News
308 Help, Battery Short Issue?
Discussion in 'Technical Q&A' started by Cooly0, Sep 23, 2006.
  1. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    I have 308 GTSi. I think I may have plug the battery in the wrong way for under 10 seconds with ignition on. I did correct it and install it the right way, I have 2 black cables. I can now see which is the ground/negative.
    I installed it, and was able to go into the cable and re turn on the igition and turned over, but did not start it(No gas in tank). Upon getting out of the car right away I saw smoke coming from under the deck (closest to the cabin). I ran immediatly to unhook the battery, I rechecked the ground it was correct. I havent connected the battery again.
    If I attempt to connect it I get a large spark, took and mulimeter and light bulb to it. It appears I have a short from the battery wire. I cant see where. I can assume it's the Regulater which is attached to the alternator.
    Could this be the piece that was smoking? Could this be what is actually giving me the short ? Any help would be greatly appreciated.
  3. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    yeah, you run a huge amount of current through the diodes in the alternator, which usually burns them up, then they conduct in both directions so fixing the battery orientation still causes big current draws.
    you'll need to yank the alternator and replace the diodes (or let a rebuild shop replace them). The voltage regulator may have survived, though a shop normally replaces it anyway as part of a rebuild.
    the good news is that it's unlikely you've done any damage to other stuff in the car (like the digiplexes)
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    6,991
    Northern California
    Greg Calo
    Get rid of the two black cables as well ASAP!
    Get that "+" cable in red today!
    With the ignition having been on, you might have done other damage as well such as dash instruments!
  5. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    As an addition, I did notice when I went to turn over engine, The lights came on then, went out, I think that's burned out, I hopes that the one fuse I saw burned.
  6. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,239
    Mount Isa, Australia
    Pap
    The terminal post are a different diameter on your battery on the + and - post.
    How did you get them mixed up? Did you bash them on?
  8. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    No both were loose
  9. Cooly0
    Cooly0 Karting
    Nov 2, 2003
    129
    Milford
    Jozy
    Ok, with The Alternator out, it no longer has the short it seems. However when the ignition is on with the battery the lights light up then the dash light fuse blow's.
    Is there a good electrical diagram anywhere, any Idea where the short with the lights could be?
