Buy
308 steering rack
Discussion in '308/328' started by Andythebath, Jul 6, 2021.
  1. Andythebath
    Andythebath Rookie
    Dec 29, 2019
    40
    France
    Hi all
    Hope to call on your experience to tell me what’s missing / what I might need to fix the excessive play on this steering rack ? It’s a lhd 1981 GTSi
    Thanks in advance
  3. miketuason
    miketuason F1 World Champ
    Silver Subscribed Owner
    Feb 24, 2006
    14,574
    Cerritos, CA.
    You may be missing that one bushing inside (bottom item in the pic) where the rod/rack slide back and forth and keeps the grease or oil from coming out. I just rebuilt mine not too long ago, it did had an excessive play also where I couldn’t have my front wheels align.
  4. Andythebath
    Andythebath Rookie
    Dec 29, 2019
    40
    France
    Thanks I’ll look up that part on Superformance
  5. miketuason
    Feb 24, 2006
    14,574
    Cerritos, CA.
    If it’s not missing then it’s more likely worn out which mine was.
  6. Andythebath
    Andythebath Rookie
    Dec 29, 2019
    40
    France
    Maybe it’s worn out to the point that it’s disintegrated, how does the new bush fit it? I presume the track rod ends have to come off somehow ? Thanks
  8. miked
    miked Formula Junior
    Feb 7, 2001
    688
    Cincinnati, Ohio
    Mike Dawson
    The steering rack is the same as used on a Pantera. This link is to a tutorial on rebuilding the rack, it's been around for probably decades and has become the "go to" article for rack rebuilds.
    http://www.panteraplace.com/page203.htm
  9. Andy 308GTB
    Andy 308GTB Formula 3
    Jun 2, 2004
    2,499
    Essex, UK
    Andy M
    All of the above. You will need 2 of those bushings (the Superformance website states that) and I can confirm that.
    I used Penrite Semi Fluid Grease to fill the rack with (https://www.penriteoil.com.au/products/semi-fluid-grease)
    Track rod ends. Remember that this is a steering rack shared with the mini. I bought track rod ends from a mini spares places and they were a fraction of the price of those offered by the usual suspects.
  10. miketuason
    Feb 24, 2006
    14,574
    Cerritos, CA.
  11. BigTex
    Rossa Subscribed Owner
    Dec 6, 2002
    75,247
    Houston, Texas
    Bubba
    The original end play bushing was Delrin, or plastic.....I think the conventional wisdom is to replace it during rebuild with one machined of brass???
    It will cause steering wheel shimmy, once gone...
  13. dave80gtsi
    dave80gtsi Formula 3
    1,569
    Ohio
    Dave Meredith
    Is there a known experienced shop which someone can recommend who can rebuild our steering racks to a high (OEM quality) standard?
  14. absostone
    absostone F1 Veteran
    6,406
    Pantera uses the same bushing
  15. Cirorsi
    Cirorsi Formula Junior
    528
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    call Dave at AW Italian in Eatontown, NJ, they rebuild your own or can sell a new one (I have not used this service however). 732-542-5600.
