Many parts from a 78 GTS 2 valve, carburetor, USA model timing belt cover, 108054, front bank, edge modified for water pump removal $100 water pump back, 105163, some pitting on surface $200 water pump, basic unit, not rebuildable, like new 03052846 (not a Ferrari #) $75 oil pump gear, 109308 $150 oil pump gear on shaft, 109956 $600 (both gears) $650 camshaft timing pulleys (sprocket cam gear) (4), plastic, excellent condition $120 each (2) 110994 raised ridge towards engine, (inside lip) (2) 110995 raised ridge away from engine, (outside lip) $400 set of 4 new Bosch Red Label ignition coils, 0 221 119 030 (these are used in place $50 each of the original coils. You still use the ceramic resistor unit) $90 both Excellent for a distributor set-up. Facet Universal Electronic Fuel Pump, 40131, flow rate 4-5 psi $65 Complete with fittings and bracket. This is specific to carburetor cars due to low pressure. Barely used. Original hose clamps, cleaned then cadmium plated (not zinc) (6) Miniflex, #2, 11-19mm $8 each (6) 30mm, (4) 20mm, (6) 15mm, (4) 15mm, (2) 13mm All clamps (28) $195 Air Injection manifolds, rear-109884 and front-107803 complete with $250 each check valves, 100564. No leaks, intact threads, excellent condition $450 both Prices do not include shipping and handling. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Not sure if you're parting out a car too but I need a right front turn signal assembly (not the lens). Mike
I am looking for an air filter housing for a 1979 Ferrari 308. Would be grateful for any leads. Thanks!
I don't have any. Try posting on the 308 board, Wanted to Buy... Also try GT Car parts in Phoenix, Arizona. I have had good luck with them.
Hello, I realize it’s been a long time since you posted the parts for sale, but can you tell me if you still have the emissions parts and clamps? Thanks
