308 V12 conversion begins | Page 113 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #2801 PSk, Nov 5, 2009
    Beautiful, but I am surprised you completed the welding before you had tacked all the other pipes together ... hope you won't need to make a change.
    The last set of extractors I made was like 20 years ago and I had a dummy engine which I used to build them on. What I didn't realise was that the water pump or something was slightly different (because the block was from an earlier model) and when I went to fit them on at the engine builders so we could chuck the engine on the dyno I was mightly embarrassed as one pipe just fouled the pulley. Whipped home and remade one side (was for a flat 4 Alfa Sud engine and the pipes went forward and collected as we had no room elsewhere) and we were back in business ... but we did loose a day ...
    Pete
  2. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Your headers look good to me Mark. Don't worry too much about the appearance. They look good from here. Some guys weld like robots and some don't. I've been welding for a very long time and nothing breaks but some guys just make much neater beads than me no matter how hard I work at it.
    Wil
  3. branko
    branko F1 Rookie
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    I don't know. When I'm stick welding everything is bright in my instant-on helmet but things are not as bright when I'm tiging. You may not be out of practice.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    The lens in my helmet is a 12 to block the high power alum welding arc. I usually use an 8 or 9 fo rthis type work. The instant on helmet I ordered is adjustable form 9-12 so it should be perfect. I picked up a new 8 lens for my other helmet too today....I don't know what happened to my old one.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    #2805 mk e, Nov 5, 2009
    Tonight was start the collector night. I'm making the angle 15 degrees. Now I know you see it tacked on but don't get scared, it's coming back off. I just tacked it of to use the header as a jig and the next time I get into the shop I'll cut it off so I can weld and grind the inside of the collector and do some more work on the end of the header, then the collector will go back on for real.
    It looks like there is just enough room to leave this collector straight and go into a 4" radius 2" OD pipe. The other one will need to be a little tougher though as I'll need to use a 6" radius whcih means a longer flow path. If I want the headers to be parallel I'll need to put the collector on the bend to get the lenght right. The other option is a straight collector that comes off the bend at about a 30 degree angle....might look messy. I'll need to think about this because neat counts and is worth a little extra work.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I like to live dangerously :)
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Thanks Wil...every project I start I say "tis is the day I get the robo-welds"...and every time it's not.
  8. hotrod406
    hotrod406 Formula Junior
    Sep 18, 2007
    540
    Grand rapids area,MI
    Tim
    Nice, I love merge collectors. I wanted to try something like you are doing with the pipe stubs but I did not dare. I also don't have vertical band saw like I suspect you do. How did you figure out where to cut the pieces? That's what I could not wrap my head around.
  9. 89vr
    89vr Rookie
    Apr 30, 2007
    42
    Midlothian TX
    Chris Marotti
    amazing, this thread helps me get back to work on my car again. it's been sitting for two years apart in the garage. thanks mk e!
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I can tell you that I didn’t give it enough though before I started cutting and the piece shown in the first pic I posted is a bit wrong. I used it anyway because I’m to cheap to waste a $15 piece of tubing but it means filling a gap with weld. I’ll post a pic of the problem next time I’m in the shop…probably Monday.
    The right way to do it is probably like this:
    Cut to length. The require length is about = (Tube size-exist OD/2)/sin15
    (this will be a little short because of bend radius and because the tubes don’t touch in the middle…a CAD layout will get the correct number or 30 minutes of tig, I just added 1/2” and called it close enough)
    Mark the centerline on the OD.
    The tube end needs to be 360-(360/#of tube), so for me it’s 240 degrees. The tube it 1.75, so 2/3*1.75*3.14= 3.667”, then I measured ½ each way from the centerline and marked it.
    The exit end is =(exitOD/3)*3.14. for me that is 2.00/3*3.14=2.09, again split at the centerline and marked.
    Draw a line connecting the 2 marks you just made and cut. I cut the first one with a cut-off wheel in a die grinder and it worked fine but that finished off the cut off wheel and I found I didn’t have any more. The next to I cut in the cut saw just holding the part with a pair of vise grips….I’m sure the safety people at work would not have approved but it was very fast and easy.
    Then I beat the exit end to about a 2” OD and started fitting and welding. I had to do some grinding in the middle 1/3 of the pieces to get them to fit right.
    When I do the next one I’ll take pictures of each step which will probably make it more clear.
  11. tknobby
    tknobby Rookie
    Mar 12, 2009
    49
    Mark,
    You Are adding the little triangle where the 3 tubes connect inside the collector, right? I forget the name of this piece.
    Tom...
  12. hotrod406
    Sep 18, 2007
    540
    Tim
    I'll have to read that at home where I can concentrate on it. I tend to just "do it" and see what happens as I go.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Yes, it’s next on the list and that is what I meant by more work on the header. I couldn’t do it last night because I was out of cutoff wheels.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    That’s what I usually do to…I only thought about it after I realize I cut the tube wrong.
    All the math says is you want to cut the header end of the tubes so they go to the tangent points where the header tubes touch each other. On the exit end the length of all the pieces welded together need to add up to the circumference of the diameter you are trying to make.
    That’s really all there is to it other than picking a length. Length and angle go hand in hand. I wanted a 15 degree angle or there about so I use trig and a little estimation to give me the length that would get me close. I used 3.5” measure along the outside of the tubes (by chance it’s 2 times the primary tube OD)…which really was a tad short so my angle is more like 16 or 17 degrees. Burns only sell 1 flavor and it looks like 15 degrees, but SPD has 12, 15, 20, 25 so I’m right in the middle and since I have no idea what ideal is I guess what I have will be just fine
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    In other news I sent a couple emails to cam guy this week . The first one explained the Lana knows I’m hiding money so if he wants it he’d best get the cams done and the second explaining that “tomorrow” was over a week ago and if his measuring guy is that busy I’d be happy to give him the address of a place that would be happy to turn them around in a day or 2 at the most as it’s only 30 minutes worth of work.
    No response.....I'll call on my way home tonight.
  16. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #2816 ernie, Nov 6, 2009
    Yo Mark!
    Hey does Burns have a 3 into 1 merge collector you could use? I ask because it looks as though the way you are welding up those pipes you aren't going to have the point protruding into the merge the way the Burns 4 into 1 collector does.
  17. brian.g
    brian.g Rookie
    Apr 4, 2009
    24
    West of Ireland
    Brian Garvey
    Mark,
    Great to see progress again, you know my thoughts on the whole thing, amazing.
    I must reply to your pm also, just seeing it now.
    The best of luck, watching this one always.
    Brian.
  18. hotrod406
    Sep 18, 2007
    540
    Tim
    They sure do. Only $276 each. That might be why he's electing to build his own.
    http://www.burnsstainless.com/MergeCollectors/3into1base/3into1base.html
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Don’t worry, the points are coming, patients.
  21. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Okay I'll be patiently waiting for the pics.
    :D
  22. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    I'm a little late for this, but thank you. :)
    This project is really coming along!
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    How did you even find that at this point?
    I have trouble finding stuff I wrote last week much less last year.....this thread is out of control. I think it would need to be it's own topic with everything broken in to 4 or 5 sub topics and then cross linked somehow if I was going to find anything specific in it. Finding a picture in here is getting almost as bad as finding a specific one on the bikini thread :)
  24. 134282
    40,647
    California
    Carbon McCoy
    I realized I hadn't been in here in a while and decided I need to catch up on what was going on - but I couldn't remember where I'd left off, so I just started from the beginning. :)
    It was almost as much as fun as going back through the entirety of the bikini thread!
  25. gmoore
    gmoore Rookie
    Jul 18, 2004
    19
    Seattle, WA
    Greg Moore
    Bikini thread? Where have I been? I guess spending too much time looking at pipes on here....
    Where is it?
