308 timing belt question | FerrariChat
Discussion in 'Technical Q&A' started by Barnone 308, May 20, 2004.
  1. Barnone 308
    Barnone 308 Formula Junior
    Mar 22, 2004
    432
    canada
    Guys, I have a quick question, and please forgive me for my inexperience. but in replacing the timing belts on a 308. I read a few different procedures. But isn't it just replacing belt. after you make your markings and losen the belt, don't you just place another on, and tighten to speck. What does someone have to not forget to do?..
    Thanks Guys, I love F-chat..I wish I can buy you all drinks.
  2. BigTex
    79,218
    Houston, Texas
    Bubba
    Whoa, big fella!
    There's more to it than that. The most common cause of problems is when the Tensioner Bearing and spring is not replaced at the same time. This is critical, as, if the bearing seizes or fails a brand new belt is still toast.
    Also, it is incorrect to assume existing valve timing on the orientation is "spot on", a good technician will investigate and confirm valve train operation per bank before reinstalling new belts. Not uncommon to find someone cutting the corner earlier in the engine's life missed it by a tooth or two.
    A belt service is the cheapest insurance you can buy for these cars. I let my tech do it, at the recommended intervals. We take off a lot of belts that look brand new, but find a lot of tensioners just short of failure.
    Do both at one time! HTH!
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Yes always change both. Belts are around $22 and the kit with Tensioner bearings and belts is around $250 or so.
    Just for the record all of the belts and bearings I have taken off, the bearings were always in surprisingly good condition.
  4. Barnone 308
    Mar 22, 2004
    432
    canada
    Is there anything I can read or intructions that will provide me some guidance on how to do this.
  5. Fiat Dino 206
    Fiat Dino 206 Karting
    Apr 19, 2004
    144
    Mississippi
    David
    You may read through this site ... I can't ensure that it applies or is accurate to every aspect, but it may give you some idea of what's going on.
    You may want another member to read through the procedure and comment.
    http://www.cameragear.com/ec/timing.htm
    I hope that other members will read this and clarify for Barnone ... Thanks
    Best wishes
  6. Fiat Dino 206
    Apr 19, 2004
    144
    Mississippi
    David
  7. BigTex
    79,218
    Houston, Texas
    Bubba
    There is a special tool to span and hold the gears during the procedure, if you are going to maintain the existing timing.
  8. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,153
    Kingsport, TN
    Lawrence A. Coppari
    My experience regarding tensioners is the same as above entry cites. Much of the profit in servicing vehicles is in the installation of new parts whether you need them or not. It takes the same amount of time to install new tensioners as the old ones. They buy them for less than we can so there is profit in making the switch because we have to pay them retail. I have a friend who has a shop that repairs german cars. He cannot be profitable on labor alone. Parts generate profit with no additional sweat.
    I don't blame them. They are covering their butts as well. And the customer feels more secure especially after reading all the scary stories about timing belt failure.
  9. Steve Magnusson
    25,145
    My guess would be that the perceived condition of the Tensioner bearings will vary a lot with the reason for doing the belt replacement. I.e.:
    If it's done because of time yet at low mileage = Tensioner bearings will seem OKish (which is the more common case because you maniacs don't drive your F enough ;))
    If it's done for mileage = Tensioner bearings not so good. At least that's been my experience -- after each of my three 30K mile stints, they've been rather "dryish" and no question IMO needed replacement.
  10. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    This is why I really appreciate my mechanic. He lets me obtain my own parts. Water pump at FNA prices = $1100. Water pump from G. Evans = $350. Nuff said.
  11. Lawrence Coppari
    Apr 29, 2002
    2,153
    Kingsport, TN
    Lawrence A. Coppari
    I still maintain that a lot of replacement parts are not necessary. It is insurance for both the customer and the shop. Some of you guys rationalize it by saying it's the entrance fee for driving a Ferrari. Others indicate they have some sort of special relationship with their technician and that he has their interests foremost in his mind. Oh my.
