signal and vacuum, then sets the timing to the programmed value. So to crange it, you need to install a new ignition system that can be adjusted. Electromtive makes one that is a multi-coil waste spark system. Also a haltech EFI computer can read the OEM crank signal and fire either your stock distributors or multiple coils the same as electromotive, but requires you to buy the coils and module separately. Another option is to install a mechanical distributor, but personally I perfer the electronic options
