308 Speedo Repair/Rebuild | Page 11 | FerrariChat
Discussion in '308/328' started by alhbln, Aug 22, 2013.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    The type number 61.XXX is sufficient to identify the board, it is a Type 2 speedo.
    I have finished the Type 2 circuit board but did not find a good solution for the calibration process yet. The factory process for the type 2/3 Speedo was to send a specific speed signal to the Speedo and then install the Speedo needle in the correct position with a machine. Calibration on my PCB does the same, it creates a predefined speed signal but you would need a special tool or trained hands to properly install the needle then.
    G. Pepper likes this.
  2. 4valves
    4valves Rookie
    Aug 29, 2012
    12
    Do you think that will be always in this way or will be possible to find different solution? Other solution could be to send you a speedo ( I think you are in Germany correct ) and you change card and set it ? Do you have additional solutions?
    Is it possible to repair my card, I mean the chip installed is available or like SAY 115 parts?
    Thanks again
  3. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I'm thinking about either changing the electronics to further calibrate a previously installed needle or if its possible to 3d print/mill a small guide for installing the needle. Type 2 Speedo PCBs have a different chip, these use a RCA 929xx type which is not available anymore unfortunately.
  4. 4valves
    4valves Rookie
    Aug 29, 2012
    12
    So at moment, we can't use for type 2 your great work!
    Do we have to wait till you will find different electronics ?
    Send speedo to you, for card exchange and setting, is not feasible?
  5. chrisgoates
    chrisgoates Rookie
    Nov 21, 2019
    1
    Christopher Oates
    I have joined this forum in order to thank Adrian and other contributors to this thread which has enabled me to repair the Veglia Speedometer from an Alfa Romeo GTV6.
    The short version is that it was the BD370 transistor in the amplifier section that was faulty, I replaced it with a BD244C.
    The long version. It is a long time since I have owned a 1980’s Alfa Romeo but in the process of trying to clear out my garage I came across lots of spares. A few weeks ago I came across a GTV6 speedometer together with a lot of ex Fiat Veglia speedometers of the same era. I vaguely recall pulling these from Fiats in a scrap yard, I assume when I was trying to repair either my Alfa or Guzzi speedometers. I also had one complete sender. I was curious and hooking the sender up to an electric drill showed that some of the Fiat speedos worked but the GTV6 one didn’t. Here was the challenge, could I fix it? Two of the Fiats were of your type I with a SAY115Y chip, the remaining Fiat and GTV6 ones were of the Type 2/3 in that they all had an 8 pin DIP chip labelled RCA, but had several differences, the most notable being that the GTV6 one had 3 transistors.
    I experimented with a very old oscilloscope, basic signal generator and an audio amplifier and discovered that the working speedos would run with a square wave signal of about 8 volts and about 100 Hz, and a 12 volt power supply. My probing with the oscilloscope on the working units confirmed Adrian’s work that the square wave signal from the sender was processed to about 6 volts and input onto pin 1 of the chip which behaved as a frequency to voltage converter outputting a voltage onto pin 5 which varied directly with the frequency of the input. This voltage was processed through the two transistors and drove the dc motor which ran the speedo needle and odometers just like an old mechanical drive would, about 1-7 volts gave about 0-100mph. Feedback came from the motor sensor into pin 2 of the chip at approximately half the frequency of the pin 1 input and about 6 volts and I assume, but didn’t investigate further, modified the voltage put out on pin 5.
    There was no consistency of the markings on the 8 pin DILs apart from RCA, some were illegible. I tried to find a current IC that might perform the comparator function on two frequencies as well as converting to voltage, the LM2917 looked hopeful but my electronics knowledge was not sufficient to tell if it could be made to work. The pinout was different to the existing IC.
    I jumpered the motor drive from a working speedo to the non-working GTV6 one and the motor and motor sensor worked. I couldn’t see the tracks on the double sided circuit board well enough to draw a decent schematic, they were obscured by the components. I reverted to my usual fault finding technique of unsoldering and testing any burnt or damaged looking components (none in this case), then capacitors (all OK), then semiconductors. The BD370 transistor was faulty. An internet search revealed it was PNP medium power silicon but obsolete with a strange pinout. I substituted a BD244C which had similar characteristics but is physically bigger as higher power and twisted the legs to match the old pinout. It worked both with the signal generator and the Fiat sender driven by the drill.
    Chris
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    It's not really a problem of the electronics but rather how the Speedo was designed for production. Marelli simply removed the possibility to calibrate the instrument after it had been assembled. I was thinking of adding a calibration option, so you could install the needle as usual and then fine tune.
  7. BigTex
    79,380
    Houston, Texas
    Bubba
    Welcome Chris!!
    Wonderful thread.....]
  8. 4valves
    4valves Rookie
    Aug 29, 2012
    12
    Hi Adrian I understood situation, so I asked the possibilities to send to you the speedo and you change electronic and also set mechanically means calibrating it.
    Is this possible, or we have to wait that you will find different solution?. Thanks
  9. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    That should be feasible but it would not scale to do this for everyone and we have to find a way for shipping to the EU if you are in the US.
  10. 4valves
    4valves Rookie
    Aug 29, 2012
    12
    Hi Adrian, I'm in EU, Italy so will be not a big problem, to ship speedo!
    How we can proceed? If you prefer write your private mail so we can agree:
    Carlo
  11. LIONEL COGNET
    LIONEL COGNET Rookie
    May 10, 2020
    1
    LIONEL COGNET
    bonjour adrian,je suis en france je serais interessse pas ton pcb de remplacement c'est pour une ferrari 308 TB par contre j ai deux pcb dans le mien avec SAA1004n qui est monte en diviseur de frequence
    crdialement lionel
  12. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Bonjour Lionel,
    the PCB you posted is the intermediate version between type 1 and type 2 boards. It has the same size and speedo mechanics as the type 1 Speedo but already accepts the speedo sensor type 2 installed in later cars. I can modify a type 1 replacement board to be compatible with your setup.
  13. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Due to too much corona induced home office i started to work again on the type 2 speedo to find out how to fix the calibration problem. If i can't find a mechanical procedure then a redesign of the board by introducing a calibration trimmer might be another approach.
  14. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    Hi Adrian,
    If you've still got that speedo sender casing I gave you, I'd be happy pay you to assemble it with the new internals you designed - I replaced it with a second hand one, and I'm just waiting for it to fail!
  15. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Ferraridoc, sent me your shipping address and i'll send it to you. I still have it, it is the reference conversion and fully functional.
    So i hope everyone is healthy and not too much restricted by the loockdown. The homeoffice gave me some unexpected spare time to review the type 2/3 calibration and i decided to completely redesign the board to incorporate the same calibration via trimmer as in the type 1 board. Currently working on the reference board, will do some first prototypes in the next week and if it works, send out some trial boards to you guys. Just took some years to get there.
    Freerange likes this.
  16. Ferraridoc
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    Thanks, Adrian.
    PM sent.
  17. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    miketuason and G. Pepper like this.
  18. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #268 Crowndog, Jun 24, 2020
    Yeah now that’s art! How come 308 isn’t listed on the board?
  19. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    The 308 IS listed, it's called "Non Turbo Engine" on dip switch #2. ;)
    I'm confused by the dip switch #1 for "km/h & mph" <--> "mph>km/h Conversion" Maybe the label is the Conversion side, and it's ON for km/h, off for mph? Does the odometer match the speed units, ie if km/h selected, odometer shows km, while mph has the odometer show miles?
    alhbln and Crowndog like this.
  20. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    The 308 Turbo (right side of mode switch) was just called "GTB Turbo" or "GTS Turbo" by Ferrari, so no 308 listed on the turbo mode switch.
    This board should support most if not all Ferrari Speedo's from 1980 (EU) / 1982 (US) up to at least 1985, some up to 1988.
  21. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Please ignore the "On" label, the switch points to the configuration, which is activated. So on the photo is the default, a normal aspirated engine with either a km/h or mph Speedo (km/h & mph). The "mph>km/h Conversion" setting allows you to convert a mph US Speedo into a km/h EU Speedo.
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Please PM when funds are required for purchase or if test mile needed.
    alhbln likes this.
  23. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    My speedometer is malfunctioning overall, but never reads less than about 15-20 mph. (Once over that speed, it tracks speed as expected.)
    Will this correct that issue? (Also, is this a common problem?)
  24. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Which type of Speedo/part number? Is the needle at 0 or 5 when switched off, or also at 15-20mph?
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    When off, it sits at 10mph. No idea on the part #.
