308 V12 conversion begins | Page 127 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    +1. Most impressive.
    Pete
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,915
    Atlanta
    John!
  3. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,168
    Huntsville, AL., USA
    Andrew
    That's a great result, Mark. :D
    All the best,
    Andrew.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Schwing!
    Nice work Mark.
  5. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Did you flux each joint? Is it worth picking up a can of that flux?
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    I fluxed pretty much joint before tacking so the tacks didn't leave anything inside then I purged during the full welds wher I could.
    I liked the flux over all. It gives a good result if the joint is a good tight fit, but not so good if if there is much of a gap, say over .04".
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    I don't have the bends I'd like to use for the front 2 into 1 so one to the heads I guess.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    I just got a cal from Web Cam. The cams are back from copper plating and going on the machine for rough grind. Progress.
  9. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Sweeet!
    Lets get this party started!
  10. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    Whats the deal on copper plating? Whats being plated and why, the part of the cam that runs in the cylinder head?
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    The cams were made from 8620 steel. This a pretty strong steel that case hardens well. I want the lobes and journals hard, but the shaft part wants to be more tough than hard and it’s the copper that lets this happen. The entire part gets copper plated then the lobes and journals are rough ground which removes the copper from these surfaces only. Next the cams go to the heat treaters and are carburized, the carbon soaks into the bare steel but does not go through the copper plating leaving the shaft part as 8620, but making the wear surfaces more like 8680 to a depth of about .030”. Then the actual hardening is done and the wear surfaces with their now high carbon content get to about 65C Rockwell while the base metal only goes to about 45-50C.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    #3162 mk e, Dec 16, 2009
    I looked and the cam accel/decal ramps today. The 2 lobes I picked have very difference designs. It looks like the intake is about a 30 degree vs 45 on the exhaust and they are not at the same lift points and they have different blend radii. I’m seeing the max allowable lash on the intake as about .012” and the max on the exhaust as .008”. Normally you would expect the intake lash to be less than the exhaust but because the tails are so different a design setting the intake at .006 and exhaust to .008 costs a ton of low end hp…at least it does on the simulator as the sim says the engine is hyper sensitive to intake seat to seat duration. It looks like the correct lash setting are .010-.012 on the intake and .006-.008 on the exhaust with both erring toward the loose side if possible.
  13. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Can you go more into the theory on the valve lash? I guess I don't have a clue as to how they come up with these numbers? I always assumed it was just some sort of mechanical tolorence issue and never thought of it as a tuning for power thing.
  14. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,168
    Andrew
    :confused:
    Sorry, I'm totally out of my depth now and don't know how to interpret the graphs. Any chance of a link or quick lecture on the basics so I can keep up? :eek:
    All the best,
    Andrew.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    Sorry…….clearly what I was thinking didn’t translate well into a post.
    A cam has a few distinct regions to it. At the very bottom where the cam first stars to move the valve are the acceleration/deceleration ramps. These are designed to gentle start the valve moving and gently stop the motion so there is no bouncing or banging to beat up the valve train. thr graphs show the shape of the ramps with zero lash and maximum acceptable lash. Simple enough.
    The problem is that these features can add a ton of seat to duration which is a bad thing as it allows all kinds of reversion pulses to form, allows cylinder blow-down which effectively lower compression ratio and other bad things. On the intake cam I selected increasing the lash by .002” decreases the seat to seat duration by 4 degrees but only decreases the .050 lift duration by about 1 degree and that helps make hp down low. If I go too high on the lash though I would hit and exit the cam on the main ramp instead of the accel/decal ramps and beat the snot out of the valve train so you want to be in just the right spot…anyplace else and you are giving up hp or giving up engine life.
  16. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,168
    Andrew
    Ahhh - thanks Mark, I get it now. :D
    All the best,
    Andrew.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    #3167 mk e, Dec 16, 2009
    Here is other cam design. It has no actual accel/decal ramps, just a radius to serve the purpose. These cams would want the lash set in the .002-.005 range to be in the right spot.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    #3168 mk e, Dec 16, 2009
    Ok, I'm not done with the headers. I didn't notice before but thefront headers ended up a little crooked some how.....anyway I couldn't bring myself to leave it so I cut #4 apart a little bit and fixed it. I have a little more welding on tube 1 & 3 and I think I'm going to order a new bend for tube 2 to give me a little more clearance to get the nut on the stud. I'll order the bends for the 2 into 1 too I guess.
  19. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Wouldn't you want to design the cams so you could run the tightest lash? By increasing the lash you lose duration and lift, I can see reasons you'd want that but wouldn't it be better to use a different profile if you knew that while designing the cams? I'm just trying to get my head around this.
  20. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    Excellent attention to detail!
    Keep up the good work!
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    Yes and no. Yes lash decreases lift and that is a bad thing but designing the cam to work with more lash means there is more margin for error in valve adjustment and therefore allows longer maintenance intervals. Everything is a compromise.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    #3172 mk e, Dec 17, 2009
    This whole lash thing got me thinking if I would have been better off with a cam that has less lift but wants less lash. I laid the intake )blue line)and exhaust (red line)I ordered set to what I think is the correct lash (.010 Intake, ,008 Ex) over another intake option that has .007 less lift but wants only about .002 lash (green line).
    The lower lift cam ends up with .001 more lift than the higher lift cam, the seat to seat and .050 duration of the higher lift higher duration cam ends up less than the lower lift lower duration cam, but the higher lift cam has about 5 degrees more duration from about .200 lift up to .400. This all says the intake cam I ordered will make more hp from idle to redline than the lower lift lower lash option just like the simulator says it should in spite of needing more lash causing it to end up as the lower valve lift option.
    It also look like both the exhaust and intake I ordered will do a better job of picking the valve up and setting the valve down gently than the low lash design option and will do so over a .008+ lash setting window vs the low lash design that really wants to be help in a .002- window.
    I know….engineer types get excited by boring sh*t and you want pics of something being cut or welded, tonight.
  23. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    I've only been looking at the pictures so far, very nice by the way.
    But for the love of all that is holy and Italian, please do not put the diaper back on the car. Go naked or use an early model mesh type screen.
    I know Big Tex had one made at a local shop here as he used mine as a pattern. They duplicated it exactly and IIRC it was not that bad a price either.
    http://www.ferrarichat.com/forum/member.php?u=11800
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,792
    The twilight zone
    I hear you, but I’m a big fan of leaving things stock. ;)
    I actually prefer the diaper anyway, which goes to show there is just no accounting for taste
  25. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    OK, I see.
    Do you leave the copper on the cam after the lobes and journals have been ground and hardended, or does it have to be stripped/removed?
