308 - Upgraded Valve Stem Seals? Other makes? | Page 2 | FerrariChat
Discussion in '308/328' started by Jack.pe, Aug 2, 2022.
  1. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,599
    California SF bay area
    Paul
    FWIW I used the OEM Teflon seals when I did my heads a couple of years ago. None of the research I did nor people I had talked to ever mentioned there being an issue with them. The engine had about 60,000 miles on it when I did this due to a leaking head gasket and I did not have any oil consumption problems of any sort nor did I see anything wrong with any of the original seals. Putting the new ones on was a bit of a challenge and I messed up and had to redo 3 or 4 of them before I got the procedure down right. They've got about 15-20k on them now with no problems. Also my car is a QV so the seals are smaller than the 2V ones if that makes any difference. There's also twice as many of them so you get real good at installing them by the time you're done. d;-)
    I respect the opinions of others here and the Viton seals may indeed be superior but maybe calling the original seals "junk" is a bit over the top. When I did my work I just didn't want to go down any experimental routes and figured this has been working so far, may as well stick with it. Just my two cents.
  2. s219
    s219 Formula Junior
    Aug 26, 2021
    479
    Good update video from Jack:
  3. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,599
    Paul
    I left a comment that he shouldn't be turning the engine over with the heads off without hold-downs for the liners.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    Given that "Jack" posted a video showing smoke on start up back in June of 2021, shortly after putting the engine back together, the seals popped off almost immediately. But it's not the type of seal that was the problem. It was that the supplied seals did not fit properly. Something that, IMO, the shop should have checked. An example why most shop won't install owner supplied parts.
  5. Jack.pe
    Jack.pe Rookie
    Apr 6, 2020
    20
    Jack Pegoraro
    Chaps, thank you all again for your input on all this.. I will let you know which way we decide to go but I think viton is the most likely!
    Portofino and Ferraripilot like this.
  6. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,588
    Argent/Brasil
    Guido
    Can't you glue them in place ?
  7. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,776
    Atlanta
    John!
    No, that is what the spring collar on the valve seal is for. Making certain the valve seal fits your particular valve guide correctly is the trick.
    mike996 likes this.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,773
    Cerritos, CA.
    Even if the original is still available, I would still get and use them, imagine they lasted 40 years, now what’s wrong with that?
    JuLiTrO likes this.
  9. AlfaGreg
    AlfaGreg Karting
    Dec 28, 2003
    83
    Saint John, NB Can
    Greg Gormley
    Jack....I used 8mm Viton valve seals on my '77 308 GTB engine rebuild back in '19. So far, no issues. I purchased them from my local BMW shop. The P/N was
    Cortico 026109675. For reference, there is marking on the seal itself. = CFW E26 VA3 8-26. Hope this helps . This is a stock photo of the seal which matches mine perfectly.
    MFlanagan and miketuason like this.
