308 strange cooling system air issue | Page 2 | FerrariChat
Discussion in '308/328' started by chris1866, Sep 24, 2023.
  1. Rifledriver
    36,818
    It has happened many times. The cars work fine either way.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,183
    Norfolk - UK
    Tony
    So do you as you seem to confuse water (velocity) flow with volume.........For your information the radiator header passes a volume of water at a low loss velocity to the rad cores for cooling, if that rad header is partially filled with air then the volume of water (for cooling) decreases.
  3. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,223
    Sergio Tavares
    There could be corrosion or scale in radiator that is blocking.
    Perhaps time to superclean at professional radiator shop.
  4. Rifledriver
    36,818
    You can theorize to support your conclusions all day. I'll just point out the 99+% of 2 valve 308s with properly serviced, 100% stock cooling systems that perform flawlessly.
  5. Saabguy
    Saabguy Formula 3
    1,784
    Shreveport, LA
    Ok, that's funny right there.
    flyngti and 350HPMondial like this.
  6. 350HPMondial
    350HPMondial F1 Veteran
    5,295
    Edwardo
    Saabguy likes this.
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,183
    Norfolk - UK
    Tony
    agreed, most do run without to many issues if looked after correctly. Its no theory just common sense, the clue is the bleed valve!
    Best
    Tony
  8. Sergio Tavares
    Nov 15, 2018
    1,223
    Sergio Tavares
    Yes, this is why a very odd thing has occurred and I wonder if the coolant has hard deposit that would block tstat or tubes or radiator passges
