308 QV: air in the radiator. | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by flanguasco, May 28, 2006.
  1. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Maybe the thing to do is drain the expansion tank and see if there is a tube on the bottom?
    Bill
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Understand - mine is the same.
    (and your English is a lot better than my Italian!)
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Refurbed & repainted my tank last year - there was nothing rattling around in it.
    I.
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,665
    Hell's waiting room
    Maybe that part of my theory was wrong. Couldn't it be drawing in air while the system is runing (and under pressure) too though? If the top tube is open to the air in the tank isn't there a possiblity that that air can be forced into the system?
  5. Jdubbya
    43,665
    Hell's waiting room
    If that's true that would confirm my suspicion. I don't know why it never occured to me before but it makes logical sense. BTW I also cleaned and sealed my tank last year and there was no tube inside.
  6. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
    Are you sure you are bleeding off air and not steam? When you open the bleeder valve with the system at operating temperature you release the pressure in the system which will cause the coolant to boil and release steam. If you are very far above sea level the coolant will boil and turn to steam at temperatures below the normal 212F (100C) when the system pressure is released.
  7. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    you say you are bleeding air out when the engine is hot/very hot I would say after a fifty mile run.Now you release the pressure cap which is meant to raise the boiling point of coolant.Internal heat from the engine now starts heating up the surrounding coolant, This high coolant temperature with no cap fitted will create an aeration effect.Look at a jug before it starts to boil.I dont recommend taking radiator caps off when the car has been turned off for a minute or more.I like the w/pump idea but more likely to be the cap .if coolant water is recirculating through that tank is it aerating the coolant as it fdrops back into the tank l.Pitting around waterpump impellor area can cause aeration/insufficient antifreeze /inhibitor/sharp rough edges or bends in piping.I have seen hoses sucked flat and coolant cant be suppled fast enough around the impellor . if nothing appears obvious try switching the heater pipes over if thats possible (hondas/subarus suffer this prob)and i would try using a Wurth product called radiator system sealer(used in new vehicles)have used it with amazing results. Tony
  8. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    Good point!! I don't know.
    What I can do is to run the car for a few miles then, when from past experience I know there is some "gas" (air or steam) in the radiator, switch of the engine.
    Wait until the radiator cools down and then open the bleed valve. If it was steam it should have condensed then no gas coming out; if it was air I should get the usual quantity of "gas" out from the radiator.
    But... thinking better about your sentence "...release the pressure in the system which will cause the coolant to boil and release steam..." I see a problem.
    When I open the bleed valve the coolant can't boil instantaneously because the pressure will not drop in zero time and therefore I shouldn't find a lot of "gas": I should, rather, get a stream of boiling coolant. But, anyway, your theory if very worth of a deeper investigation!
    Ciao and many tanks for this new point of view.
    Franco
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Unlikely...the upper hose seems to be the return to the tank.
    I.
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Yes, the bit about being able to bleed the thing when the engine was hot was in response to the idea that the air was being drawn in as the thing cooled. The air is in the radiator straight after switch off (i.e. disproving the theory about air being drawn in as it cools) and it's still there once it's cooled off - so it isn't steam either.
    I.
  11. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    You can't do this - boiling hot coolant will fly everywhere. You can however open the bleed screw on the radiator whereupon (in my case) air will come out to start with followed by coolant
    Unfortunately so do I.
    I really doubt this problem has anything to do with the expansion tank cap. Fundamentally the expansion tank seems to be under pressure when the thing is running & so any movement of air around the cap is likely to be outwards, not inwards.
    I wondered about this but I don't believe the coolant is foaming too much.
    I.
  12. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    Ian i was explaining your approach to a hot engine.Read again it will explain itself .The pressurecap and coolant raise the boiling point /dont release cap it could then start to boil. Does it look foamy. Tony
  13. ParadiseRoad
    Mar 26, 2006
    538
    Colorado
    Another thought, if the system is pressurizing normally, air cannot possibly enter the system while it is pressurized unless the air is at a pressure above system pressure.
  14. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    It seems as if air, to a large degree, is being redistributed from the expansion tank to the radiator upper header tank.
    I don't understand the plumbing to the expansion tank on a carb GTS/B. One would assume the larger, lower hose from the thermostat housing would be principally a coolant carrier and that the smaller upper hose, also connected to the thermostat housing, would convey air or a mixture of air and coolant. Can anybody post with authority/knowledge on how this is supposed to work?
    Bill
  15. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Right, so if air was being drawn in it would have to be at a point of negative pressure in the system. Someone has suggested via the impellor shaft on the water pump - right behind the blades in the pump should be a point of negative pressure.
    I.
  16. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    That's one option - but the system can't possibly have been designed to work like that.......can it?
    I.
  17. ParadiseRoad
    Mar 26, 2006
    538
    Colorado
    The water pump will be pressurized to system pressure also. There will be a pressure differential between inlet and outlet, but both will be above ambient air pressure when the system is at normal temperature and pressure.
  18. flanguasco
    flanguasco Rookie
    May 25, 2006
    19
    Imperia - Italy
    Franco G. Languasco
    Not quite sure (in theory). The system has its minimum pressure at the pump inlet, its maximum at the pump outlet and we only know that the pressure in the expansion tank can't be higher than 0.9 bar. A centrifuge pump of this kind is likely to have a differential pressure of 2 or more bars therefore, if the pressure drop from the pump outlet to the expansion tank is not greater than 1.1 bar, the pump shaft pressure is less or equal the ambient pressure. As I said, all this is just theory: a better knowledge of the hydraulic circuit is needed before arriving to a conclusion.
    Ciao and to the next.
    Franco
