308 shifter lever return pin PN 108824 | FerrariChat
Discussion in '308/328' started by 808Forza, Jun 10, 2025.
  1. 808Forza
    808Forza Formula Junior
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Working on a 1983 308 GTB project car.
    Upon receiving the car, noticed the shifter handle not returning to center and can even spin the handle.
    Removed the shifter assembly to inspect and found the lever pin retainer is completely missing.
    the snap ring, cover and spring are present.
    PN# 108824 lever return pin shows available to order, however, Eurospares says it’s discontinued.
    Anyone have one they can offer to purchase or pics and measurement of one to see if I can have fabricated at a machine shop?
    Thanks in advance for any help on this.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Rifledriver
    37,068
    Not a high demand item. Find people who part out cars. Ferrparts, GT Car parts, T Rutlands etc.
  3. moysiuan
    moysiuan F1 Rookie
    4,183
    Canada
    Where did it go, is it sitting in the bottom of the shifter casing? Seems an odd item to be missing, if someone took it apart and put it together without that the shifter would not be working as you note.
    https://ferrparts.com/parts/Ferrari/108824
    Maybe they have one in stock on their shelf.
  4. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thanks. Trying these suggested locations. ferrparts checked and no dice
  5. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thanks for the suggestion. So far no luck with Ferrparts. I checked everywhere around the interior and it’s nowhere to be found.
  6. Michael DB
    Michael DB Karting
    Dec 22, 2023
    230
    Michael D Beswick
  7. Rifledriver
    37,068
    808Forza likes this.
  8. moysiuan
    moysiuan F1 Rookie
    4,183
    Canada
    Time to get creative. You might have to buy the one that fits the Mondial and some other models, the part which has a slightly different design with a nub on one end, and grind the nub off. I suspect the hole in the shifter case is the same size in each model, but can't be sure. If it is, and that alternative part is indeed available, it could possibly be modified to fit.
    Or if someone can measure the precise dimensions of the item, it looks like a simple sleeve that could be fabricated for low cost.
    The alternative would be to buy a used shifter assembly off of ebay or elsewhere. You might be able to do that and then resell some of the parts you don't need and recoup some of the cost.
  9. Michael DB
    Michael DB Karting
    Dec 22, 2023
    230
    Michael D Beswick
    It looks like a simple closed off cylinder. Does the spring look as though it fits inside? The diameter of the hole will determine the OD with some clearance. Easy enough to fabricate. The thickness of the closed off cylinder”end” might be tricky but trying washers against the spring might give an idea.
  10. moysiuan
    moysiuan F1 Rookie
    4,183
    Canada
    #10 moysiuan, Jun 11, 2025
    This is why I think the Mondial item with the nub ground off might be the solution. Part number 103317 superceding 522514.
    Makes me look at my own shifter, this little extra nub on the part was probably an add on to the original 308 part, to help the Mondial and TR cars orient the shifter handle a bit more than in the 308, which has a different shift lever. The picture is with the shifter moved fully to the left of centre, where this little spring loaded sleeve with the nub comes out of its burrow. It is interesting that your car is shifting ok without this part in place. I am not certain exactly what its function is, it must be interacting with the spring loading within the transmission, those famous 3 little springs and balls within the transmission pan.
  11. sltillim
    sltillim Formula 3
    1,692
    San Diego
    #12 sltillim, Jun 12, 2025
    You are looking for what is in the upper right hand corner of this picture, I believe. No I don’t have an extra! But my shifter is still out. I just bought a very cool 3D scanner and I can make a scan and convert it to a cad file or simply share measurements. You can have one machined with steel rod and a lathe pretty quickly. Or, I could try to print it out of a carbon fiber infused plastic and you could put a washer in between, it might last?!? Maybe outsource a cnc version to be made….. The pin fits into a recess in the shifter fulcrum and keeps it from spinning and within limits vertically as you press down for reverse lockout. It's not a ton of force but I think a solid metal one would be better.
  12. sltillim
    sltillim Formula 3
    1,692
    San Diego
    Note - mine is out of a '75 GT4, so yours might be different. I am sure brian can confirm but it looks as though some shifters didn't have the groove on the fulcrum ball. Does yours look the same as mine or is the face where I see the groove in my pic remain a flat surface on yours? your pic doesn't really show...
  13. eurocarguy101
    eurocarguy101 Karting
    115
    Jacksonville, Florida
    Jefferson Wheeler
    It’s interesting the 83 is different than my 84 QV, at least by your parts diagram you posted above. I just had the shifter apart and mine didn’t have the nub in the bushing or a slot in the shifter so it may be a little bit of a narrower search for you.
  14. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
  15. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thanks. Yes, a fellow member was kind enough to private message me a drawing with the dimensions.
    has a local machine shop make it and it did not work because it appears the piece with the nub is made to work with a slotted fulcrum. mine is not slotted so not able to fit and secure the snap ring.
    Next attempt is to remove the nub and try again
  16. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thanks for the pic and I think you’re onto something. the nub appears to not work with my shifter so we are modifying it without the nun and retry
  17. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
  18. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thank you sharing the pic. That is correct, mine does not have the slot on the fulcrum and the nub appears to interfere. We are modifying it without the nub and will retry. Will share the outcome.
    sltillim likes this.
  19. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thank you for sharing this pic. Yours looks identical to mine except it appears someone cut out the sides of the housing to lighten it for race purposes.
    the spherical flat portion has no slot like yours and I see your detent has no nub on it. This explains why the piece with the nub will not insert completely to allow the snap ring to lock in.
    eurocarguy101 likes this.
  20. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
  21. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
  22. sltillim
    sltillim Formula 3
    1,692
    San Diego
  23. sltillim
    sltillim Formula 3
    1,692
    San Diego
    Hmmmmm... Graph Paper..... It's been a while..
    As I start my journey into learning CAD I am going to try and make a model of this. It will be valuable for the group. I hope it works after you cut off the nub - please let us all know!
    808Forza and moysiuan like this.
  24. Anton Schicho
    Anton Schicho Rookie
    Mar 2, 2020
    6
    Anton Schicho
