308 smoking | Page 2 | FerrariChat
308 smoking
Discussion in 'Technical Q&A' started by Hopper, Apr 21, 2019.
  1. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Grog like post ! :)
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
    You’re the BEST! NO YOUR the best! NO, YOUR THE BEST!!
    (rolls eyes)
  3. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,795
    Atlanta, GA
    Steve D.
    The best know when to be quiet and watch, and it has been proven in this thread.
    sjd
    jjtjr likes this.
  4. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I'm not quite clear on whether the smoke is coming from inside the exhaust pipe, or a fluid dripping on to the hot pipe and smoking.
    Kinda need more info than "hot exhaust make smoke don't want" before one starts pulling parts out of the car.
  5. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    just pull the plugs and look at them. You will learn a lot about the car. If brake fluid is leaking you will see it in the plugs. Not likely though.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    What does brake fluid on the plugs look like? You should be able to narrow down the problem without removing plugs. It's a fair amount of work.
  7. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    Really? Think about it. You’ve all been trolled by the red herring. Pull the damn plugs and figure out what is wrong. It’s just a car guys.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,841
    Norfolk - UK
    Tony
    So you are advocating sniffing, licking and looking at a soiled rag and all of that from just standing behind the car....wow, you are the nuts!
  9. magaoidh
    magaoidh Karting
    May 12, 2009
    220
    I have known and read Rifledrivers posts for years and he knows a lot of stuff!
    tazz99 and Ak Jim like this.
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,841
    Norfolk - UK
    Tony
    He should do, he has been at it for a long time. I had to laugh at the rag sniffing theory though, its surprising what you learn in 30+ years
  11. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Someone posts a ridiculous question with no basis or reasoning & everyone runs off at the mouth with no sign of the original poster. Smoke from right exhaust, 4 words and its on!!!! Lol
    johnk... likes this.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
  13. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    One thing I didn't see mentioned. The 308/328 cars will naturally produce more steam/smoke out of the right side tail pipe due to the design of how the manifolds are connected to the muffler. Much more noticable in colder ambient temperatures.
    Top off as a control, then drive and monitor your fluid levels. Oil, brake fluid and coolant. If any one of those starts disappearing at a higher rate then normal..you have found your culprit. Next is to find the cause.
    Dane likes this.
  14. racerboy9
    racerboy9 F1 Rookie
    2,524
    I had a MGC once that had brake boosters that were bad. Looked like I was fogging for mosquitoes!
  15. mwr4440
    55,949
    Bavaria, The 'Other' Germany
    Mark W.R.
    In the Military I have known many 'Motor Officers' (really Maintenance Techs) and NCOs. They were responsible for keeping several hundred vehicles, each, Fully Mission Capable, 24x7x365.25. And they were DAMN GOOD at it.
    Point being, they never 'Broke Wind,' let alone 'Broke a Seal' on ANYTHING without checking EVERYTHING out FIRST; Visually. Then starting 'it;' checking again Visually and adding Listening and then letting it run 10+ minutes and checking it AGAIN Visually and Listening.
    A piece of 'filter paper' over the exhaust was also almost always applied.
    Once all clues were gathered and inspected and analysed by the Motor Officer/Maint Tech did I EVER see a mechanic reach for a wrench.
    WORK SMART, FIRST.
    THEN
    WORK HARD.
    Ak Jim likes this.
  16. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    680
    Vermont
    john truskowski
    ^^^^^^^THIS
  17. DonB
    DonB Formula Junior
    616
    Florida
    Don Bartz
    I think the car should maybe start to vape.....it's supposedly better than smoking
    Qavion likes this.
