308 rear spoiler (wing) | Page 3 | FerrariChat
Discussion in '308/328' started by Crowndog, Feb 3, 2012.
  1. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    #51 glenv6, Feb 6, 2012
    I bought a contour gauge at Lowes yesterday. I taped up the wing in the middle so I wouldn't scratch the paint and pressed the contour gauge along the top starting at the leading edge. The gauge I bought is too short to measure the surface by about an inch, so I took the measurement from one edge, traced it onto paper, then took the measurement from the other edge and traced it onto the previous trace with the approximate overlap. Picture is below.
    My initial trace is very rough, but the result is good enough to know that my wing is flat on top and curved on the bottom, so it is shaped like a wing. I talked to an airplane builder friend of mine who said he would help me measure this thing and interpret the shape, so my hope is we can understand the shape of the wing well enough to know how the angle of attack plays into this to answer Crowndog's original question...
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Great effort! Thank you. Can't wait to hear the results.
  3. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    Should be fun! My friend sent me this website link to get started once I have my measurements...
    http://www.grc.nasa.gov/WWW/K-12/airplane/foil3.html
    Plugging in the numbers should give us a "good enough" indication of what effect the angle of attack has.
    If anyone else here is interested in participating with their own measurements go for it :)
  4. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    :D
    Looking forward to the NASA simulations on our 308 spoilers, whatever the outcome.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #55 Crowndog, Feb 6, 2012
    Using approximate values I am getting a small negative lift and equally small drag. By varying the angle of attack or cord (width) the lift value changes pretty quickly. It will be interesting to plug in more careful numbers tonight after I take some measurments. I have an inclinometer to measure the angle of attack. The chord and thickness values should be easy. The program calculates area when length (span) and width are plugged in. Way cool.
  6. BigTex
    79,408
    Houston, Texas
    Bubba
    #56 BigTex, Feb 6, 2012
    I think ya'll are losing sight of it's intent.
    It's not for generating killler downforce on the car body itself, IMO.
    It is for relief of the vortex at the rear window, which kills cooling flow thru the engine compartment, via the relief louvers.
    Not downforce for it's own sake.
  7. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Sounds like marketing-speak from Ferrari to justify caving to a fad. Maybe some inquisitive owner will tie yarn on his deck louvers and test the issue.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,842
    Cerritos, CA.
    #58 miketuason, Feb 6, 2012
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Could you share with me your center thickness measurement, I am having difficulty getting an accurate number and this is a critical value.
  10. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    #60 glenv6, Feb 6, 2012
    I made a caliper just for this! I'm finding it is 3/4"...
  11. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,280
    Worcester, England
    Phill J
    That's pretty much how I see it too.
    To Me, it appears that the rear window, the roof line and the rear buttresses create an area above the engine cover where there is very little (if any), air flow to draw the engine heat away.
    The angle of the wing appears to pull air down across the engine cover to help draw away the engine heat a bit more efficiently.
    This extra air flow is also then being pulled over the rear raised lip on the engine cover lid, not to create massive downforce, but to break away the air drag at the rear end of the car.
    This is where people get confused and think that all rear spoilers on cars are there to create downforce.
    Some rear spoilers are designed to produce an element of downforce (like the whale tail on the original Porsche 911 turbo and the rear spoiler on the Audi TT coupes), but the vast majority are designed simply to "spoil" the air flow at the rear of the car and cause the trailing air wake to be "snapped off" more quickly. This results in less aero drag on the car, thus making the car marginally quicker.
    This is the thinking behind boot (or trunk) lip spoilers. They do not provide downforce, they reduce drag.
    In the case of the spoiler fitted to the buttresses on Ferrari's 3*8 series, a more appropriate name for it would be an "air deflector", as it's not really there to "spoil" the airflow, it's actually there to redirect (or deflect), the airflow downwards.
  12. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    BigTex - While downforce may not be the primary mission of this appendage it is still a function of the shape... Where does the info about the vortex come from? Just curious :)
  13. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    What did you come up with for the angle?
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #64 Crowndog, Feb 6, 2012
    I have got delayed at work and forgot inclinometer. I will take the measurement tomorrow and post it. Also, in the sim that I did I used the smoke probe and could not find a scavanging effect below and behind to help with heat. But could not simulate the passenger compartment in front. No idea if that would make a difference. Also, using camber as %chord = -5.0 (inverted flat bottom wing) and chord = .54ft and looking at a shape plot for an ellipse, the other variables have little influence, the angle of attack seems the critical value and anything over 5 degrees seems to produce positive lift. I am afraid that at first glance thhe spoiler is just that. It spoils. Most likely producing lift. Bummer.
  15. vaccarella
    Apr 16, 2011
    2,291
    Paul
    I'm sure it would.
  16. treventotto
    treventotto Formula Junior
    Apr 14, 2008
    720
    Alicante
    Benjamin
    Maybe it's simply a sun visor :)
  17. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    I'm as interested in the ability to spoil as I am with any downforce that might have been created. I would also really like to know where the vortex info comes from and if there are any more detail about it...
  18. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    #68 Matto, Feb 7, 2012
    It's pretty effective that way, too :) I'm one of those odd ones who really likes the airfoil up there. To me, it's one of those QV "signatures". It would be cool to see the math though, on how it's affecting air flow over the bonnet. I look forward to seeing your results here. If I can do anything to help, let me know. It would be especially cool if we could take a couple of models back into a wind tunnel for video.
  19. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Couldn't agree more but it would be nice if it did have some function as well. Tonight I will post some measurements and findings.
  20. miketuason
    Feb 24, 2006
    15,842
    Cerritos, CA.
    Robert, doesn't my pics on post #58 shows that there's a little down force?
  21. vaccarella
    Apr 16, 2011
    2,291
    Paul
    You'd need to do it with spoiler on / spoiler off rather than stationary vs moving. Downforce visible when moving is largely from the aerodynamics of the whole vehicle rather than just the foil.
    I measured yours with my screen ruler and it seems to be squatting by very roughly 10% (measured as a ratio of rim width to wheel centre/top of wheel arch)
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    It does look that at speed the front spoiler is lowering the front and perhaps there is less tire gap in the rear. I seem to notice that the 3x8s at speed tend to hunker down but have no idea if they are being pushed that way due to aerodynamic forces on the car or are being sucked down due to some ground effect. It will be interesting to see the calculations later with the more precise numbers.
  23. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    #73 glenv6, Feb 7, 2012
    Hey Gang,
    I googled for wind tunnel software today during lunch and found the following two items. The first is free wind tunnel software that uses "STL" files, and the second is a site that actually has an STL file available for a 308!
    Free "Project Falcon" Software from Autodesk Labs:
    [ame]http://www.youtube.com/watch?v=UrrOA0rlaCg[/ame]
    http://labs.autodesk.com/utilities/falcon/overview/
    308 STL file available here for $100.00 USD (or free if you have an STL to upload):
    http://www.3dcadbrowser.com/preview.aspx?modelcode=7616
    http://www.3dcadbrowser.com/preview.aspx?modelcode=23789
    Unfortunately I haven't been able to get back to the wing analysis since taking that center measurement, but it looks like Crowndog is running with it! I'm also probably not going to be able to play around with the wind tunnel software until the weekend, so please don't let me stand in the way of progress! :)
  24. Steve Magnusson
    26,955
    Did you also account for 2 occupants vs no occupants?
  25. glenv6
    glenv6 Formula 3
    Jul 4, 2011
    1,158
    New York
    Glen
    Miketuason - Regarding vaccarella's on screen measurement, were you accelerating at that time that picture was taken? It's hard to know what's causing the squat from a static picture...
