308 tightening torque for Carb <--> Intake Manifold studs
Discussion in 'Technical Q&A' started by Mike328, Jan 25, 2004.
  1. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    Couldn't find this spec in the workshop manual. These studs use standard nuts pressing down on special tapered washers... Over torqueing, I understand, can contribute to the carb base warpage.
    Ideas?
  3. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    If you can figure out how to get a torque wrench in there, you're a better man than I.
    Since I had to use a little shorty wrench, I tightened about as tight as I could get it. Bear in mind that the short length reduces the effective torque, and the awkward confines that you work in limit the leverage that you can apply - often just pressing on the wrench with the tips of the fingers. So I doubt I'm overtorqued.
  4. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    Mike: If the nut is a 13 mm size, then the torgue would be 15-18 ft-lbs. This seems true of all 13 mm nuts on my TR. I just installed the intake runners at 18 ft-lbs.
    If you can't get a torque wrench in the tight confines, then practice on a nut, and bolt, in a vise, with the wrench that you will use. Then you will have the "feel" for the 15-18 ft-lbs.
  5. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    Yeah, good idea about practicing with the wrench you'll use. BTW, it takes a fair amount of effort to torque to 15-18 ft-lbs with a 4" long wrench! (Doh! About 50 lbs?)
