308 Speedo Repair/Rebuild | Page 10 | FerrariChat
Discussion in '308/328' started by alhbln, Aug 22, 2013.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Tim, hope you fully recover, that does not sound too pleasant at all. Wish you lots of health and happy hours! Happy to supply two of the new ones to you but first need your help in making sure they actually work as intended :) Don't worry about the development cost, your support in testing is well appreciated!
    Gordon, that should be feasible, mph->kmh conversion will be a standard option on the new boards.
    G. Pepper likes this.
  2. 308deano
    308deano Rookie
    Sep 3, 2017
    12
    vancouver bc
    dean giammarco
    Hello Adrian,
    I too am in the need of your product, when it’s available. If I could please be on the list.
    I have and 83 308 QV with Km/h in Canada speedo and odo have stopped functioning
    Cheers
  3. Thomas Dowell
    Thomas Dowell Rookie
    Sep 19, 2017
    2
    Thomas Dowell
    Hi everyone, bit of a thread resurrection (hopefully!) .
    I've just found this thread after the speedo in the 308 QV I have finished restoring in work has suffered from its 10 years sat in a dusty box in a damp Scotland! Neither the needle or the odometer work. I have replaced the sender and tested all of the connections to and from both the sender and the gauge which all check out good.
    Was any headway made with the type 2 board for these cars as id be interested in trying one out to see if it solves the problem. I do have the capability of making the board if the schematics and code are available, this would save a lot of time in reverse engineering that Adrian has clearly already done such a good job of, so hats off to you for the time and effort put in!
    Would be happy to pay for the designs etc. of course, just need a resolve as replacement speedos seem to cost all of the ££££s .
    Thanks very much in advance,
    Tom
  4. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Work is mostly done, i expect the first dry run on the test bench in the next one to two weeks, depending on my work load :)
    If you have a very early QV then it might have a transitional speedo which requires a modified type 1 board.
  5. Thomas Dowell
    Sep 19, 2017
    2
    Thomas Dowell
    Cool, thanks for the response. It's an 84 so possibly the type 2? I'll have to get a pic next week.
    just out of interest where are you based?
    Tom
  6. paul ruby
    paul ruby Rookie
    Feb 17, 2016
    3
    Boalsburg
    paul ruby
    Oooeee it's working! Thanks Adrian. You are my hero. I wasn't following your instructions well. But I applied the power AFTER I pushed the calibration button and
    it fired right up. See the photos. Notice I added some additional wire length to the two wires under the board. It was too hard to solder them on with the original short wires. After I set the calibration to 81MPH using your built in calibration signal, I put 184Hz into the sensor input wire from my external source and I got 100MPH
    on the speedometer. The odometer is also working and the trip odometer also works. It's exciting to me. You saved me at least $1000 in that I didn't have to buy
    a new speedometer (or what ever they cost).
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    G. Pepper and alhbln like this.
  7. AN-M
    AN-M Formula Junior
    Jun 30, 2012
    367
    Norway
    André
    Finally, four years after I did the board conversion from miles to the more civillized km, I'm in the process of changing disc. The nonsensical MPH disc is out, now I hope fedex delivers before the weekend. :)
    paul ruby and alhbln like this.
  8. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    A quick update, i found some issues in my hardware design while doing the software testing and redesigned the hardware accordingly. The new boards will be supplied next week, i'll continue with the software after assembling then and if all works well we can start field testing.
    I used the opportunity to redesigned the configuration switches to support normal/conversion mode (mph->kmh) and also supporting the Turbo cars such as the 288 GTO and 208 GTS/GTB Turbo which have a different gearbox/sender setup. So we need just a single board/software version to rebuild Type 2 or 3 Speedos, kmh or mph and normal/turbo cars.
    Crowndog, ME308 and G. Pepper like this.
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Looking forward to it!
  10. mwr4440
    57,962
    Bavaria, The 'Other' Germany
    Mark W.R.
    Me too.
    I 'lost the bubble' on this one a long time ago.
    I'll be needing several of Adrian's boards.
  11. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    Adrian, thanks for the update on this project. Thanks, too, for your relentless pursuit of excellence - revising the hardware and software this late in the game, to perfect the final product.
    I can't wait to get my hands on these and start "testing" them.... although, I'd imagine Adrian will have caught and corrected every last bug before I even install my first one.
    My current speedo is misbehaving more frequently now, requiring a sharp "thwack" on the side of the binnacle to revive it, whenever its needle drops... and most of the time, that still 'fixes' it, temporarily, of course. Once in awhile, even that won't work, and I finish my day's drive using the tachometer as my poor man's speed indicator.
    Needless to say, I'm ready as soon as you are, Adrian, so let me know when I can send you some money for a couple of these, and I'll be happy to pull over and use the mobile PayPal app to send it right away!
  12. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    Just my quarterly check-in with Adrian, to see if there's an update on the project?
    I'm starting my major service, and could add the speedo to the list, if it will be available anytime soon....
    Thanks, Adrian!
  13. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Hi Adrian, I am wondering if you are able to offer the speedo boards yet? Your post in another thread today seemed to indicate they were available, I’d be happy to arrange to buy one ASAP.
    Cheers,
    Gordon
    Crowndog likes this.
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  15. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    Adrian, I'm still ready to purchase the speedo boards, as soon as they are available. Last I recall, I believe you reported that there was some software work remaining to do.
    Based on reading your post from yesterday, I think you may have been referring to the Speedo SENSOR board, rather than the Speedo HEAD board.
    Please advise on the speedometer head board.
    Thanks Adrian!
  16. mwr4440
    57,962
    Mark W.R.
    Ditto.
    Im IN for several.
  17. thepadol
    thepadol Rookie
    Jun 30, 2019
    2
    Thepadol Dardarananda
    For Adrian - an unexpected savior perhaps. I've been trying to figure out my speedo which stopped working, only that it's one for an Alfa Romeo GTV6 1986. Obviously it's a Veglia Borletti and so they are all the same pedigree and oddities. It's got an RCA 92956 chip so from reading on postings here I think it's close to a type III board. Is the circuit schematic available? I'd be happy to put together my own board and modify to accomodate differences. It it requires programming, I'd be happy to undertake too.
  18. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I haven't done work on Alfa GTV6 speedos yet so have no reference about the boards, maybe you could send a photo or two to my info@ mail address? Based on my notes, the RCA 92956 has not been used on any of the Ferrari Veglia Speedo type boards. Type 3 boards are based on the RCA 9296x family.
    Saabguy likes this.
  19. thepadol
    thepadol Rookie
    Jun 30, 2019
    2
    Sorry it was my typo in haste probably. The chip is RCA 92967 as you would have expected. I will send to the email address.
  20. Lee Ruble
    Lee Ruble Rookie
    Apr 5, 2019
    2
    Hello. I am new to the Chat. I have a 1981 308 GTB with a 1988 3.2 QV engine/transmission from a Mondial.speedometer works but, reads twice the actual speed. I think the earlier chassis/speedo is expecting the speed sensor to read an 8 tooth reluctor and the later model engine/transmission has a 16 tooth reluctor. Is there a way to put a later model circuit board in the earlier speedometer?
  21. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Yes, correct. The Type 2/3 Speedo boards are not compatible with the Type 1 Speedo as the internals/motor is completely different. I could modify my Type 1 replacement board to work with a 16 pulse gear box though.
  22. Lee Ruble
    Lee Ruble Rookie
    Apr 5, 2019
    2
    If you could modify your Type 1 replacement board that would solve my problem. How do I proceed with a purchase of this modified replacement board. Thank you, Lee Ruble.
  23. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Please me an email to my contact address, i'll check if i still have a board and then do the modification.
    Matt Sanchez likes this.
  24. 4valves
    4valves Rookie
    Aug 29, 2012
    12
  25. 4valves
    4valves Rookie
    Aug 29, 2012
    12
    Sorry for previous and empty post.
    Hi alhbln, I followed your tread and works, but I not understand where you are with type2 card development.
    I'm 308 4valves (1984) owner, and speedo and odo dead, sender sensor is 116987 type, and it's ok, so I think that I need one of your card.
    Today I try to remove instruments and I was able to read label on speedo cover:
    061.7367.990.1
    1giro=0,52MT
    CAPT.68.0517
    121469 8M 50
    My questions are:
    Label infos are enough to know which card I need, or I've to remove completely instruments and check inside the speedo card?
    Is the new card developed and available to replace that?
    Thanks for your help.
    Best regards
