308 QV Throttle sticking but not the cable | Page 2 | FerrariChat
Discussion in '308/328' started by jimmyp11, Feb 2, 2024.
  1. jimmyp11
    jimmyp11 Karting
    Dec 25, 2019
    149
    Port Charlotte FL
    jim patterson
    I hope to get a video in the next couple of days, maybe seeing the throttle movement will help
  2. Michael DB
    Michael DB Formula Junior
    Dec 22, 2023
    252
    Michael D Beswick
    For it to “hang” does it not imply the butterfly must be partially open? Have you investigated the shaft /butterfly/spring assembly.
    The fact it snaps back 4500 might be the return spring being more compressed overcomes whatever is causing the stickiness…..,Maybe!
  3. jimmyp11
    jimmyp11 Karting
    Dec 25, 2019
    149
    Port Charlotte FL
    jim patterson
    I have, and keep in mind this can not be replicated sitting in neutral. But, I agree, one would believe this is one of the few ways for this to occur.
  4. Michael DB
    Dec 22, 2023
    252
    Michael D Beswick
    Experience of other cars suggests “load” has some effect which might go some way to explaining why it happens only on the road. Is there anything else that would cause the same effect as the butterfly being open? If not with foot off the accelerator the butterfly should snap back to almost closed (idle speed).
  5. jimmyp11
    jimmyp11 Karting
    Dec 25, 2019
    149
    Port Charlotte FL
    jim patterson
    Thanks all for their advice, I did get a video, I think the moral of this story is 99% of the time it is the cable. Seems under load, in an actual 4 or 5th gear you don't have the snap back that you do in neutral, so any amount of slack in the cable will mess things up. I will unscrew the ends and tighten this up as there is just a bit of slack, but I guess that's enough.
  6. Michael DB
    Dec 22, 2023
    252
    Michael D Beswick
    Glad you found the solution. Being new to this I think I need to learn more about K tronic!
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,614
    California SF bay area
    Paul
    Well if it's the cable the cause would be the opposite of slack because, as I suggested before, under load the torque from the wheels wants to rotate the engine backwards. This is arrested by the dog-bone brace that runs from the top of the 1-4 cam cover to the rear firewall. If you had a blown out bushing in that brace or if the firewall mount came loose and you lost one or two of the slotted shims the movement would pull on the cable which is connected to the chassis. Maybe just grab that brace and make sure it's rock solid. If it is at least you can cross it off the suspect list.
    johnk... likes this.
  8. jimmyp11
    jimmyp11 Karting
    Dec 25, 2019
    149
    Port Charlotte FL
    jim patterson
    Thanks for the tip!!!
  9. jimmyp11
    jimmyp11 Karting
    Dec 25, 2019
    149
    Port Charlotte FL
    jim patterson
    Interesting, I may have a blown out brace bushing. That cable easily moves through that cam cover brace. I'll look up the part # for that bushing. Could be just that movement.
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,449
    Dumpster Fire #31
    SMG
    Having driven test engines without the brace, I've never experienced that problem. I wouldn't go spirited driving without the brace. The engine also moves a lot more in reverse then forward.
    The engine is either getting more air other then the throttle, i.e. a broken or messed up check valve on one of the vacuum circuits or the the cable/TB is sticking.
    Rifledriver likes this.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Not only the brace, but also motor mounts.
  12. Rifledriver
    37,288
    #37 Rifledriver, Feb 5, 2024
    The entire concept of a Bowdin cable eliminates movement of the engine causing the cable to be pulled. Torque strut or not.
    Slack or not, same applies. Cable needs slack. Too much only limits total throttle opening.
    Its a case of GIGO.
  13. Rifledriver
    37,288
    Would not matter.
  14. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,614
    Paul
    You're right now that I think about it, The cable housing is secured to the bracket on intake manifold. Oh well, I was just floating ideas but he can scratch that one off the list.
