308 Speedo, Odo, Sender System Fix | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by RJay, Apr 8, 2006.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    another thought . . I was just checking out other OEM sending units on Summit and it looks like something might adapt pretty easily to the stock 308 mounting position on the gearbox (easy being if you have a mill and lathe :)) . .. there's a new kid working at Kragen that's been real helpful when I walk in with something in hand . . . might give that a try.
  2. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    #27 gerritv, Sep 19, 2008
    Hi Sean
    Measure the threads on the sender mount, it is standard M14 or something. This should translate to after market 'cable to electronic' senders from most aftermarket speedo manufacturers. An example might be http://www.magsensors.com/vss.html Another source is http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
    BTW I really really wnat to see your 'ring removal' gadget, that is the most scary operation you can perfomr on an instrument. I can't imagine replacing a ring, where would you get one? I had to remove one on a broken 365GT4 clock that was heading to a concours event. Took a year off my life.
    Gerrit
  3. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    thanks Gerrit .. I'll make it a point to take some pics.
  4. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    M18X1.5 is the thread on the stock piece . .. well it measured .670 which is 17mm but the major dia of the thread is stripped so pretty sure it's the next size (seen this a few times) . . so I can just get away with a thread adapter and one of the parts from the Jag place for $75 (square drive looks correct) . . or call the other place since no prices online but can do custom apps which means pricey.
  5. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #30 luckydynes, Sep 19, 2008
  6. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #31 luckydynes, Sep 20, 2008
    if I was doing something I was worrying about destroying I'd make a ring to support the o.d. of the bezel (maybe just c'bore the install ring I made) and a second ring for the tool to lever against instead of pushing on the plastic . . there's a way to mount this on a rotary table too if you do it for a living . .. let me know and I'll tell you how I'd do it . . then you'd be able to peel the lip back and close it just like a canning machine .. but it'd be a semi-complicated arrangement but might be worth it for what you're working on.
    as you can see I just made it from a miniature pair of cutters
    cheers
  7. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi
    I can't say I do it for a living but I am doing 1 or 2 a month. I will get modify the aluminum plate I am already using to add a 'peeler'. Rolling the rim back down would be ok with just a roller. The rim doesn't need to be rolled back very far to create enough wiggle room over the plastic lip, at least not on the tach and speedo. The clock is a different matter, due to its much smaller diameter and the fact that the case is metal.
    Thank you for the insiration to create a better tool to make this less scary :)
    Gerrit
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I have a small stable of Italian vehicles from the '70's and they _all_ (Ducati, Moto Guzzi, Ferrari, Vespa, Alfa Romeo) have the same speedo threads and square drive for the cable. In fact, I have an Alfa spider tach on my Guzzi. Screwed right on, no issues at all.
    Moto Guzzi uses these same angle attachments. Your local (ha!) Moto Guzzi dealer can get both 90* and 60* versions. MG Cycle (mgcycle.com) has them mail order:
    17768360 90 degree cable drive gear $44.00
    Used on many models, particularly with fairings where cable clearance is tight, also for custom consoles
    23768310 60 degree cable drive gear $54.95
  9. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    dude . .. glad I could help . . .you're welcome :)
    I've worked on some industrial canning machines for Coke and Del Monte just incase your biz grows :)
    cheers
  10. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Luckydynes,
    Nice tool and it seemed to work for you. In the first post, I mention how I got the ring off but I wasn't real clear. The ring was rotated so that a small notch in the side facing the rear of the speedo lined up with a notch in the plastic bezel. The ring is then pushed out towards the front so that the inside most part of the ring starts to cross through the notch. The ring then gets really tight as it trys to "climb" off the bezel plastic lip as it is rotated. It literally "threads" itself off as you rotate the ring. The force is then equally distributed on the bezel and hopefully doesn't crack anything. The ring then just pops off in your hand....in a perfect world :)
    -Rjay
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #36 luckydynes, Sep 25, 2008
    thanks . . I wondered if there was an easier way and another poster on here said he got the speedo apart without bending the bezel.
    Hey doesn't one of you guys owe me a chip or something? :)
  12. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    #37 gerritv, Sep 25, 2008
    Hey Bob, how are things?
    I use the pry, twist approach as well but it scares me. Some of the units worked on have been opened before and the case starts to crack right on the lip line. I will modify the aluminum support plate I use to incorporate something like Luckydynes approach.
    Lucky,
    I thought you got a chip already? If not, send me an email. We will come to an arrangement :)
    Gerrit
  13. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    #38 RJay, Jan 4, 2009
    As much as I enjoy hearing from my fellow Fchatters, I thought I would save everyone the trouble and post the schematic and layout for the Veglia Speedo that I reverse engineered in '06.
    -Rjay
    LuckyDynes, I have the chip now and I sent you a PM a month or so ago. You have to send me five bucks and an address and the chip is yours (I have been consistent about this :). If I don't hear from you, I am going to Ebay it in a few weeks.
  14. veradent
    veradent Rookie
    Jun 11, 2009
    7
    Italy
    Verace
    Sono Verace dall'italia sono in cerca di un say115y dove posso trovarlo?
  15. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Non disponibile
  16. sebino81
    sebino81 Karting
    Dec 14, 2008
    135
    France
    Paul M
    Hi all,
    For rallying with my ’77 308 (in "old ladies" category obviously), I need a Tripmaster.
    To install thnis device, I intercepted the red wire (pulse wire - I have strictly the same odometer as the one described by RJay) to connect it to the Tripmaster via a Brantz interface and …the system does not work!
    First of all, I must precise that I’m totally dumb in electricity/electronic but
    - my odo works fine;
    - I tested my derivation registering the pulse at the end of the wire I installed; so, for this part, all is OK.
    Re-reading the Brantz interface instruction, I read that “analogue sources are not suitable”.
    Anybody knows if the pulse coming from the sender is a digital or an analogue signal?
    Personally, I have no idea on the difference between the two things and how to distinguish them...
    Thanks in advance.
    Paul
  17. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Gerrit,
    Did you ever get a working version of the chip?
    Thanks,
    Joe
  18. 4wd
    4wd Rookie
    Dec 21, 2009
    1
    First off, I don't own a Ferrari but the information in this thread was useful for a friend who has one with a faulty speedo so I thought I'd return the favour.
    My friend who is currently in our house in Australia, (we're in his place in the UK), has found a source for the SAY115Y IC - there were three (3) available, now there's only two (2) left.
    The shop is not on the internet which is probably why he still has them and the owner is currently selling off all his stock, (the shop has been there at least 35 years that I remember - I used to live near it).
    They're not cheap, the price was ~AU$120-140 each and contact details are:
    Ringwood Speedometer Service
    693 Whitehorse Road
    Mitcham, Victoria
    Australia
    3132
    Ph: +61 (0)3 9874 2260
    NOTE: This information was current as of 2010-03-27, friend's been in Australia for previous 5 weeks - so I don't know exactly when he bought his IC. So if someone finds out they're all gone or buys them all I hope they'll update this thread with a post.
    Anyway, hope it helps someone - now let the squabbling begin :D
  19. steven_ew
    steven_ew Karting
    Apr 3, 2009
    107
    Hi,
    I'm having the problem of a broken speedometer at the moment, and wonder if someone might be able to advise?
    I had initially thought the problem was the sender - having disconnnected it and reconnected whilst painting the chassis. Whilst on holiday; the speedo stopped. Fiddling with the send connection got it going (?) again for about 10 miles then it stopped.
    I have taken the sender off and tested as described above - no pulse.
    I have also replaced the transistors and now the sender gives a square wave of 0-2.5V when rotated, when connected to a 12V supply.
    But the speedo still does not work.
    I am wondering if the sender is still broken? Should it be giving 12V pulses? or should the 2.5V pulses work.
    Can I test the speedometer by switching on the ignition and connecting a 12V pulse to the red wire?
    Also, Gerrit, if you are still on here, did you come up with a fix for broken speedometers along the lines of a new circuit board?
    Has anyone found any more SAY chips?
    Best regards
    Steven, UK
  20. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #45 Paul_308, Dec 21, 2010
    I've gotten heavy into the speedo circuit as I'm working on the DRD correction module from 12o'clock and a "how to" DIY for the 308.
    No, the ground side is the body which is grounded by it's mounting. The other wire is the output from the internal transistors sending a low impedance signal to the speedometer.
    No. The impulse generator (speedometer sender unit) outputs square wave pulses between 0.6v and 5-6v from red/blk wire when the green wire is at battery +12v and body is at ground. A 2.5v output is marginal if it works at all. Although the speedo circuit contains protection, do not put battery voltage on it. The best way to test the speedometer is using a signal generator for a square 100Hz wave and gradually increasing the amplitude.
    In replacing the transistors it sounds like the biasing is off a bit. If you've gotten into the generator, I'd go the next step of drawing out the schematic and altering a resistor value or two to get the full necessary voltage.
  21. steven_ew
    steven_ew Karting
    Apr 3, 2009
    107
    Thanks Paul, for your advice. What do you mean by DRD correction module from 12o'clock.
    Thanks for your thoughts on the sender and testing speedo etc. I will try over Christmas to sort a 6V square wave generator and test.
    Regarding the sender (and considering I really don't know much about electronics), can you think of a reason it is giving out a nice 2V square wave after replacing the transistors, rather than the correct 5-6V? It gave nothing before.
    In my mind I'm not sure why it wouldn't be working right and why the situation would occur when it would need adjusted a bit?
    Perhaps if I draw down the schematic you might be able to advise on which component to tweak?
    BW
    Steven (UK)
  22. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #47 Paul_308, Dec 22, 2010
    Sorry for trying to save some ink...DRD = SpeedoDRD which is 12o'clock's product number for the motorcycle speedometer corrector module. http://www.12oclocklabs.com/p_sdrd.htm
    The reason you went from a non-working Impulse Generator to one producing 2.5V pulse but need one producing 6V pulses is likely because another component is wrong or you didn't use the exact same transistors. If I knew the Impulse Generator circuit I could figure out the voltage problem (the speedometer circuit is available but not the Impulse Generator). The +6V number I use comes from the original poster, RJay, in 2006.
    Input specifications for the SAY115Y chip require 2.5-3.5volts to trigger. The reason your 2.5V is inadequate is the speedometer has input protection circuit in front of the SAY115Y - integrated circuit which reduces the pulse amplitude below the required level. You just don't have quite enough voltage to trigger the SAY115Y - integrated circuit. Close by not enough to work reliably.
    Can you provide pictures (digital but even detailed word pictures) or any circuit information about the Impulse Generator from your experience changing the transistors? Certainly if you already changed the transistors there is hope to get it working again...you are so close.
    Incidentally, when measuring the voltage output from the Impulse Generator by meter or o'scope, assuming +12V is applied to the green wire, negative to the housing, the output wire must be connected either to the speedometer or to a pulldown resistor of about 500 ohms (RJay info).
  23. steven_ew
    steven_ew Karting
    Apr 3, 2009
    107
    #48 steven_ew, Dec 23, 2010
    Hi Paul, that's very helpful, thanks.
    An instrument tech at work tested the sender with the resistor as per RJay's comments above and came up with the ~2V square wave.
    I will try and draw out the schematic for the sender from the circuit board, in the mean time here are some photographs of what lies inside (before cleaning and replacing the transistors)
    Is this a hall effect sender? I don't think there is a magnet attached to the rotor...
    Incidently, to get it apart we machined off the top crimping - plan to make a threaded collar to reassemble, should we get it working! As you say... so close!!!
  24. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #49 Paul_308, Dec 24, 2010
    Thanks so much for posting the Kodak moments (dual lens?). Yes, a hall effect device should have 3 leads like a transistor, is often flat, and will be placed very near to the rotating shaft which will have 2 tabs or reliefs of equal size (for a square wave) machined into it. Most parts on the pcboard are identifiable but yuk...what invaded the sensor, oil from the gearcase seeping through the seal?
  25. Steve Magnusson
    26,958
    #50 Steve Magnusson, Dec 24, 2010
    If the rotor itself is just a piece of metal (steel), it could be a variable reluctance device. It looks like one of the components on the PCB is a vertical coil of wire on a bobbin with a steel (or magnet) center post whose end the rotor leaves pass fairly closely by -- is that so?
