News
308 Hard Brakelines
Discussion in 'Technical Q&A' started by lou staller, Sep 22, 2004.
  1. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    What is the ID for the hard brake lines on a 308 QV? I'm not asking about the rubber or replacement s/s lines but the hard lines that run through the chassis tubes and along the chassis rails. Does any one know if they can be replaced with standard US mild steel/stainless steel lines? If so what ID?
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    It's metric bubble flare. Comes in multiple lengths. No big deal to change. Remember paint doesn't like brake fluid.
    Philip
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Not sure of ID, but it's ordered in 10m rolls and is 3/16" OD steel as std. The QV has a plastic coating on it's line but I've never found a supplier for that. In AUS, we have to use steel. But in UK "Cuniper" is really good...it's an alloy of copper and tin I think. Not sure of US regs for brake lines..
    The nuts are M10x1
  5. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    Thanks for the input guys. I just returned from Napa with a 25' roll of 3/16 mild steel brake line. So, this weekend looks like a cut, bend and flare event!
    pma1010: My car is apart sitting on a dolly in primer so access is not going to be a problem. And with the old lines already out it's as simple as slipping in the new lines. But thanks for the warning about paint not liking brake fluid. I don't like brake fluid either!
