308 Timing Belt Problem | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by david, Oct 4, 2008.
  1. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    The debate whether to pull the engine for service or to work around it will never be answered simply because it has to many variables. If all someone is trying to do is keep the engine is good running condition and maintain its reliability, the motor can stay put and you can work around it. Ive looked up inside the sump, and while I dont know how anyone got those oil pickup tube bolts off, I will take their word it can be done. And there are (or were) pictures to prove it.
    But if the motor has been in the car over 10 years and looks like hell, and if you want to restore it back to like new, the only way to do it right is to get the motor out of the car. Yes, you can remove the front header with the motor in. Yes, you can remove the timing gear cover with the motor in. And yes, its even possible to remove the front head with the motor in the car. But if your thinking you might be doing any two of those jobs at the same time, IMHO you will be far ahead getting the whole lump out of there so you have some room to work.
  2. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
  3. david
    david Formula Junior
    Feb 21, 2001
    810
    Northwest
    david
    Yes, I think I have to agree with the chicken and the egg concept. I am not one to beat up on anyone just because things didn't go my way. When my mechanic told me the belts were put on too tight, I wasn't too happy about that. However, I also know that there are two sides to the story. I put this out to see if this was cut and dry and from your answers, I can see that there are definitely shades of grey here. And that's what I wanted to determine.
    I think one of the hazards of owning these older cars is that things break. I don't mind taking care of things the best I can. I'm not as talented with the wrench as some of you guys, so I rely on the advice of mechanics with experience as well as my research to learn how to maintain and care for the car. I can see from some of you pros that you are thinking that I'm the type of person who would sue first and ask questions later. I assure you that this is not the case. As you can probably tell, I had a nagging question that I hadn't taken care of things correctly. Part of the equation is whether I selected the right person to maintain my car. I already had enough little things that weren't quite right, so I had changed mechanics. This was a pretty big deal and it was bugging me. At this point, thanks to all of your input, I think I will let it rest.
    All things work until they break.....
  4. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Paul, after rereading your comment this AM I think I was mistaken. I now see you were speaking about the inner bearing and I was commenting on the outer. My mistake, horse of a differant color.
    David, The thought never crossed my mind regarding your intentions or reasoning. I have always said to choose your mechanic wisely as there is much at risk. A full 3/4 of the work I do these days is janitorial in nature and gives the marque a faulse reputation. Once again Brian properly sumed everything up in a short sentence, things are getting old now and have to be serviced regardless if the parts were traumatized sometime in their past.
    Dave
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    44,106
    Hell's waiting room
    David, I don't think you will ever go wrong using Carlo as your mechanic, that was a very wise choice. Unfortunately he's also not going to be around forever. What are those of us in the NW going to do when he retires?? I'd love to quit my job and start apprenticing under him but it would probably take many years to learn a fraction of what he knows!!! Sure would be fun though.
    I've been watching this thread because this is one of the jobs that I'm looking at for my car this winter.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I agree, 2 or more big projects & the motor might as well come out, total effort will probably be a wash or even favor the motor pull. Also it's hard to get an engine really really clean in the car. Some of the more aggressive metal cleaners will also do a job on paint, or cause corrosion if they get into some frame nook & don't get rinsed out.
    I also agree with Dave Helms about you have to be careful when resealing things afterwards, & keeping that $#@#$@ O-ring in place while slipping the cover back in is a real PITA. . But If the timing bearings were the only thing needing work, I'd do it in the car.
  7. david
    Feb 21, 2001
    810
    Northwest
    david
    #32 david, Oct 8, 2008
    Hi John. Yes, Carlo is a good guy and I believe we in the NW will have to prevent him from even thinking about retiring. Here is a shot of my engine after Carlo went over it. It runs as good as it looks. One thing that I've been wanting to do for a while is to remove all the air injection pumps and tubes and junk. But I knew it would be a pain, so when it looked like Carlo had to pull the engine to fix the bearings, it was a perfect opportunity to take care of my shopping list. The removal of the air injection nozzles from the exhaust really helps the engine breathe. I can't believe how much of the exhaust cross section was taken up by the nozzles.
  8. Jdubbya
    44,106
    Hell's waiting room
    It looks Great!! When you did the exhaust you didn't pull the heat shields off the headers? If I wind up pulling my motor this winter I'll probably do the air pump stuff as well. I'm thinking that I'll pull the heat shields off and ceramic coat the headers too though. Did you use Peter's plugs for the injection ports?
  9. david
    Feb 21, 2001
    810
    Northwest
    david
    Heat shields stayed on. I've seen both setups. I don't know the advantages or disadvantages so I didn't mention to Carlo to take them off and he didn't advise it, so there they are. I didn't request a whole big header treatment and quite frankly with all the other stuff, I don't really think the budget would have allowed it anyway. I can barely afford the wife tax for the work I had done... ;) I think the exhaust system will wait for another day. Peter's plugs for the exhaust ports. I know there was a guy on this site that had machined up a bunch at a far lower cost. Maybe they are still available. In my case, Carlo said, do you want to use Peter's plugs on this, and I said fine, whatever. I could probably have done a whole bunch of research and found the plugs etc. but it just didn't make that much difference to me and I know Peter is a good guy so Carlo probably got a good deal from him. Or not.
    Glad you liked the pic. Maybe we will see you on a drive one of these days. I just haven't been able to do any NWRFCA events in a while. Life is interfering with life these days.
    David
