308 - Oil Pressure & Temperature Problems | FerrariChat
Discussion in 'Technical Q&A' started by Bianco, Oct 9, 2004.
  1. Bianco
    Bianco Formula Junior
    Dec 29, 2003
    309
    Las Vegas
    Jeff
    My '82 308 GTBi has no problems when on the street even when driven hard, but it's a different story on the track. Even though the oil resevoir is full, on very tight right-hand turns taken very hard the oil pressure will momentarily drop to zero.
    The 308 is not a dry sump resevoir of course, but rather than do that type of modification, I've heard that a 328 oilpan has a better baffle system that will prevent my problem. Can anyone confirm that and if so, know where I might have a reasonable chance of obtaining one?
    I also have an overheating problem - again only on the racetrack. The oil overheats first but the water temperature also heads skyward so that I cannot get in a full half hour track session. An aftermarket fan on the oil cooler has not helped the situation.
    Does anyone know if the 328 has a bigger/better oil sump, oil pump or oil cooler - or - know if there are any other aftermarket solutions to my oil pressure and temperature problems?
    Any and all suggestions and advice are most welcome. Thanks!!!
  2. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    A mechanic I know recommended adding an extra full qt of oil to the engine before tracking . Maybe this could help the oil temp and pressure to some degree.
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    See the post in another thread here.
  4. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
    Another reason to have too high a temperature is that you have too low an oil flow (the oil does not flow enough to cool the internal parts) and too high internal friction from too thick an oil. What brand, type and viscosity of oil are you using on the track and what do you use for around town driving? What exact pressures do you get at 2,000 and 4,000 and 6,000 RPM at the track with the hot engine and exactly what is the temperature?
    aehaas
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Ali
    It is a pick up/scavenge issue given the location of the pick up on the WS 308/328 cars. And by the time the Veglia gauge has registered it's too late.
    Philip
  6. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,189
    Bay Shore, NY
    Andy
    I don't usually like it when people say "they all do it" but in this case I can at least say that mine does the same thing. I agree its a scavenge problem and I too added an extra quart of oil when running on the track. It was a momentary drop of pressure in very hard corners but a drop nonetheless. I know some folks have installed Accusump systems to overcome this problem. The Accusump senses low oil pressure and takes over until pump pressure is back to an established level.
  7. Bianco
    Dec 29, 2003
    309
    Las Vegas
    Jeff
    I use Mobil 1 brand 15w-50 Supersyn Performance Driving Formula for both track and town. With a hot engine on the track the oil pressure runs at about 20 at 2,000 and about 40 at 4,000 and about 80 at 6,000 RPM. The oil temperature climbs to over 250 within about 15 minutes on the track and will max out the gauge at 280 if I don't pull off the track first. Here in Las Vegas the temperatures are in the 90s.
    In addressing my oil starvation problem on hard right turns in another string Philip Airey pma1010 said,
    "(I) can get away with overfilling the sump as long as you vent the vapor separator to a catch tank... Most race shops sell them. Buy a vented one (most are).
    I bolted mine to the firewall between the engine and trunk, then used a length of hose from the VS to the catch tank. You might route the trans vent to this too -- I find this vent will spray if the trans oil gets really hot.
    I run the engine oil 1/2 to 3/4 inch over max at the track."
    I intend to follow his advice. Do you think that would that also contribute to my temperature problem up to now?
  8. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
    The 50 wt. Mobil 1 product you are using gives you the perfect flow/pressure dynamics with that engine temperature on the track. However, it can only mean that you are running excessive pressure and therefore reduced flow at around town driving temperatures.
    I wound guess that the 0W-30 Mobil 1 would be better for around town. If you insist on using only a single wt. for both applications I would try the 0W-40 Mobil 1.
    A 40 wt. oil is only slightly thinner than a 50. It will give you slightly less pressure at the same temperature as the 50. However, since the 40 is thinner it will flow better and therefore cool the engine more. This will decrease the engine temperature somewhat. The lower temperature will make the otherwise slightly thinner 40 wt. oil a little thicker. This is why some people use a reduced thickness oil and actually get the same pressure as a thicker oil. The engine overall temperature is lower though and this is good for engine longevity in itself.
    The oil you are using is not the cause of any over heating on the track but is certainly eating up HP, and causing your engine to run a little hotter while driving in town. That oil is also causing a lot of wear and tear at start up, where most engine wear occurs.
    aehaas
  9. Bianco
    Dec 29, 2003
    309
    Las Vegas
    Jeff
    Thanks Ali. The car runs cool around town, and since it only robs a little horsepower on the track, I may want to stay with ithat viscosity since the owners manual specifies 5W-50. I haven't been able to find 5W-50 but will use it if I can to reduce startup friction.
    The water temperature increases almost as fast as the oil temperature so I think I'll need to look at the cooling system. Maybe an aftermarket radiator is available for better cooling.
    To solve the oil starvation on hard right-hand turns I've been told I can overfill the sump by an extra quart or so to 1/2 to 3/4 inch over max on the dipstick if I vent the vapor separator to a vented catch tank. I'm told I can also route the transmission vent to this too as I've heard it also sprays if the transmission oil gets really hot. That may solve the heavy oil spray I get all over the back of the car every time I track the car.
  10. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
  11. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Are you sure the 308 OM recommends 5w50? I thought it recommended 10w50 just like the 328 and Boxer OM.
  12. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,060
    Kansas
    Sean F
    Interesting, mine stays pretty constantly close to 85 all the time. A little lower at idle and lower RPM. Valvoline Synthetic Race oil 20w50.
  13. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
    I wish they would put flow meters on cars instead of pressure sensors. As flow becomes more restricted the pressure goes up. They are inversely related. Pressure does not lubricate anything. If it did then we should all be using 90 wt. oil.
    aehaas
  14. boxer frank
    boxer frank Karting
    Sep 30, 2004
    165
    toronto canada
    FRANK
    run an extra liter or 2 of oil and try straight water in your cooling system with redline water wetter.....water conducts heat twice as good as antifreeze
  15. f355spider
    f355spider F1 World Champ
    17,934
    A very common problem to the 308/328/Mondial radiators is that they can over time become plugged up and have reduced flow. The fix is to remove the radiator, have the bottom cut off, and a brush run up and down through the tubes to clean out the gunk....kind of like having an angioplasty :)
    Once done, you car should run just fine (cool). Remember, that radiator is probably over 20 years old, if it has never been replaced or opened up!
  16. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    58,351
    Australia
    another thing to check is the radiator cap tension is not soft as I did all sorts of things to my cooling system that cost a fortune but did nothing to help solve the trackday overheating problem until one of the racers guys in the club looked at my RC and said it was the problem and that I should get a 15lb Ford RC as they fit straight on and it fixed the water overheating permanently.
    As for the oil problem, I just added an extra litre or slightly more for trackdays and problem solved for the pressure but temp would still go off the scale after about 25 laps or 50 mins (I use to only do 5-6 laps before the temps would go thru the roof)
    Also Mobil 1 is not a great synthetic, use the Shell Helix synthetic. Racer mates of mine use to use Mobil all the time in their racecars but found abnormal wear and switched to Shell Helix which reduced it noticably.
    The 328 sump does fix the oil pressure problem to a degree but check the old Fchat for how to dry sump the 3x8 series cars, some good info there
  17. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    592
    NW Rural Nevada
    Mike Florio
    I'm not sure if your '82 has a mechanical advance distributor, but you might want to check if it is advancing correctly. Just attach a timing light, and run it up to 6000 RPM while observing the timing marks on the flywheel. It should move smoothly up to 38 degrees advance at 6000 RPM.
    I had an oil heating problem on my '75, and a stuck advance weight was the problem. Disassembly, cleaning and lubrication of the Distributors solved it. Of course you need a distributor machine to properly set the curves - that required a trip to eBay and purchase of... (long story truncated).
  18. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,216
    MO
    Dave. of the various aftermarket radiators, do you feel they would do the job? I was thinking of getting an aftermarket radiator + fan combo for my 328, but am hesitant of modifying any of the mounting points/etc in my car. (aka, if need be, I want to be able to swap it back to stock).
    Your thoughts on this? I may start a separate thread on it later.
    I feel a modern radiator/fan combo should help cool the system quite a bit.
  19. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,285
    Colorado
    Dave
    I have run a couple of QV's and my current 328 on tracks quite a lot. 328's have better cooling systems, especially water. On short, tight tracks, the QV's would reach 225 water and 260 oil. The 328 rarely goes over 200 and 250. On higher speed tracks, the 328 stays quite cool about 190 & 240. You didn't mention if your 308 is actually boiling over or just spitting out the overflow. If it's the overflow, change your cap as mentioned above. Ferrrari caps are crap, I once one got a brand new one that was bad right out of the box. I never had any oil pressure problems with any car. When the oil is really hot, you have less pressure of course, but mechanics tell me not to worry. It is my understanding that carb cars have the pressure drop problem but baffles were added in the injected cars to prevent that. By the way, my 89 328 calls for 10/40. I don't know when the switch was made from 10/50 but since there were no motor changes I'm theorizing that Ferrari at some point decided that heavy stuff really wasn't needed either because oils had improved or some other reason.
    Dave
    Dave
